Old 03-21-2017, 12:08 AM   #29
FR-Sky
FR-Sky's Avatar
Drives: 2013 FR-S 10 series [755]
I personally like weighted shift because u know our gear box is kinda crunchy and notchy.
It helps me to shift smoothly and effortlessly especially on 1st and 2nd.
I am using 1lb blox.
FR-Sky is offline   Reply With Quote
Old 03-21-2017, 12:19 AM   #30
Exrald
Exrald's Avatar
Drives: 2013 Scion FRS & 2022 GR86
It is crunchy! I was about to buy a short shifter, thinking that it would fix the problem...
2013 SCION FRS (Argento)
2013 Scion FRS
2022 Toyota GR86
Exrald is offline   Reply With Quote
Old 03-21-2017, 12:20 AM   #31
Exrald
Exrald's Avatar
Y thank ya, Exrald ...... but I don't get to many car meets ...... they are usually during my nap time or after my bedtime ......
You're in the car scene humfrz! Sleep is not in our agenda! Lol.
Eat, Meet, Race!
2013 Scion FRS
2022 Toyota GR86
The Following User Says Thank You to Exrald For This Useful Post:
humfrz (03-21-2017)
Old 03-21-2017, 12:55 AM   #32
BFIFE22
BFIFE22's Avatar
Drives: 2013 GBS BRZ Limited
Get a Raceseng shift knob that comes with a delrin cover. I personally use the Orbature and you get the extra weight but the Delrin cover doesn't get nearly as hot or cold as steel. They can be a bit pricey but are the best of both worlds IMO
APEXi / JDL / Perrin / Grimmspeed / Tein / Hotchkis / TRD / RAYS / Michelin / Raceseng / JPM Coachworks / SWEIDIT / Carsmo / TOM's / OFT / OEM Audio
BFIFE22 is offline   Reply With Quote
The Following User Says Thank You to BFIFE22 For This Useful Post:
Exrald (03-21-2017)
Old 03-21-2017, 01:06 AM   #33
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
The Delrin has a nice feel to it.
PetrolioBenzina is offline   Reply With Quote
Old 03-21-2017, 01:50 AM   #34
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
If you want a nice precise and positive shift feel, get a lightweight Delrin knob. If you want less positive feel and an easier shift, get a heavy shift knob. If you want the absolutely most phenominal feeling shift...you get rid of the entire stock shifter assembly and go with this:
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
The Following User Says Thank You to Vracer111 For This Useful Post:
Exrald (03-21-2017)
Old 03-21-2017, 05:55 AM   #35
Exrald
Exrald's Avatar
I've seen this shifter set up before. But I've always wondered how they work, since they only go back and forth... Does it work like paddle shifters?
Instagram: @theunforgottenfrs
2013 Scion FRS
2022 Toyota GR86
Old 03-21-2017, 08:10 AM   #36
15limited
15limited's Avatar
You are thinking of a Sequential transmission, pictured is the CAE Ultra shifter that still uses the traditional H pattern of the transmission.
Sent from my 2PQ93 using Tapatalk
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
Old 03-21-2017, 08:10 AM   #37
dattran86
Driver
Drives: 2013 Whiteout FRS
I had both,
heavier knob = making shifting smooth, but it doesnt have any feel to it, the notchy feeling is gone. numb!
lighter knob = shifting is more precise, notchy and mechanical.
I had a Raceseng slammer (1.25lbs?) vs a genuine TRD Knob (lighter than oem).
Sold the Raceseng and stick with the TRD, however its all personal reference!
dattran86 is offline   Reply With Quote
The Following 2 Users Say Thank You to dattran86 For This Useful Post:
Exrald (03-21-2017), humfrz (03-21-2017)
Old 03-21-2017, 08:13 AM   #38
Bowen
Powered by Crickets
Bowen's Avatar
Drives: 14' SWP MT Limited BRZ
Originally Posted by FuelMode View Post
You clearly are either a troll, or the least knowledgeable person in the world.
He's a well vetted forum member that often times has a sarcastic side.
Nothing he says is intended to be malicious.
Build Thread / OFT Stage 2, Tomei UEL, Perrin Resonated, ST Coils, 2 Sets of Wheels, Rally Armor, TOMS Tails.
Bowen is offline   Reply With Quote
The Following User Says Thank You to Bowen For This Useful Post:
humfrz (03-21-2017)
Old 03-21-2017, 11:24 AM   #39
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
OP,
Did you have a chance to drive your buddy's car with the shift knob installed? If not, you install it in yours, and try it. Only you will know if you like it. If you don't you should be able to sell it without too much trouble. Personally, I installed a Raceseng Topology I bought from a fellow board member in my '15. In my opinion it's one of the best mods I've done. I don't think it removed the feel, just moderated it a bit. The trans can be pretty notchy with the light knob and this offers just the right amount of smoothness - for me.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
The Following User Says Thank You to Capt Spaulding For This Useful Post:
Exrald (03-21-2017)
Old 03-21-2017, 11:27 AM   #40
Exrald
Exrald's Avatar
Originally Posted by Capt Spaulding View Post
OP,
I will do that. Thanks for the tip! I've felt the knob itself. It's heavy for sure, and pure metal. But I haven't shifted with it. I'll try it out on Thursday!
2013 Scion FRS
2022 Toyota GR86
Old 03-21-2017, 01:28 PM   #41
PetrolioBenzina
Drives: 17 86
Any idea what that dash and vent trim is?
Old 03-21-2017, 01:41 PM   #42
Shinchu
Shinchu's Avatar
Drives: 2016 FR-S Asphault MT
looks like spray painted BRZ trim to me.
I have also tried both heavy and light shift knobs (on my s14 and AE86). I prefer the light ones so I can "feel" the gears better, not just destroying synchros I cant feel.
delrin is great since its light, wont heat up and burn your hand.
but that's just my preference.
TEAM HINGA | Shift-Lock.net | Club4AG
http://www.poweredbymax.net/
Shinchu is offline   Reply With Quote
Weighted oem leather shift knob -- any interest?? Superklasse Cosmetic Modification (Interior/Exterior/Lighting) 23 01-09-2017 12:28 AM
Fs: weighted shift knob, red redlined600 Transmission and Driveline 0 11-04-2015 10:59 PM
WTB: Raceseng Slammer / Weighted Shift knob Stealthy Want-To-Buy Requests 4 03-23-2015 03:49 AM
wtb weighted red shift knob. flat486 Want-To-Buy Requests 1 11-05-2014 01:23 AM
weighted shift knob options Reaper Cosmetic Modification (Interior/Exterior/Lighting) 17 07-18-2014 01:07 PM
