Old 10-10-2014, 05:41 AM   #1
Kodename47
Kodename47's Avatar
Drives: UK GT86
Kodename47's Tuning Tools
I've had a few PM's so I've decided to add my final tool here.
Disclaimer: I take no responsibility for the tables produced. Please check and confirm all data used within your ROM
I have tried and tested these on my car and they seem to work, although some of it is still in experimental stage like tip in enrichment.
I don't have much time to explain the whole working of this spreadsheet but I think it's fairly self explanatory. Any questions, please ask and I'll answer them.
All error calculations are done by using my Error % column within the log and require only the following fields to be logged:
- AFR (WBO2 Preferred)
- Commanded AFR
- Fuel System Status (OL/CL)
- LTFT
- STFT
Please select whether you log in seconds (s) or milliseconds (ms) in the 1st page. ECUtek is now is seconds so I have confirmed both. If you log in seconds, change the descriptor on the 1st page and it will adjust some of the formulae where required.
Download here: Multi-Calibration Tool - v1.22
Other links:
Knock Correction Tool Thread
OEM MAF Comparison and Smoothing Tool
Ignition Timing Table Comparison and Adjust
MAF Shaping Tool - Credit to 86Inches on Romraider for this one. Added my own touch for users here.
AVCS Comparison Tool
.: Stealth 86 :.
Kodename 47 DJ:
Old 10-12-2014, 04:40 AM   #2
Kodename47
Kodename47's Avatar
Drives: UK GT86
Thanks to @vgi I realised that the error calculation within my spreadsheet doesn't take into account LTFT under OL operation. Typically I don't have LTFTs enabled on my car so I had overlooked this.
Anyway, now sorted and v1.1 Calibration Tool is up
.: Stealth 86 :.
Kodename 47 DJ:
Old 10-13-2014, 04:35 PM   #3
Toyota John
Calle Atun
Drives: 13 FRS, 93 Mr2, 85 ae86
Thanks. I will try the timing spread sheet. I made my own simple sheet but yours looks a little nicer.
Toyota John is offline   Reply With Quote
Old 02-04-2015, 04:12 AM   #4
Kodename47
Kodename47's Avatar
Drives: UK GT86
Calibration tool and Knock comparison tool both have updates.
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-22-2015, 06:17 PM   #5
freerunner
freerunner's Avatar
Drives: GT86
Awesome tool.
Scaled my maf yesterday. Compared to the oem setup, the engine's reactions to pedal changes are perfect now.
Just wanted to leave to leave a 'thank you' here.
freerunner is offline   Reply With Quote
Old 11-12-2015, 03:35 AM   #6
Kodename47
Kodename47's Avatar
Drives: UK GT86
I've gone through and standardized all my spreadsheets and some have some notable updates:
>NEW Multi-Calibration Tool (V1.2)
> DI Calculator V2
> Engine Load Compensation Tool
> Knock Compensation Calculator
> Load Limit Calculator
> MAF Comparison Tool
.: Stealth 86 :.
Kodename 47 DJ:
Old 02-12-2017, 07:12 AM   #7
Kodename47
Kodename47's Avatar
Drives: UK GT86
Updated my Calibration tool to v1.22 - only some minor formula changes.
Added the MAF Shaping Tool to the OP. Credit to 86Inches on Romraider for this one. Added my own touch for users here to make it a bit easier to use. Designed for giving the MAF a true curve, I have used the tool and it works nicely. Here is the original thread on Romraider, users have reported a smoother car due to correct interpolation of the MAF so I recommend giving this a go.
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-23-2017, 03:14 AM   #8
freerunner
freerunner's Avatar
Drives: GT86
Bump.
Can't access the files any more.
Old 03-25-2017, 08:04 PM   #9
Kodename47
Kodename47's Avatar
Drives: UK GT86
Originally Posted by freerunner View Post
Bump.
I've re-shared all my files again on Dropbox. If I've missed any then let me know.
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-26-2017, 09:49 AM   #10
denso
Drives: 86
The Multitool is just a .bin file?
denso is offline   Reply With Quote
Old 03-27-2017, 12:56 PM   #11
Kodename47
Kodename47's Avatar
Drives: UK GT86
It's an Excel file.
.: Stealth 86 :.
Kodename 47 DJ:
Old 05-22-2017, 02:25 PM   #12
Tor
Tor's Avatar
Drives: Toyota GT86
I tried this out today. Zeroed out the IAT compensation, flashed and went for a 1 hour CL focused drive and collected this data. In between, I did 4 WOT pulls.
Stuffed it through VGI's tool (chose the least correction at 2.9v from OL and CL scaling) and put the output unedited into your version of 86Inches smoothing tool.
I attached my excel sheet with my data and wanted to ask, if you have the time, if you would please take a look at it and see if the way I used the tool makes sense?
In the comparison line, I filled in the MAF scaled that I used to collect the data. The result I end up with is very close.
Tor is offline   Reply With Quote
Old 05-23-2017, 03:21 AM   #13
Kodename47
Kodename47's Avatar
Drives: UK GT86
@Tor I have tried to make as few values into the Cal row as possible as this will result in the smoothest of curves.
Try this version. It's slightly updated, I've just pasted your scale in and given it a quick run through. You'll see I've added some new tabs to help see areas of the MAF in detail.
.: Stealth 86 :.
Kodename 47 DJ:
Old 05-23-2017, 05:08 AM   #14
Tor
Tor's Avatar
Drives: Toyota GT86
Thanks a lot. Now I think I understand, it's not the goal to match all cal values to match Smoothed d2M/dV2. But rather to visually get the calculated first derivative line to average the origin line with as few adjustments as possible while keeping it as smooth as possible?
Pulley tool rental? Asian Delight Southern California 0 01-01-2014 01:37 AM
Favorite car tool brillo Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 23 09-18-2013 09:19 AM
What basic tool set to get? ZionsWrath Off-Topic Lounge [WARNING: NO POLITICS] 5 09-05-2013 11:46 AM
pry tool jazztennor Cosmetic Modification (Interior/Exterior/Lighting) 5 12-15-2012 02:02 AM
What does this tool use to carscat Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 06-27-2012 09:24 PM
