| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: 2016 FRS
TPMS Disable?
I changed my rims and tires and don't have tpms valves in the new ones. Is there a way to disable it so I don't have to start at the time low icon all the time? I do have techstream software and cable but haven't seen anything in there. Anyone know?
#2 |
Should be there someplace in Techstream. My light is on 5 months f the year but after the first couple of days I don't even notice it anymore.
#4 |
But then when I do put the summers back on then every time I start the car I wonder what is missing.
| The Following User Says Thank You to Tcoat For This Useful Post: | korhun (11-04-2019) |
#5 |
Drives: 13 SWP BRZ Prem
There is no way to disable the TPMS system (At least not through techstream).
This is the best you can do: http://www.ft86club.com/forums/showthread.php?t=7827 Edit: Or purchase another set swap the TPMS IDs back and forth when you change sets.
JDL UEL Headers, Nameless Res&Cat Over&Front, Invidia Q300 Catback, AVO Dry Panel Filter, Custom ECUTek Tune by DriftOffice 191WHP/151 ft-lb on 92 |
#6 |
Drives: Asphalt 2015 FRS
TPMS cannot be disabled as it is required to be installed in all new cars by law.
Build Thread: http://www.ft86club.com/forums/showthread.php?t=101096
#7 |
FYI, rockauto has them for about 40 bucks a corner for OE Denso sensors.
http://www.rockauto.com/en/moreinfo....1504002&jsn=12
#8 | |
Drives: 2013 Scion FRS & 2022 GR86
2013 SCION FRS (Argento) Instagram: @theunforgottenfrs
2013 Scion FRS 2022 Toyota GR86 |
#9 | |
| How to disable DRL in FRS | whitefrs | Cosmetic Modification (Interior/Exterior/Lighting) | 12 | 12-13-2016 02:11 PM |
| how to disable drl ? | Ardenyo2k13 | Scion FR-S / Toyota 86 GT86 General Forum | 55 | 05-03-2016 09:38 PM |
| NEED HELP!! TPMS light on. with TPMS installed on aftermarket rims+tires | Figo | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 09-23-2013 08:11 AM |
| Changed to new wheels w/o TPMS, car still thinks I have TPMS sensors? | Ahz | Issues | Warranty | Recalls / TSB | 9 | 11-06-2012 08:25 AM |
| Is there a way to disable the immobilizer? | schtebie | Issues | Warranty | Recalls / TSB | 5 | 09-22-2012 06:09 PM |
