Old 03-14-2017, 02:26 PM   #29
LowAndSlowBecauseNoTurbo
FRS 10 series #0239
LowAndSlowBecauseNoTurbo's Avatar
Drives: #0239 FRS 10 series silver ignition
Originally Posted by MurderousPandas View Post
I just got done running a gutted header, catless front pipe, and stock catback. Last week. It sounds bad, but there is some performance gain. And it does not smell in the car, even when on e85. Also, only the exit of the exhaust should smell, if it does elsewhere then you have an exuhast leak. I'm now running some cheap UEL headers while i wait for some nice ones.
"Chasing speed with patience"
what if I ran just the gutted header and left the cat in the front pipe? would that help with the sound or no sound and just interfere with the exiting exhaust?
Drop in K&N filter, CX Racing oil cooler, Tomei Expreme UEL headers, Invidia N1 Catback, OFT stage 2, Raceland coilovers, stage one Exedy clutch kit, Stoptech drilled and slotted rotors and Hawk HPS street pads
10 series #0239
LowAndSlowBecauseNoTurbo is offline   Reply With Quote
Old 03-14-2017, 10:17 PM   #30
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
It would likely sound better and not raspy. Tbh there are minimal gains to be netted on a catless front pipe, at least for NA. There are gains to be netted on a gutted header or catless header. Everything will require a tune for gains.
tyler_win_photo is offline   Reply With Quote
Old 03-14-2017, 10:25 PM   #31
FRS 10 series #0239
Alright, yea that's what I was leaning more towards was just the gutted header to drown out some raspiness since everyone is saying it's raspy. But I am going to run stage 1 with my stock headers and then I'm getting another set and running stage 2 on the gutted headers
10 series #0239
Old 03-14-2017, 11:01 PM   #32
Originally Posted by guybo View Post
I'm running gutted cats and OFT stage 2. It was a big difference from Stage 1 with the cats. It sounds great too with a cherry bomb and Berk dual exit.
I get a lot of compliments on it.
Nice cap. Got some good cooter there.
guybo (03-15-2017)
Old 03-15-2017, 04:44 AM   #33
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
That's my Sebring hat. I really want to go back this year but I have to wait until 2018. the 12 Hours is a lot of fun to go to.
Yeah I'm more of a Cooterized rolled bill kind of a guy not one of these flat bill punk kids running around today. LOL
guybo is offline   Reply With Quote
The Following User Says Thank You to guybo For This Useful Post:
Ultramaroon (03-15-2017)
Old 03-15-2017, 07:15 AM   #34
Lantana frs
Drives: 13 frs red
A lot of times when you hear bad things about gutting it's from people who have no experience with it. But it works and it made my car like it has a new engine- huge difference in power but I have yet to dyno it. But My 80-100 MPH time went down by about 1.5 secs and my 0-60 MPH time has lost close to a second too (still on stock tires).
I know the gains aren't the same as the high end headers, but you have the advantage of the stock heat shielding- there is no risk of cooking coils or anything else if you keep the stock heat shields. Also, OEM quality is top notch. No chance of cracked welds.
That really sounds good imo and I'm big into quiet. Lol.
Lantana frs is offline   Reply With Quote
The Following User Says Thank You to Lantana frs For This Useful Post:
guybo (03-15-2017)
Old 03-15-2017, 09:26 AM   #35
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
so you just have the header cat gutted and left the front pipe cat in tact? would the exhaust eat up the front pipe cat or no? but I was planning on running stage 1 until I bought another set of headers so I can keep the factory headers that came with the car in tact. I will definitely be looking more into before and after of the gutted headers and anymore information I should be informed about with the gutted header would be awesome
Precisely. I mean one cat has to be first against the exhaust stream.
I don't care if it gets eaten up, frankly. And if it fails totally and I want it replaced, I can go to the dealer and ask them why my car is stinky, and get them replaced within 100k as it's an emissions component.
JazzleSAURUS is offline   Reply With Quote
The Following User Says Thank You to JazzleSAURUS For This Useful Post:
Old 03-15-2017, 03:28 PM   #36
MurderousPandas
MurderousPandas's Avatar
Drives: 2013 Scion FRS
When i removed the cat in the header is when my exhaust got raspy, the air doesn't flow very well because where the cat once was is now just a chamber for exhaust gasses to get caught up in. When i ran a catless front pipe and stock catted headers, it sounded decent. If you can cut the cat and weld a pipe in, you'll get a better sound i would imagine, but i hated the gutted cat sound so much i bought some cheap headers to fix just the sound.
MurderousPandas is offline   Reply With Quote
Old 03-15-2017, 03:35 PM   #37
guybo
Huge E85 fan!
guybo's Avatar
The difference with mine may be the cherry bomb. It cuts out any rasp and helped a lot with the Berk drone. Also a lot of people straight pipe it which gets rid of the resonator and that weird muffler thing in the stock front and mid pipes. All those help the sound a lot.
Also the Cooter hat helps a lot. Never underestimate
Old 03-15-2017, 11:21 PM   #38
Rezi
Drives: GT86
Just curious. Did someone already swap the oem cat out for an hfc?
Thats what i am doing next week.
Rezi is offline   Reply With Quote
Old 03-17-2017, 10:35 AM   #39
FRS 10 series #0239
adding on to this OFT thread, would I be able to run stage 2 EL header tune on the stock headers? or would that mess anything up? I mean I'm picking up some headers later today but I just would like to know if I could hahaha
10 series #0239
Old 03-17-2017, 10:56 AM   #40
ajcarson11
Drives: 2013 Subaru BRZ Limited (Black)
No. Do not do this. Very large chance you will damage something.
ajcarson11 is offline   Reply With Quote
The Following User Says Thank You to ajcarson11 For This Useful Post:
Old 03-17-2017, 10:59 AM   #41
FRS 10 series #0239
alright hahaha I kinda figured it couldnt be good but I just thought id throw it to the experts before I royally messed up hahaha
10 series #0239
Old 03-17-2017, 02:07 PM   #42
MurderousPandas
It won't damage anything, but will drop performance as your car isn't setup properly for that tune. There's no life threatening difference from stage 1 to stage 2, the only difference is that one is meant for cats and the other catless.
The Following User Says Thank You to MurderousPandas For This Useful Post:
gutted cat, oft, open flash tablet, torque solution
Gutted Header & Front Pipe - Dyno Inside Joe-G Engine, Exhaust, Transmission 60 04-15-2020 01:34 PM
Dyno -- Stock vs Ace Header / Tune (oem everything else) IPGJames Engine, Exhaust, Transmission 42 08-25-2016 12:51 PM
FS: OEM FRS/BRZ Header w/ Gutted Cat malubawla Engine, Exhaust, Bolt-Ons 10 06-06-2014 11:29 AM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 05:42 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 04:12 PM
