CANADA Canada
Old 03-23-2017, 06:43 PM   #1
allowe
allowe's Avatar
Turbo kit legality
I know people will say "look on google" but if you can link me to the website that says "forced induction" is illegal, I'd greatly appreciate that.
I knew someone who ran an SBD kit and said it wasn't. I know someone with a ek civic saying the same thing but I've heard from others that you will get your car impounded if you have a turbo kit.
Can anyone confirm this ?
Thanks for reading my post!
Edit: especially for Ontario
allowe is offline   Reply With Quote
Old 03-23-2017, 07:00 PM   #2
brzzy
@anthonysestito
brzzy's Avatar
Drives: 2013 Sterling Silver Metallic BRZ
Turbo kit legality
Is this post real?
There are tonnes of production cars on the road with turbos from factory. A bolt on aftermarket turbo kit is not illegal, however some (almost all) aftermarket products are rated for "off road use only" and they should/will say so in their respective manuals. In which case, yes, they are "illegal" however I'd be hard pressed to think of any situation within my knowledge of someone having to prove that roadside to any form of law enforcement.
Now, how you use said turbo is different.
But I think someone is pulling your leg about FI being "illegal".
2013 BRZ LIMITED STERLING SILVER METALLIC
IG: @ANTHONYSESTITO
brzzy is offline   Reply With Quote
Old 03-23-2017, 07:10 PM   #3
allowe
allowe's Avatar
I heard manufacturers turbo kits are legal but aftermarket turbo kits use either illegal piping or something that isn't legal. I'm Guna message SPeed by design and ask if they're legal on Canadian roads and post the answer here.
Old 03-23-2017, 07:28 PM   #4
pushrod
Benched 86lb
pushrod's Avatar
Drives: Ultramarine FR-S
You are not allowed to remove or modify emissions equipment. Avoid that and you should be in business.
pushrod is offline   Reply With Quote
The Following 3 Users Say Thank You to pushrod For This Useful Post:
allowe (03-23-2017), Tcoat (03-27-2017), wparsons (03-23-2017)
Old 03-23-2017, 07:28 PM   #5
daskaman
Drives: Burz
Anything is legal as long as you can pass safety, emissions and properly insure it (tell them if a car is heavily modded).
Thats it. Only nitrous is illegal so much as you can not be capable of turning on the tanks from the drivers seat to my knowledge.
daskaman is offline   Reply With Quote
The Following User Says Thank You to daskaman For This Useful Post:
allowe (03-23-2017)
Old 03-23-2017, 07:33 PM   #6
allowe
allowe's Avatar
Emissions equipment ? Such as? Wouldn't an exhaust count as an emissions equipment?
Old 03-23-2017, 07:40 PM   #7
daskaman
Drives: Burz
From the Highway Traffic Act
"Emission Control Systems or Devices
6.1  The following types of systems and devices are prescribed for the purpose of subsection 22 (4) of the Act:
1. A system or device that is manufactured by the manufacturer of the system or device that is being replaced and,
i. is identical to or equivalent to the system or device that is being replaced, or
ii. is manufactured as a replacement for the system or device that is being replaced."
Essentially this means that unless declared and classified as a "hot rod" (engine conversion mostly) in theory your emission equipment must work as well as factory. Specifically catalytic converters and possibly EGR valves and Air Pumps if applicable. Mufflers and resonators do nothing for emissions, only noise
Currently you can pass a vehicle with zero emission equipment at all as long as your car is coded with dummy signals from emission equipment and they don't perform a visual inspection
allowe (03-23-2017)
Old 03-23-2017, 07:57 PM   #8
wparsons
wparsons's Avatar
If you want to be actually legal, you'll need a turbo kit that runs the stock exhaust manifold since removing the primary cat falls under the "removing emissions equipment" clause above.
If you want an easier search, look for kits that are CARB legal. You don't need the CARB tune up here, but if the hardware is good for California you'll be fine here.
flickr
allowe (03-24-2017)
Old 03-23-2017, 08:19 PM   #9
swarb
Works turbo kit is the only one that is carb legal.
The problem is with all that heat, canned tune that is probably rich, and the stock catalytic converter, the cats will eventually crumble and send metal shards towards your turbo impeller. But it is legal.
Go for a jackson racing or edelbrock supercharger.
The Following 2 Users Say Thank You to swarb For This Useful Post:
allowe (03-24-2017), wparsons (03-29-2017)
Old 03-24-2017, 02:41 AM   #10
allowe
allowe's Avatar
Thank you all for clarifying! What about superchargers? Those don't modify the "emissions" devices or at least I think they don't.
Old 03-25-2017, 12:08 AM   #11
pushrod
Benched 86lb
pushrod's Avatar
A supercharger would definitely be less invasive. Problem with turbos is the whole exhaust situation. A supercharger really only affects the intake side of the deal, and if you get a centrifugal type, even that isn't significant.
My Future Paint and its Legality ztrevs Off-Topic Lounge [WARNING: NO POLITICS] 11 12-04-2016 11:51 PM
Badge conversion legality allowe Scion FR-S / Toyota 86 GT86 General Forum 148 10-19-2016 02:12 PM
TPMS legality in WA Chloroform Northwest 19 09-08-2016 12:19 AM
Lights tips / legality questions Hagfish Cosmetic Modification (Interior/Exterior/Lighting) 5 02-04-2014 01:02 PM
DUI Legality Issues FnFast Off-Topic Lounge [WARNING: NO POLITICS] 8 07-14-2013 08:07 AM
