Old 04-03-2017, 06:33 PM   #15
VIP BRZ
VIP BRZ's Avatar
Drives: 2014 Subaru BRZ
Originally Posted by cat94 View Post
I discussed why I'm not/don't want to go through insurance in a previous thread, and here I'm hoping to find some tips on touching this up by hand =)
So far, my plan is to:
(1) chip off loose paint around the edges of the scratches
(2) lightly sand the scratch
(3) apply touch-up in layers
(4) sand smooth, compound & polish
Not expecting it to be invisible, but better off than it is now.
I really doubt the above method will look better than it is now, if your not going to have it fixed proper. leave it as it is..
your setting yourself up to make a mess (what are you even planning to apply your touch-up paint with? a brush!?)
VIP BRZ is offline   Reply With Quote
Old 04-03-2017, 08:30 PM   #16
cat94
Drives: '17 86
Originally Posted by ChinatownDragon View Post
Didn't see it but fair enough, best of luck with the repairs!
Thanks!
I was thinking of using model brushes, though... now I'm discouraged. I have a pretty deep rock chip (down to metal) I've been meaning to touch-up too. Maybe I'll do that first and see how badly things go.
cat94 is offline   Reply With Quote
Old 04-03-2017, 10:52 PM   #17
VIP BRZ
VIP BRZ's Avatar
Thanks!
^^ Now this is sounding rational, give it a try on the small chip before you do any sanding! try using a toothpick to apply layers within the chip.
its really a lot harder then you might expect, and honestly the prep work is just as important if not more important then the actual application of the paint.
Paint work is something i personally really only trust to a professional with experience.
Old 04-04-2017, 12:33 PM   #18
cat94
Drives: '17 86
I can see why that is. I'll give it a shot with a toothpick on the small chip before doing anything crazy. I've also seen somewhere that mixing the clear coat with the paint makes it a lot easier to apply a decent finish. A body shop I spoke to said that clear coat is sticky and difficult to work with.
Old 04-05-2017, 11:16 AM   #19
Anderzz
Anderzz's Avatar
Drives: 2013 Subaru BRZ Premium
Ouch.
You can risk doing it yourself: wet sand the surrounding area, layer it with touch-up 3 times, wet sand again, re clearcoat, wet sand again, and then polish and treat with something like AMMO hydrate.
Only other option with scratches of that severity is a full blown body shop paint match that'll probably run you $500...
Anderzz is offline   Reply With Quote
Old 04-05-2017, 02:51 PM   #20
cat94
Drives: '17 86
Originally Posted by Anderzz View Post
Ouch.
I had a couple quotes both at $1200+
I'll test this method on a decently sized, unrelated rock chip and see where that goes. Would a typical wax suffice, or is there something special in ammo hydrate?
Old 04-05-2017, 03:44 PM   #21
Anderzz
Anderzz's Avatar
Any wax will work, Hydrate is just the best IMO.
Old 04-05-2017, 03:52 PM   #22
cat94
Drives: '17 86
I see. I've been wanting to try Hydrate as a drying aid, though I've been using Sonax Spray wax for that and it's been good.
On another note, I just put in an order at the Toyota dealership for D4S (Raven) paint and there were 3 coats. Anyone know what the purpose of this is?
Old 04-05-2017, 04:03 PM   #23
I would try this. The reality is that no matter how bad it can't get worse than it is. I have had both great luck and miserable failures in doing this sort of thing but if you take your time it should be fine.
Couple of points I learned doing touch ups:
If the touch up paint is drying too fast and not flowing then use a bit of thinner to retard the dry time. The proper thinner should be listed on the container. Just dip your brush it the paint then in the thinner and then apply. Let each coat dry thoroughly before adding the next.
Tape off just outside of the space you are sanding with masking tape. If things go wrong you don't want the space you have to fix to keep getting larger!
Go to a hobby or craft store and pick up some sanding sticks. These things flex beautifully and you can get them to such a fine grit that you can polish glass with them. They are indispensable for doing this sort of work.
Take your time and don't expect to get it done in one shot. There may still be a mark there but most people that don't know where to look will not be able to pick it out.
cat94 (04-05-2017)
Old 04-05-2017, 05:30 PM   #24
cat94
Drives: '17 86
Wow, I didn't even know those existed. I was thinking of maybe wrapping some sandpaper around a sponge, but those look much easier to work with, especially in small areas.
I'll do my best not to rush - expecting it to take about a week of applying layers, maybe even more.
I saw in this video that mixing the clearcoat and base coat makes it much easier to apply, but given that I'll be getting 3 coats from the dealership, I'm not sure if this will work well. I'll probably end up doing one scratch at a time and using what I learn to tackle the next area.
[ame="https://www.youtube.com/watch?v=6xi3xmeO6C4"]Paint Chip Touch-up -- /DRIVE CLEAN - YouTube[/ame]
Old 04-05-2017, 05:41 PM   #25
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I used to work at a body shop, and I have never seen brushed on paint look as good as sprayed paint. EVER!
Tape off the small chip/scratch and spray some color in the area. Adhesion promoter, color, clear, buff carefully.
A great place to get auto paint from (in spray cans) http://www.automotivetouchup.com/index.htm
I LIKE TIRES!
The Following 2 Users Say Thank You to Leonardo For This Useful Post:
cat94 (04-05-2017), VIP BRZ (04-05-2017)
Old 04-05-2017, 06:36 PM   #26
No don't mix the clear and base. You will end up with a sticky mess.
Agreed in bigger areas but small chips and scraps can indeed be filled with reasonable success. Spray is perfect for a flat surface but doesn't fill chips well. It takes some work but can indeed be done. About 80% of my attempts have been good enough that people can't see unless I point it out. I don't like to talk about the other 20% though.
cat94 (04-05-2017)
Old 04-05-2017, 07:35 PM   #27
cat94
Drives: '17 86
I'll give it a go with some model brush first since the scratches are all on corners and under 1cm in width. If this turns out terribly, then I may opt for a spray method.
Nice to know where I can get color matched spray paint though.
Headers touching skid plate Carnewbee Engine, Exhaust, Transmission 5 11-21-2015 02:17 PM
Almost Touching... Pillar!!! Choco BRZ First-Gen (2012+) — General Topics 26 06-26-2015 04:17 PM
Hid wiring touching supercharger tubes any issues? Frs32907 Cosmetic Modification (Interior/Exterior/Lighting) 1 09-03-2014 02:23 PM
Approach Lighting on BRZ LTD racecaresuaceb BRZ First-Gen (2012+) — General Topics 3 04-10-2013 03:13 AM
A different approach to the ARMREST Sportsguy83 Interior Parts (Incl. Lighting) 91 02-19-2013 11:53 PM
