Old 04-03-2017, 07:55 PM   #1
tato.valverde
tato.valverde's Avatar
Drives: Scion FRS RS1.0,Mazda MX-6 2.5i 4WS
DIY - Push to Start button relocation
Hello! Another fun DIY coming your way.
I decided to install PBM's hydro ebrake, which is neatly hidden under the center console. However, the lever comes in through the spot where the Push to Start button is on Master Race cars, so I decided to relocate it.
First I wanted to relocate it to the steering column, where the keyhole for the Peasant Mobiles is, but there is barely any space behind the plastic trim:
The Push to Start unit is extremely long, so that made it tricky to find a place.
Then I decided to put it next to the tachometer, since there is plenty of space behind it. All you need to do is cut the plastic holding the wires from the smart key sensor and the Push to Start together in a harness, so that you can separate both of them, and then tape them separately (see poor picture with yellow tape making 2 different harnesses #colormatchallthethings)
Then disassemble the interior trims around the tachometer, cut a big enough hole in the plastic behind it to be able to slide the long unit at an angle (since making the tabs line up will require you to insert it at an angle) and then cut a perfectly sized hole in the actual plastic trim.
Glue the unit in place with hot glue, making sure to make it flush with the upper portion (the plastic trim is rounded, so one side will have to not be flush... no one will look from under it, so make it that one) and re-assemble!
As always, I hope that helps!!
tato.valverde is offline   Reply With Quote
hydro, push, push to start, relocation, start
Push Button start... usptwins DIY (Do-It-Yourself) Guides 155 07-31-2019 11:10 AM
STI Push Button Start faltyda Interior Parts (Incl. Lighting) 2 07-29-2016 01:41 PM
WTB: STI push button start SPCorBUST Want-To-Buy Requests 0 01-18-2016 03:45 AM
STI Push Start Button shanx Want-To-Buy Requests 5 12-30-2015 10:11 PM
Battery dies, push start car in gear.... push start button rhythmM Scion FR-S / Toyota 86 GT86 General Forum 7 02-27-2014 06:06 PM
