| Northern California NorCal |
#15 | |
Drives: '13 FRS - STX
![]() I got the snap ring off once, but stalled at pulling the mechanism apart. Then dinner was ready so... snap ring went back on. |
| The Following User Says Thank You to strat61caster For This Useful Post: | Ultramaroon (02-15-2017) |
#16 |
Drives: SWP BRZ Limited Manual. 2014
Mine's squeaks inconsistently, any suggestions for narrowing it down if it's a throw bearing or just something else?
Took it to dealerships, obviously they were useless.
[| Blox 490 Knob | Mishimoto Silicon Intake | K&N Filter | DD Always-On DRL | Tomei 60S | Weather Tech | RED USDM TOM's Tail Lights | OEM Underbody Panels | Intec High Mount Brake | RexSpeed Heated Wide Mirrors | TC105N 17x9 | Super Sport 245/40R17 |TRD Quickshifter | Porsche Brake Air Duct | TRD Sliding Armrest| OEM Knee Pads | MTEC Shifter Springs| WRX OEM Oil Cooler| Generic PVC Catch Can|] |
#17 |
Drives: '14 BRZ
I have a '14 and it squeaks inconsistently too. But the squeaks happen when the engine is off. So I assume it's not the throw out bearing if the previous post is right? It squeaks when it is depress but not out.
#18 |
"DGM BRZ"
Drives: 2016 BRZ Limited
Just do it, even if you replace the slave cylinder it will only take you 20 minutes to fix a problem you hear every day of your life.
#19 | |
"DGM BRZ"
If you only hear it while the engine is running then as suggested before it could be the TOB or something else and you should have it inspected.
#20 | |
Drives: '14 BRZ
[ame="https://www.youtube.com/watch?v=V1N2mHA3blQ"]Clutch pedal noise squeak sound Subaru Series Part 13 WRX STi fix solution slave cylinder - YouTube[/ame] |
#21 |
Drives: 2017 manual BRZ
Just spray some WD40 on it!
Sent from my Pixel XL using Tapatalk |
#22 | |
WD-40 is not a lubricant. Not a permanent lubricant, at least.
| The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | funwheeldrive (03-14-2017), treminaor (03-13-2017) |
#23 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
So rig up a wd40 sprayer like the IC sprayer on the GD STi for when the tmic starts to heatsoak. Squeek, press the button again
| The Following 3 Users Say Thank You to finch1750 For This Useful Post: |
#24 | |
| The Following User Says Thank You to Ultramaroon For This Useful Post: | finch1750 (03-14-2017) |
#25 | |
Drives: '14 BRZ
http://www.ft86club.com/forums/showthread.php?t=99578 |
#26 | |
I'm a bit skeptical of the conclusion only because I haven't personally experienced it. You know how that goes.
#27 |
Drives: '14 BRZ
Thank you, I will check it out.
| Melted Throw Out Bearing | danthedirt | Issues | Warranty | Recalls / TSB | 59 | 01-25-2018 05:32 PM |
| Post If You Have Had Your Throw-Out Bearing Go Bad! | Bushhy | Issues | Warranty | Recalls / TSB | 8 | 10-24-2016 05:34 PM |
| Throw-out bearing | mhigham | Issues | Warranty | Recalls / TSB | 71 | 08-18-2016 10:21 AM |
| Noisy throw out bearing | jp_r6 | Issues | Warranty | Recalls / TSB | 23 | 08-18-2016 04:45 AM |
| throw out bearing clips... | Shit Luck | Engine, Exhaust, Transmission | 0 | 04-12-2014 06:34 PM |
