Old 03-30-2017, 03:19 PM   #1
BFIFE22
BFIFE22's Avatar
Drives: 2013 GBS BRZ Limited
Marks on Rotors
Yesterday I just gave my car a rinse to get rid of the pollen on it, parked the car and didn't drive it for the rest of the day. When I went to work this morning, when I first started backing out of my garage I heard/felt a clunk from mostly the rear. My brakes were also making rubbing/grinding noises when the pedal was pressed on the way to work.
Now I know when rotors get wet they develop surface rust, but I've never experienced it like that before. It rained today while at work, and they made the same noise on the way back. Anyways, once I got home from work I took a look at my rotors and found this:
Each rotor has a spot like this on them where you can see a mark left by the pads. Anyone know if this will wear off or are my rotors fubared? I'm not terribly familiar with brakes
APEXi / JDL / Perrin / Grimmspeed / Tein / Hotchkis / TRD / RAYS / Michelin / Raceseng / JPM Coachworks / SWEIDIT / Carsmo / TOM's / OFT / OEM Audio
BFIFE22 is offline   Reply With Quote
Old 03-30-2017, 03:45 PM   #2
It will wear off I am sure but in many years of rotor manufacturing and seeing 100s of warranty returns I have never seen anything like that before.
How far did you drive after the rain?
Old 03-30-2017, 03:51 PM   #3
BFIFE22
BFIFE22's Avatar
I live about 7 minutes from work so not far. I've only had these pads for 2 months but they've never given me any issues whatsoever before. Maybe enough surface rust on the rotor to make contact with the pad surface?
Braking feels completely normal minus a tiny bit of a gravely feeling, although the road I drive on is fairly rough and could be my mind overanalyzing.
Old 03-30-2017, 04:09 PM   #4
Ya surface rust means nothing and will not be an issue. I find the difference in the surface between the mark and the rest of the rotor interesting though. Seen lots of pad marks before but they usually disappear after just a couple of applications of the brakes. I will show that to one of the quality guys tomorrow and see what he says. Could be perfectly normal and I have just missed seeing it. As long as they are working OK I wouldn't worry about them.
~el~jefe~ (03-31-2017)
Old 03-30-2017, 08:04 PM   #5
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Looks rather like it sat in one place for several days in a row getting wet and drying out for a number of cycles.
Do you park near any sprinklers?
Old 03-30-2017, 10:20 PM   #6
BFIFE22
BFIFE22's Avatar
Thanks, I'm interested to see what he says!
Not near any sprinklers, but it sat for probably 16 hours right after getting a quick rinse.
Old 03-31-2017, 01:10 AM   #7
Legionsk88
Legionsk88's Avatar
Drives: 2015 WRB Limited BRZ
I had the same exact thing happen to mine after i washed my car, went away after some miles
Legionsk88 is offline   Reply With Quote
Old 03-31-2017, 02:28 AM   #8
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
you need to brake harder.
I'm not kidding. Things like this stay around when you use the brakes lightly.
The Following 4 Users Say Thank You to mav1178 For This Useful Post:
JD001 (03-31-2017), Tcoat (03-31-2017), Ultramaroon (03-31-2017)
Old 03-31-2017, 05:41 AM   #9
Spec C Wannabe
Drives: 2017 WRB M/T BRZ
7 minutes of driving is not sufficient distance to rub off that brake pad mark.
Put something heavy in the trunk and drive longer faster harder. I am sure those pad marks will be rubbed off.
Always drive your car around right after finishing the wash to avoid this problem, along with other moisture collection in the hidden area.
Spec C Wannabe is offline   Reply With Quote
Old 03-31-2017, 11:12 AM   #10
thomasmryan
thomasmryan's Avatar
Drives: hyper blue
Drive your car after you wash it to dry the water off the rotors.
thomasmryan is offline   Reply With Quote
Old 03-31-2017, 12:02 PM   #11
OK so I talked to our engineers and as everybody has said it is normal pad marks from being wet. They were also baffled at first since the pics seemed to show excessive pitting and different wear marks than the rest of the rotor. We threw the pic up on a different computer and the marks don't look near as bad as they did on my monitor.
Give it a good drive and some moderate brake pressure and all is good.
Teseo (03-31-2017), ~el~jefe~ (03-31-2017)
Old 03-31-2017, 03:04 PM   #12
mav1178
mav1178's Avatar
This is similar to people that bed brake pads. Two types of people:
1) those that "brake hard" and complain about noise, lack of bite, or something else.
2) those that know how to bed brakes, and make the pads smoke when they are first bedded.
By "braking hard" I really mean you need to find an empty stretch of road and do a complete full stop from around 50MPH so you can get enough rotations on the rotor in with full pressure contact on the pads.
Old 03-31-2017, 04:06 PM   #13
BFIFE22
BFIFE22's Avatar
Good to know! I'm gonna basically do a bedding procedure later today and see if it helps get some of it off. Thanks!!
Old 03-31-2017, 08:13 PM   #14
mrk1
Drives: Sterling BRZ Ltd
Pad marks from sitting wet, normal.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Weird paint marks UNCC_BRZ Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 7 10-11-2016 01:54 PM
Marks on Glass VMRamos Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 16 11-04-2015 10:35 PM
Help on Swirl marks on my new FRS xcooperx Southern California 9 02-10-2015 05:36 PM
Marks on car ID86 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 34 12-26-2013 10:43 AM
swirl marks jarviz Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 31 07-12-2012 08:33 AM
