Old 04-03-2017, 04:02 PM   #1
Joesurf79
Joesurf79's Avatar
Drives: 2016 White Pearl BRZ Premium
BRZ - what does it use to determine vehicle speed?
Searched some but didn't find the answer. Does the BRZ use wheel speed to determine vehicle speed? I have a different final drive ratio now, and the speedo seems off compared to GPS displayed speed. But I can't reconcile why the final drive ratio would have affected it? Thanks for any info you might have - Joe V
Joesurf79 is offline   Reply With Quote
Old 04-03-2017, 04:23 PM   #2
Kodename47
Kodename47's Avatar
Drives: UK GT86
Rear wheel speeds. There is always a difference between GPS and displayed speed.
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-03-2017, 05:20 PM   #3
churchx
churchx's Avatar
Drives: 2014 GT86
Speedo is off in all new cars even stock. By 4-10%. IIRC was ~8% slower in my gt86.
Joesurf79 (04-04-2017)
Old 04-03-2017, 05:40 PM   #4
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Perhaps you should also disclose what else is different on your car, aside from your final drive.
Old 04-03-2017, 10:49 PM   #5
Turdinator
Señor Member
Turdinator's Avatar
I believe the speed is determined by the ABS sensors so changing a final drive should have no effect on detected speed. Wheel, tyre size and even tyre wear will effect the detected speed however.
1974 TA22 Celica
2013 86 GT
The Following User Says Thank You to Turdinator For This Useful Post:
Old 04-04-2017, 02:58 AM   #6
CSG Mike
CSG Mike's Avatar
Wheel speeds (specifically rear). FD doesn't affect speedo.
JoeC (04-04-2017), Joesurf79 (04-04-2017)
Old 04-04-2017, 09:23 AM   #7
JoeC
Drives: Subaru BRZ Limited
so then is the speedometer not affected by changes to the rear end?
JoeC is offline   Reply With Quote
Old 04-04-2017, 09:27 AM   #8
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Speedo is affected if you change tire/wheel diameter.
The Following 2 Users Say Thank You to PandaSPUR For This Useful Post:
CSG Mike (04-04-2017), JoeC (04-04-2017)
Old 04-04-2017, 09:56 AM   #9
How is that not a clear statement?
JoeC (04-04-2017)
Old 04-04-2017, 10:32 AM   #10
JoeC
hahhah. it was totally clear. I guess I just hadn't had enough coffee yet because apparently I didn't even read the entire sentence. may bad
The Following 2 Users Say Thank You to JoeC For This Useful Post:
CSG Mike (04-04-2017), Tcoat (04-04-2017)
Old 04-04-2017, 10:33 AM   #11
LOL I thought I was missing something somehow!
CEL P0500 Vehicle Speed Sensor Malfunction travisb Issues | Warranty | Recalls / TSB 34 06-23-2021 03:12 PM
Vehicle Speed Sensor Location or Pin Out jjkerr626 Engine, Exhaust, Transmission 6 06-21-2018 11:09 AM
Boost Up Your Vehicle's Speed, Power, & Track Times at FR Sport! FRSport.com Forced Induction 0 01-24-2014 12:33 PM
How to determine whether TSB applies to my car? qqzj Issues | Warranty | Recalls / TSB 2 11-12-2013 06:08 PM
Engine Speed vs Vehicle Speed for 6MT DetroitJake Engine, Exhaust, Transmission 22 04-27-2013 06:56 PM
