Old 03-31-2017, 11:01 AM   #15
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
I would get grade 8. You probably won't find them at your average hardware store. You'll probably have to order them from Mr. Metric or other.
wulfstan (03-31-2017)
Old 03-31-2017, 11:03 AM   #16
wulfstan
Drives: 2014 Whiteout Monogram 6MT FR-S
Originally Posted by stevesnj View Post
Here's the English(sorta) install instructions
or just buy these bolts
D40 is a washer
Or get the part numbers off the bags
I do not have the bolts hence I do not have the bags, I was hoping someone who had this part kept their bags or recorded the part numbers or listing for future reference.
wulfstan is offline   Reply With Quote
Old 03-31-2017, 11:05 AM   #17
wulfstan
Order one bolt you have the number for and look at the head for the grade then pick up the rest.
That is an excellent idea, thank you!!! That would work I will do this in the meantime... I am hoping someone was anal retentive enough like me to have recorded the bolt part numbers for future reference...
wulfstan
The Following User Says Thank You to wulfstan For This Useful Post:
stevesnj (03-31-2017)
Old 03-31-2017, 11:07 AM   #18
stevesnj
stevesnj's Avatar
The part numbers are on the bags in the pic.
My 2016 Build thread
The Following User Says Thank You to stevesnj For This Useful Post:
Old 03-31-2017, 11:16 AM   #19
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
I don't see why the "grade" of bolt would make much difference. Heck, they are just holding on a simple brace ......
@Tcoat may disagree .....
And of cuz my last German car the factory got the bolt specs wrong on the front subframe which almost fell off my car after a few years where some of the bolts could be loosen by hand.
krayzie is offline   Reply With Quote
Old 03-31-2017, 11:18 AM   #20
wulfstan
Yes, 3 sets of bolt part numbers are there and I can order those, but I still don't have the part numbers for the other 3 sets. If you can make out the part number upside down on the top left and also of the bags underneath the right bolts, please let me know. I can't make them out.
wulfstan
Old 03-31-2017, 11:43 AM   #21
Getting too high a grade can be as bad as or worse than getting too low. Odds are that they are just ordinary, everyday, bolts but if he is concerned then he should get the right ones even if just for peace of mind.
Old 03-31-2017, 11:44 AM   #22
Of course, this is coming from the kid that used a case hardened bolt as a "shear" bolt on the fly wheel in my fathers hay bailer and wrecked it up (yep, I've already told that story).
I don't disagree. I would just grab some mid range bolts and call it a day if it was me.
humfrz (03-31-2017), wulfstan (03-31-2017)
Old 03-31-2017, 11:49 AM   #23
Sapphireho
Famous Potatoes
Sapphireho's Avatar
I'm sure they would be the same grade as the ones currently in the car.
Old 03-31-2017, 12:03 PM   #24
That would make way to much sense!
Old 03-31-2017, 12:26 PM   #25
Speaking of making sense ...... it seems to me that some folks are dead set on nailing down the drivetrain, suspension and frame on this car so tight, that the car would feel like riding on an empty, steel wheeled, hay wagon on a washboard gravel lane .......
Tcoat (03-31-2017)
Old 03-31-2017, 12:34 PM   #26
Just need to do what I did when the springs and shocks on my wife's 76 Pacer broke and blew.
Jack it up.
U bolt a chunk of 4 x 4 on either side of the diff.
Lower onto wood.
Rode like an old hay wagon but was nice and firm. The drive shaft eventually fell out because there was no flex but you can't have everything.
Old 03-31-2017, 01:31 PM   #27
wulfstan
Oh, special, just want to use the bolts that would have come in the set. Only other recourse would be to buy a new set, get the part numbers, resell the new set as brand new un-installed. But probably take a loss because seems like no one wants these bars... Oh, and just checked japanparts, it's around 457.23 + shipping for a new set...
Jack it up.
Lower onto wood.
Old 03-31-2017, 01:34 PM   #28
driftartist
Kurenai Samurai
driftartist's Avatar
Drives: Red and manual
You can find grade 8 at orchard supply hardware. I used to work at osh. but if osh has them you can for sure find them at home depot or lowes ace etc. hope this helps.
driftartist is offline   Reply With Quote
Part numbers or part diagram? pacemkr Engine, Exhaust, Transmission 6 08-22-2016 01:44 PM
OEM part numbers nikitopo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 12-29-2014 12:59 PM
Borla UEL flange, more in common with a pretzel then a flange. Adeets Engine, Exhaust, Transmission 13 04-12-2013 05:38 PM
How do I get JDM part numbers? InstantNoodles Cosmetic Modification (Interior/Exterior/Lighting) 2 07-09-2012 04:29 PM
part numbers Staticfrost BRZ First-Gen (2012+) — General Topics 5 05-29-2012 12:02 PM
