Old 04-03-2017, 01:55 AM   #1
pinetree
pinetree's Avatar
Drives: 2013 BRZ Limited
Clutch replacement
Hi,
Having my clutch replaced later this week after having issues with the throw out bearing, and reading through the forums still can't decide which route to go.
Have a BRZ '13, with about 70k miles. Car is N/A, headers, exhaust, intake, tune (OFT). Not sure what power car is pulling, but guessing not much from stock.
Option 1: OEM clutch, stock flywheel resurfaced
Option 2: Exedy stage 1, stock flywheel resurfaced
Option 3: ACT HD street clutch, lighter flywheel
Option 4: Something else?
Help me decide! Car is daily driver, with maybe a few canyon runs a year. Also, it looks like the consensus is to get the Velox clutch fork as well, even with my application is it worth it?
Any advice with this is much appreciated, need all the help I can get. Thanks!
pinetree is offline   Reply With Quote
Old 04-03-2017, 02:20 AM   #2
dhuang
Cannonball Record Guy
dhuang's Avatar
Drives: Series.Yellow, 4C, Fit
I went option 3 with the Streetlite flywheel. Also went ahead with the Velox clutch fork and pivot while the transmission was opened up.
My impressions after 3k miles: I'm still getting used to the clutch, it grabs pretty hard which combined with the lightened flywheel makes taking off from a stop tricky for me. I have to rev a bit higher to get her going. Also, consider how much stop-and-go traffic you endure. Sometimes I wish I had the stock setup since it was so easy to drive in stop-and-go traffic.
dhuang is offline   Reply With Quote
The Following User Says Thank You to dhuang For This Useful Post:
pinetree (04-03-2017)
Old 04-03-2017, 02:33 AM   #3
pinetree
pinetree's Avatar
Good to know, was debating the pros/cons of lighter flywheels. Since this is my DD it seems stock is better (Unless someone else chimes in). Now to decide if going stage 1 is worth it or just going OEM.
Thanks!
Old 04-03-2017, 02:36 AM   #4
swarb
Exedy makes the oem clutch, so they are the same except the markup.
The Following User Says Thank You to swarb For This Useful Post:
Old 04-03-2017, 02:45 AM   #5
pinetree
pinetree's Avatar
Yeah, was aware Exedy made the OEM parts, just wondering if the upgrade to stage 1 is worth it or not.
Thanks!
Old 04-03-2017, 10:42 AM   #6
I'd suggest you go with option #1.
If the clutch fork looks OK, why replace it (assuming you're putting back a OEM clutch and flywheel).
Old 04-03-2017, 11:31 AM   #7
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
My FR-S is just under 60k miles right now and I'm in the exact same situation. My throwout bearing has been making a grinding sound whenever I depress the clutch pedal. Tried to get Toyota to fix it under warranty, but they said clutches aren't covered. I'm torn between the Exedy OEM and Stage 1 clutch kits right now. I often run an E85 Stage 2 tune, so wonder if the extra torque warrants a stronger clutch or not?
smg1138 is offline   Reply With Quote
Old 04-03-2017, 11:36 AM   #8
Cockatoo
TALLY FT86
Cockatoo's Avatar
Drives: 2014 FR-S Monogram -- SBD Turbo --
If you are NA you dont need a stronger clutch... get OEM replacement and call it a day.
Cockatoo is offline   Reply With Quote
The Following 6 Users Say Thank You to Cockatoo For This Useful Post:
ajcarson11 (04-04-2017), fika84 (04-03-2017), humfrz (04-03-2017), pinetree (04-03-2017), smg1138 (04-03-2017), Swisher Seattle (09-26-2022)
Old 04-03-2017, 12:27 PM   #9
pinetree
pinetree's Avatar
Exactly, seems even with slight increase in power/torque with bolt on parts and tune, OEM seems to handle the job which is great.
However, does stage 1 have its merits and worthy upgrade or pointless unless you go boosted?
Been reading the forums all night, still can't decide lol
Old 04-03-2017, 12:33 PM   #10
churchx
churchx's Avatar
Drives: 2014 GT86
Unless it's this NA
Old 04-03-2017, 01:17 PM   #11
pinetree
pinetree's Avatar
Originally Posted by churchx View Post
Unless it's this NA
I think we wish we all had that engine...lol
Old 04-03-2017, 01:38 PM   #12
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
If you're not going to clutch kick all day (i.e. drifting), OEM is plenty fine for your needs.
Clutch fork is only a need if you have upgraded pressure plate.
Old 04-03-2017, 01:55 PM   #13
smg1138
smg1138's Avatar
Anybody know if the throwout bearing is the same between the Exedy OEM and Stage 1 kits? I seem to remember reading somewhere the Stage 1 had a higher quality bearing. Dropping the transmission is going to be a PITA, so I don't want to do this again for a long time.
Old 04-03-2017, 02:38 PM   #14
Cockatoo
TALLY FT86
Cockatoo's Avatar
Unless it's this NA
That thing actually only makes 197lb ft torque... OEM could handle it no problem...
Surprisingly, I'm boosted with almost 240wtq and my low miles OEM clutch is doing fine... wont last forever obviously
The Following 2 Users Say Thank You to Cockatoo For This Useful Post:
Tcoat (04-03-2017), Ultramaroon (04-03-2017)
DIY Clutch Replacement Supermassive DIY (Do-It-Yourself) Guides 217 08-27-2023 12:35 PM
Exedy OE replacement clutch. APEXIT53 Transmission and Driveline 2 04-08-2017 08:54 AM
clutch helper spring replacement. another way Sandy AUSTRALIA 5 08-02-2015 04:32 PM
Clutch replacement Thatguyjeremy Engine, Exhaust, Transmission 0 02-28-2015 04:22 AM
Clutch/flywheel replacement? bucket BRZ First-Gen (2012+) — General Topics 1 11-19-2012 12:25 PM
