Old 02-14-2017, 05:37 PM   #15
cat94
Drives: '17 86
Thanks guys. Setting off actually isn't TOO bad. I'm more concerned with shifting smoothly from 1-2 and 2-3 etc. That's when the car tends to lurch a bit cause I'm not sure at what point to start feeding the throttle in.
I learned on this car and I'm only a couple months in, but what I've realized when driving in normal traffic is 1-2 shift needs rpm to drop a little more than the rest of the gears. Also, if you're not doing a speedy shift, a tiny bit of gas just before you reach the biting point helps keep the rpms exactly where you need for 2-3, 3-4, 4-5. Then throttle on when the clutch is fully engaged. (By a tiny bit I mean literally just resting your foot on the accelerator without any force)
I've contemplated removing the clutch spring, but since the only other mt I've driven was an s2000 for a couple hours, I've got nothing to compare to and the clutch feels perfectly fine to me.
cat94 is offline   Reply With Quote
The Following User Says Thank You to cat94 For This Useful Post:
jcw99 (02-15-2017)
Old 02-15-2017, 08:25 AM   #16
StraightOuttaCanadaEh
Wes
Thanks everyone for the excellent excellent tips. Will keep driving. I'm already feeling more comfortable with it.
Old 03-16-2017, 10:59 AM   #17
LowAndSlowBecauseNoTurbo
FRS 10 series #0239
LowAndSlowBecauseNoTurbo's Avatar
Drives: #0239 FRS 10 series silver ignition
give it gas to about 2k and then let the clutch out slow until it catches and takes the RPM's down when the clutch engages the flywheel. unless you mash your first gear to 30 mph then of course you're going to have to stick your foot in it to match the flywheel speed lol
Drop in K&N filter, CX Racing oil cooler, Tomei Expreme UEL headers, Invidia N1 Catback, OFT stage 2, Raceland coilovers, stage one Exedy clutch kit, Stoptech drilled and slotted rotors and Hawk HPS street pads
10 series #0239
LowAndSlowBecauseNoTurbo is offline   Reply With Quote
Old 03-16-2017, 11:39 AM   #18
Wes
I think 2K is way too high! I set off at 600-800 rpm
Old 03-16-2017, 11:40 AM   #19
Somerandom18
Drives: 2017 manual BRZ
For real. Clutch slip much?
Sent from my Pixel XL using Tapatalk
Somerandom18 is offline   Reply With Quote
Old 03-16-2017, 12:19 PM   #20
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Originally Posted by Strife View Post
In terms of 1st to 2nd to be smooth you want to really take your time. Shifting too early will lead to jerking. I usually try to shift at around 1500rpms for the smoothest transition when driving normally.
1500? Really? Damn.. I always feel like the car is gonna die when I'm around those RPMs. I usually shift around 3-4k RPM for "normal" driving and near redline when im having fun.
2k is a bit high in my opinion too but 600 is pretty low.
Old 03-16-2017, 12:37 PM   #21
FRS 10 series #0239
Well he's getting the hang of things still, I'd say that just so you can control the speed either the clutch until you get the feel of the clutch. I'd rather give too much and slip than to not give enough and stall haha just my opinion though
10 series #0239
Old 03-16-2017, 01:12 PM   #22
PandaSPUR
PandaSPUR's Avatar
Dude saying 2k wasnt the OP, dude surprised at 2k is the OP.
But anyway, I tend to agree, just remember to not "linger" anywhere. Burning clutch smell is not a good time
Old 03-16-2017, 01:17 PM   #23
FRS 10 series #0239
lol I didn't even realize that😂 well I'm also use to launching off the line as well. Spirited daily driving👌🏼
10 series #0239
Old 03-16-2017, 01:51 PM   #24
Wes
yep guilty of that as well.. a lot more fun, needless to say
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post:
Old 03-16-2017, 03:54 PM   #25
ls1ac
ls1ac's Avatar
These little engines LOVE RPM. As an experiment add 1000 rpm to your shift points (after you are going). You might be surprised .
The Following User Says Thank You to ls1ac For This Useful Post:
Old 03-16-2017, 05:08 PM   #26
Strife
Strife's Avatar
Drives: Hyperblue BRZ
My bad, that's when I release the clutch.
Strife is offline   Reply With Quote
Old 03-16-2017, 08:51 PM   #27
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Delete the clutch spring and youll feel it enrage and the numb and dull feeling is gone.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Shifting during Jfheisenberg Engine, Exhaust, Transmission 25 10-09-2015 08:56 PM
shifting into 2nd cantaloupe BRZ First-Gen (2012+) — General Topics 63 06-23-2014 04:47 PM
Shifting into 2nd bpmorgan7 BRZ First-Gen (2012+) — General Topics 31 04-11-2014 04:39 PM
MT Shifting n8dog11914 Engine, Exhaust, Transmission 4 08-28-2012 03:28 PM
shifting and down shifting feel Lowellrenzo Scion FR-S / Toyota 86 GT86 General Forum 23 07-08-2012 05:09 PM
