View Poll Results: Which of the following options have you decided upon for this much discussed Gen1 201
No torque dip specific modifications: It doesn't bother me. 67 25.38%
No torque dip specific modifications: I don't want any potential future warranty issues due to mods. 26 9.85%
OFT tune 28 10.61%
UEL Header (Which one?) 14 5.30%
UEL header + OFT tune 100 37.88%
Something else: Please specify. 19 7.20%
Wait for the performance results of the 2017 model before deciding. 10 3.79%
Voters: 264. You may not vote on this poll
Old 07-03-2016, 08:42 AM   #113
JD001
JD001's Avatar
Drives: Subaru BRZ
Tomei UEL, Milltek OP and Berk fast cat. No tune as the car is still under warranty.
Old 07-03-2016, 04:42 PM   #114
CatDaddysBBQ
Drives: '13 FR-S
I went as gradual and low end as I could. In Chicagoland, wanted to stay catted just in case.
First, I got an OFT. Stg 1 93 octane tune cut the dip down dramatically on its own. Car revved harder all over the tach too. Almost stopped here, as it was good enough.
Then, I came across a cheap used TopSpeed EL catted header. It's branded a UEL... Technically the runners aren't exactly the same length, but 90% close. They really aren't unequal enough to be one. I'm fine with this, didn't want the UEL rumble, even though UEL is supposed to help more with the dip. The cat is a small 200cfm high flow unit, way less restrictive than Oem. As far as headers go, this one is barely better than the Oem, BUT...
OFT stage 2 93oct + this low end header is great. dip is gone, car pulls cleanly from idle to redline and more power all over. Car isn't fast, but isn't slow anymore. Barely more volume than stock. Total spent is under 750, totally worth it.
CatDaddysBBQ is offline   Reply With Quote
Old 07-03-2016, 09:58 PM   #115
Spec C Wannabe
Drives: 2017 WRB M/T BRZ
Does this set up without remapping cure the Torque Dip? How much better does it feel?
Spec C Wannabe is offline   Reply With Quote
Old 07-03-2016, 10:04 PM   #116
TruRace
TruRace's Avatar
Drives: FRS-Raven-MT
Torque Dip Decisions
Originally Posted by Aztec View Post
Tune and UEL Header almost completely eliminates the torque dip.
I personally think that it makes for a smoother shifting experience to not be required to shift AROUND the dead zone of 3.5-4.5k
The dip is almost a non issue for me. Interesting because we are running relatively similar setups. Hardly even notice it anymore. This is kind of a weird dyno readout though, but you dyno looks similar to mine before I installed my header.
TruRace is offline   Reply With Quote
Old 07-04-2016, 02:11 AM   #117
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
Hell the hybrid has the same 0 to 60 as us! (well the auto ones of us at any rate).
With a proper launch in a MT you should be able to smoke a 2015 XSE V6. Unless of course you find somebody that can drive a Camry at the top limits.
Haha a 5 second 0-60 Camry.
What a crazy world we live in.
Wise is offline   Reply With Quote
Old 07-04-2016, 05:41 AM   #118
Vassp
Drives: Hyundai i30
Originally Posted by Mim View Post
Perhaps us folk from the land down under have it a little better than others https://www.hertz.com.au/rentacar/pr...adrenaline.jsp
You realize there is nothing broken about the car? Hundreds of thousands of people from around the world drive the car stock and are totally satisfied.
Everyone's view on acceptable risk is different, but at the end of the day if this is going to be a daily driver then wait for the MY17 cars and just buy the latest most up to date iteration and enjoy it as is. It has quite a few updates over the past releases and will likely keep you happy for the handful of years its covered by warranty.
I agree with This post and quoted it, I'll my my 20c.....
The new car will be tested soon enough, see how it pans out and make your choice. Don't over think it before you drive it. I searched these forums and you know what, when I drove the car there were many things I didn't agree with both in positives and negatives. What does that tell you?
