Northern California NorCal
Old 02-15-2017, 02:49 PM   #15
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
You can swap your clutch slave while you're in there feeling industrious.
After the spring removal.
I got the snap ring off once, but stalled at pulling the mechanism apart. Then dinner was ready so... snap ring went back on.
ineedyourdiddly
Ultramaroon (02-15-2017)
Old 02-15-2017, 08:13 PM   #16
SmartedPanda
SmartedPanda's Avatar
Drives: SWP BRZ Limited Manual. 2014
Mine's squeaks inconsistently, any suggestions for narrowing it down if it's a throw bearing or just something else?
Took it to dealerships, obviously they were useless.
[| Blox 490 Knob | Mishimoto Silicon Intake | K&N Filter | DD Always-On DRL | Tomei 60S | Weather Tech | RED USDM TOM's Tail Lights | OEM Underbody Panels | Intec High Mount Brake | RexSpeed Heated Wide Mirrors | TC105N 17x9 | Super Sport 245/40R17 |TRD Quickshifter | Porsche Brake Air Duct | TRD Sliding Armrest| OEM Knee Pads | MTEC Shifter Springs| WRX OEM Oil Cooler| Generic PVC Catch Can|]
SmartedPanda is offline   Reply With Quote
Old 02-16-2017, 01:08 PM   #17
Blue Bird
Blue Bird's Avatar
Drives: '14 BRZ
I have a '14 and it squeaks inconsistently too. But the squeaks happen when the engine is off. So I assume it's not the throw out bearing if the previous post is right? It squeaks when it is depress but not out.
Blue Bird is offline   Reply With Quote
Old 02-19-2017, 03:38 AM   #18
treminaor
"DGM BRZ"
treminaor's Avatar
Drives: 2016 BRZ Limited
Mine has made that sound for at least two years now, too lazy to do anything about it. Maybe I'll feel industrious someday.
Just do it, even if you replace the slave cylinder it will only take you 20 minutes to fix a problem you hear every day of your life.
treminaor is offline   Reply With Quote
Old 02-19-2017, 03:40 AM   #19
treminaor
"DGM BRZ"
treminaor's Avatar
If you hear it even when the car isn't running then it's the clutch fork that actuates with the clutch pedal. You can fix it yourself with some grease.
If you only hear it while the engine is running then as suggested before it could be the TOB or something else and you should have it inspected.
Old 03-13-2017, 09:11 PM   #20
Blue Bird
Blue Bird's Avatar
Drives: '14 BRZ
Do you know if this fix on the WRX works the same way as the BRZ?
[ame="https://www.youtube.com/watch?v=V1N2mHA3blQ"]Clutch pedal noise squeak sound Subaru Series Part 13 WRX STi fix solution slave cylinder - YouTube[/ame]
Old 03-13-2017, 10:11 PM   #21
Somerandom18
Drives: 2017 manual BRZ
Just spray some WD40 on it!
Sent from my Pixel XL using Tapatalk
Somerandom18 is offline   Reply With Quote
Old 03-13-2017, 10:42 PM   #22
different mechanism at the master cylinder. No rubber doohicky.
WD-40 is not a lubricant. Not a permanent lubricant, at least.
funwheeldrive (03-14-2017), treminaor (03-13-2017)
Old 03-13-2017, 10:49 PM   #23
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
So rig up a wd40 sprayer like the IC sprayer on the GD STi for when the tmic starts to heatsoak. Squeek, press the button again
The Following 3 Users Say Thank You to finch1750 For This Useful Post:
Somerandom18 (03-14-2017), treminaor (03-13-2017), Ultramaroon (03-13-2017)
Old 03-13-2017, 10:53 PM   #24
Genius. This is why you are the Undisputed El Presidente.
finch1750 (03-14-2017)
Old 03-13-2017, 11:03 PM   #25
Blue Bird
Blue Bird's Avatar
Drives: '14 BRZ
So this guide should be the one?
http://www.ft86club.com/forums/showthread.php?t=99578
Old 03-13-2017, 11:21 PM   #26
That's a good thread. Have a look at this one too. It takes a different direction which may be closer to your issue.
I'm a bit skeptical of the conclusion only because I haven't personally experienced it. You know how that goes.
Old 03-13-2017, 11:42 PM   #27
Blue Bird
Blue Bird's Avatar
Drives: '14 BRZ
Thank you, I will check it out.
Melted Throw Out Bearing danthedirt Issues | Warranty | Recalls / TSB 59 01-25-2018 05:32 PM
Post If You Have Had Your Throw-Out Bearing Go Bad! Bushhy Issues | Warranty | Recalls / TSB 8 10-24-2016 05:34 PM
Throw-out bearing mhigham Issues | Warranty | Recalls / TSB 71 08-18-2016 10:21 AM
Noisy throw out bearing jp_r6 Issues | Warranty | Recalls / TSB 23 08-18-2016 04:45 AM
throw out bearing clips... Shit Luck Engine, Exhaust, Transmission 0 04-12-2014 06:34 PM
