#15 |
Drives: toyota 86 gt 2012 manual
Thanks for the replies everyone.
Yea I am trying to remember if the turning circle had actually changed but I think it could just be a maybe its slightly more sensitive with the new harder tyres, but I seem to remember I was able to get it to turn a lot quicker and point it when I wanted it to go alot easier before the new tyres and "alignments". The steering angle is definitely off centre. I have to keep it above 3-4 degrees to the right to keep it heading straight otherwise when I straighten out the wheel its slowly veers off to the left. I am hoping toyota can sort it out once and for all cause all I have is the handling in my otherwise stock car ![]() Might have to pay again for stock tyres if I aint happy once toyota have a look at it
#16 | |
Ie front toe R = 0.3 but says -2.1 etc |
#17 |
Drives: 2017 BRZ
Turn the steering wheel and they will be. Left went from 0.2 to 2.5, turn it -2.3 and you'll now have r0.2, l0.2, and 0.1 difference is easily rounding.
#18 |
Drives: 2013 Subaru BRZ
Front toe always equalizes as you drive, if the left and right toe adjustments are different the steering where ends up off centre. That's why they need to be very close to,equal on the rack with the steering wheel centered.
Different rear toe generates side thrust because the wheels are fixed. Different camber generates side thrust. My money is on a new defective tire being the cause of your problems. It happens. |
| "Edit Post" Has Nothing In It! | DaJo | Site Announcements / Questions / Issues | 25 | 01-09-2016 03:11 PM |
| Anyone have experiences/stories related to "get outta ticket" license plate frames? | Shindig | Northern California | 5 | 04-17-2014 09:06 PM |
| Getting new 16" wheels with winters, do I need to do wheel alignment? | amram | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 13 | 12-23-2013 01:17 PM |
| If you want to PURCHASE an 18" S7 wheel post here. | Memphis | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 05-31-2012 03:49 PM |
