Old 03-15-2017, 01:05 PM   #1
Da Brz
Drives: 2016 Subaru BRZ
Loud clank when taking off in first
This just happened to me. 24k miles.
I was at a red light. Light turns green, and when I began to let out on the clutch I heard a loud clank. I thought maybe it wasn't in first good enough, so I pushed the clutch back in and pushed the stick forward -- but it was in first as much as a car can be.
Da Brz is offline   Reply With Quote
Old 03-15-2017, 01:06 PM   #2
Not a lot to go on there Da.
Old 03-15-2017, 01:16 PM   #3
Da Brz
You're telling me!
Old 03-15-2017, 01:18 PM   #4
Da Brz
What would you like to know? It's bone stock. I guess I could have added that.
The sound came from the front, possibly around the clutch area. It was a metal-on-metal sound, almost like a high pitched grind, but not really. Hard to describe.
Other than that...?
Old 03-15-2017, 02:38 PM   #5
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Has it happened again since then?
Maybe you just hit something as you started to move :|
Old 03-15-2017, 02:52 PM   #6
This^
Unless it is repeated then there are latterly 10,000 things it could be based on the info at hand.
If the car still runs and moves I wouldn't sweat it unless it happens again.
Old 03-15-2017, 03:44 PM   #7
Did the car stick in place before the clank? (Engine bogs under load but it doesn't move?)
If so, while it was stuck, did it squat at all, or did the engine just bog?
Old 03-15-2017, 04:38 PM   #8
Da Brz
Not sure. It did it as soon as I started letting out and I pushed back in as soon as it did it.
I just thought maybe it was something others had experienced and could chime in. I guess not.
Old 03-15-2017, 06:02 PM   #9
radiocrash
Drives: 2013 FRS
My car did that once but I wasn't in 1st all the way. Hasn't done it since.
radiocrash is offline   Reply With Quote
Old 03-15-2017, 07:30 PM   #10
To build on this ........ sometimes, I'll hit a manhole cover and it will "clank".
Any manhole covers at that intersection .. ??
Old 03-15-2017, 09:35 PM   #11
Every M/T owner has experienced a pop out of gear. Just didn't have it engaged enough. It happens.
perrin catback resonated - loud enough or too loud? theflathead Engine, Exhaust, Transmission 33 01-22-2018 05:46 PM
Clunk/ Clank on Engagement with 2nd and 3rd DaBoBo21 Issues | Warranty | Recalls / TSB 49 03-23-2017 02:14 PM
Automatic Transmission: Loud Clank Moshpit37 Engine, Exhaust, Transmission 5 05-23-2015 07:21 PM
Clank from suspension/give in steering wheel over bump Shady195 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 09-09-2014 08:15 AM
Rear driver side clank and click spyingwind Issues | Warranty | Recalls / TSB 11 04-04-2014 11:26 PM