Vassp is offline   Reply With Quote
The Following 2 Users Say Thank You to Vassp For This Useful Post:
FR-S Future Owner (07-04-2016), Mim (07-04-2016)
Old 07-07-2016, 03:30 PM   #119
johan
Drives: '14 981CS, '99 NB1
Tomei UEL + ECUTek dyno tune. (not a fan of OFT)
Torque dip? What Torque dip...? Header + tune inverted the torque dip and made it my peak torque point. It truly is a wonder why Subaru insists on putting an EL header on this car...
johan is offline   Reply With Quote
Old 03-09-2017, 11:33 AM   #120
LowAndSlowBecauseNoTurbo
FRS 10 series #0239
LowAndSlowBecauseNoTurbo's Avatar
Drives: #0239 FRS 10 series silver ignition
Originally Posted by kch View Post
Yeah i wish it was perfectly flat. But it's nearly there.
what are you running? UEL's and stage 2 OFT tune with full catback? any intake or anything of the sort?
Drop in K&N filter, CX Racing oil cooler, Tomei Expreme UEL headers, Invidia N1 Catback, OFT stage 2, Raceland coilovers, stage one Exedy clutch kit, Stoptech drilled and slotted rotors and Hawk HPS street pads
10 series #0239
LowAndSlowBecauseNoTurbo is offline   Reply With Quote
Old 03-09-2017, 07:27 PM   #121
kch
Senior Misanthrope
kch's Avatar
Yep, UEL + full exhaust (high flow cat in FP). No real intake; just a drop-in apexi air filter. I'm no longer on OFT; I went flex fuel with ecutek through moto-east.
The Following User Says Thank You to kch For This Useful Post:
Old 03-09-2017, 08:05 PM   #122
Calvin27
Drives: GTS
Torque dip fix put me 2 secs faster on a 1.50 course. A lot of the locals have issues with the gear spacing between second and third. Some corners you enter third and end up either at 5000rpm exiting or basically half a second on second gear.
Calvin27 is offline   Reply With Quote
Old 03-10-2017, 04:04 PM   #123
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Maybe drive a camry? Torque dip bothers you? how about rev it higher & stop racing between traffic lights?
To be honest the first thing i feel after getting the car tuned is ....boring.
I need to get the car tune again for more topend...
The Following User Says Thank You to chaoskaze For This Useful Post:
Cole (03-14-2017)
Old 03-14-2017, 09:48 AM   #124
FRS 10 series #0239
alright, sick. thats my goal as of right now. I just want to eliminate the torque dip as much as I can. I've got a theory, and correct me if I'm wrong, but I was thinking of getting a second set of stock headers and front pipe and gut both of the cats so I can keep my original headers and front pipe for smoging. I know the gutted cats don't have the best flow but with the OFT that I'm going to be getting, I am going to run the OFT with stock catted headers of stage 1 and then get the other set and run stage 2 with the gutted stock headers and front pipe. what do you think about this?
10 series #0239
Old 03-14-2017, 10:22 AM   #125
Cole
Not a troll
Cole's Avatar
Sounds like a huge waste of time.
Cole is offline   Reply With Quote
Old 03-14-2017, 10:30 AM   #126
FRS 10 series #0239
really? why is that? I looked up this thread and it seems to have decent numbers?http://www.ft86club.com/forums/showthread.php?t=96235
10 series #0239
decisions decisions Triumphrider Scion FR-S / Toyota 86 GT86 General Forum 13 12-01-2014 07:29 PM
Decisions decisions... amilleri Scion FR-S / Toyota 86 GT86 General Forum 26 05-05-2014 03:33 PM
Automatic or Manual Transmission? Decisions, decisions... Bfly Engine, Exhaust, Transmission 27 07-08-2012 03:25 PM
decisions... EPIKsung Scion FR-S / Toyota 86 GT86 General Forum 9 06-16-2012 10:22 PM
Decisions, decisions... Jay Grey Scion FR-S / Toyota 86 GT86 General Forum 24 05-16-2012 01:18 PM
