Old 03-27-2017, 07:55 AM   #15
Aboodilatif
Aboodilatif's Avatar
Drives: '14 Red Toyota GT86 RocketBunny
Just an opinion on this.
Since the tachometer on the car communicates using CAN signals, and all the relevant systems in the car send CAN signals, shouldn't it actually be a plug and play and the display would stay on the default out of the box setting without the steering wheel to control it.? the only issue i can think of is the ECU not being able to communicate, here's a quote by steve99 from the other thread
I know 100% that the earlier ECU calibration will not run on 2017 cars and causes secutity imobiliser system to lock out and need reset procedure.
so I suspect that the 2017 ecu calibration will not run with older security system.
'14 Toyota GT86 - 2JZ GTE - R154 - GTX3582R 1.06 - Motec M130 PNP - RocketBunny v1
'09 Audi RS6 C6 - MTM 850HP
Aboodilatif is offline   Reply With Quote
Old 03-28-2017, 09:37 PM   #16
GT/86
I LOVE YOUR GT86
GT/86's Avatar
Drives: 2017 BRZ with PP 1982 Datsun210
Originally Posted by Pyrefyre View Post
That is the worst way for those of us that have done performance enhancements.
Yes you are 100% Correct
GT/86 is offline   Reply With Quote
Old 09-23-2017, 03:19 AM   #17
jorgerendonjr
Drives: Frs
Bump
jorgerendonjr is offline   Reply With Quote
Old 09-23-2017, 05:58 AM   #18
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
You can't even swap the old gauge to a different car.... pre facelift model gauge swap involves getting dealer to get a code from subaru to swap for you....... why do you think the new one with all digital stuff will be easier.
Figure most guys that actually know about this just assume it's pretty expensive hence nobody posted about it?
But please do try and let us know the result.
*To be honest i just wanna know if the older car can get the new track mode. lol
The Following User Says Thank You to chaoskaze For This Useful Post:
funwheeldrive (11-08-2017)
Old 10-23-2017, 03:36 AM   #19
jorgerendonjr
Drives: Frs
Bump
Old 11-05-2017, 09:37 AM   #20
jorgerendonjr
Drives: Frs
Bump?
Old 11-08-2017, 12:49 AM   #21
jorgerendonjr
Drives: Frs
Bump!
Old 01-07-2018, 04:01 AM   #22
brentjones518
brentjones518's Avatar
Drives: 2013 White brz Limited.
I’d like to confirm. I swapped the gauge cluster and steering wheel with clock spring. Still need dash harness to make this work but so far gauges work fine. I just can’t change screens on gauge lcd till I pin the wires in or get the dash harness. They changed clock spring and also the clock spring connector from a 12pin to a 14pin. Parts from a 2017 Limited brz and I own a 2013 Limited brz.
brentjones518 is offline   Reply With Quote
The Following 5 Users Say Thank You to brentjones518 For This Useful Post:
derpz86 (02-26-2018), DustinS (03-05-2018), jorgerendonjr (01-07-2018), Sportsguy83 (07-17-2018), zc06_kisstherain (03-01-2018)
Old 01-07-2018, 04:43 AM   #23
jorgerendonjr
Drives: Frs
Pmd
Old 02-19-2018, 02:14 PM   #24
shadowsnkx
Drives: 2015 BRZ
parts
Please let us know when you get it worked out. Many of us would do this swap as well.
shadowsnkx is offline   Reply With Quote
Old 02-26-2018, 08:54 PM   #25
derpz86
Drives: 2015 Scion FR-S RS1.0 #507
Would love a full part list and write up if you got it in ya.
Sent from my Mi MIX 2 using Tapatalk
derpz86 is offline   Reply With Quote
Old 03-16-2018, 01:44 PM   #26
shadowsnkx
Drives: 2015 BRZ
Originally Posted by jorgerendonjr View Post
Pmd
did you get a parts list or reply from him?
Old 03-16-2018, 09:37 PM   #27
shaynek
shaynek's Avatar
Drives: BRZ Limited; GR86
pm'd him as well but never got a reply
shaynek is offline   Reply With Quote
Old 07-17-2018, 03:11 PM   #28
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Any more info on this?
2017 Limited Gauge Cluster halleffect Electronics | Audio | NAV | Infotainment 26 10-22-2020 07:32 PM
2017 BRZ limited wheels are Not Black. ~el~jefe~ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 37 07-30-2017 12:15 PM
2017 Limited Gauge Cluster halleffect Cosmetic Modification (Interior/Exterior/Lighting) 0 01-16-2017 03:55 AM
2017 BRZ Limited Spoiler Chayce808 Cosmetic Modification (Interior/Exterior/Lighting) 6 01-04-2017 12:49 AM
2017 Subaru WRX STI, STI Limited, WRX, WRX Limited, WRX Premium mark0006 Other Vehicles & General Automotive Discussions 0 10-27-2016 06:22 PM
