#3109 | |
Springs that are too soft will be on the bumpstops in the corner and make the problem worse. A swaybar that's too small without firm springs to make up for it will lead to the same problem. - Andrew |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | driggity (03-25-2017) |
#3110 |
I have RCE T2, currently on stock tophats. Looking to upgrade. I care about performance more than "street car" things. I look at most available options, most move the mounting point lower than the OEM location, so you would need to compress everything further to maintain ride height. My car is by no means "slammed".
Is the travel impact too great, or do I need to look into things like ground control camber plates to help with travel? Other options? Last edited by ka-t_240; 03-25-2017 at 10:06 PM. |
#3111 | |
Drives: 2017 BRZ
#3112 | |
Drives: FR-S Whiteout
These do the same thing in a cheaper, and much less aesthetic fashion. I recall reading that the HVT stuff is discontinued, not sure how much of that is true.
Intent > Content
cowardice is the mother of cruelty. |
#3113 |
I thought the HVTs were discontinued.
Velox has a similar set. And of course we've had our RCE forged lowering camber plates that we came out with about a decade ago, but we consistently have supply problems. If you want them, give us a call and be prepared to wait. Otherwise we have our more simple street plates that are a low stack height but do add a tiny bit of height. - Andrew |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | cjd (03-27-2017) |
#3114 |
I guess they are discontinued. Says "This item is currently out of stock!" Did not see that earlier.
Intent > Content
#3115 |
Drives: 2013 Scion FR-S 10-Series
No reply?
#3116 |
#3117 |
Even with height adjustment being independant from coil spring adjustment on a coilover, would I still need a new alignment when adjusting right height?
Sent from my 2PQ93 using Tapatalk
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
#3118 |
#3119 |
car geeks
Drives: 2017 BRZ Limited PP
I just purchase a 2017 BRZ with the performance package. Normally I'd go right for coilovers, but the Sachs dampers make me hesitate and wonder if a decent linear spring matched well with the dampening of the Sachs unit may not be an 'adequate' solution while I address other higher-need areas of car (i.e., the powerband).
For 2017, Subaru also softened the rear a bit while stiffening the front, presumably for better turn-in and stability near and at the limits. Not sure how the Sachs compare to standard shocks, so it's hard to know how to pair them with springs, and obviously it all boils down to what you want and what you're willing to sacrifice to get it. Soooooo, my questions I guess are: 1. Would a drop of around 25mm/1" limit suspension travel 'too much'? That is, hitting bumpstops during at-limit driving, for example? This is a second car that will mainly be driven on street, but I'm also building it for weekend hot-lapping; it's not a track-only car, but I'm willing to tolerate a harsh-ish ride. I drove a 2017 GT86 with the TRD suspension and loved it. Other car is an Integra GS-R with Koni Yellows and Ground Control coilovers. 2. Should I give the Sachs dampers a chance with something like a RS*R or Hotchkis spring, or skip right to coilovers? 3. If I /did/ want to experiment with the Sachs/aftermarket spring combo, what would you recommend? I plan on using crash-bolts for front camber to see what I can get from then, then go from there. |
#3120 | ||
Drives: '97 NSX-T, '18 Type R
#3121 |
car geeks
Whoops. Clearly my search skills are lacking. Thank you.
#3122 |
Drives: 2015 Scion FRS - Raven
How much lead time, where would I have to shop them and what is the rough cost of having my KW Clubsport 3 ways rebuilt when the time comes?
| Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 03:17 PM |
| RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 05:31 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 08:15 AM |
| 2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 06:19 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 10:13 AM |
