Old 03-11-2017, 11:16 PM   #15
Originally Posted by Chad86 View Post
ProECU reads DTC P0456 (slow leak)
I have upgraded fuel pump and injectors. Could this have anything to do with catless header?
Nah, that's p0420.
Click "readme" on my sig. go to Repair Manual>engine/hybrid system>fa20 emission control>purge valve> components.
See how that plumbing goes right under your intake manifold. Verify that it was not broken or left disconnected when you installed your blower.
Chad86 (03-11-2017)
Old 03-11-2017, 11:24 PM   #16
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Nah, that's p0420.
Thanks. I had a shop do the install. Is this easy to spot myself?
Chad86 is offline   Reply With Quote
Old 03-11-2017, 11:26 PM   #17
Don't remember how the sprintex covers it. just spend some quality time between the picture and looking around in there. It'll make sense.
I'm winging it with respect to evap system components physically close to where the latest work has been done. That's the area where I would look first. There are many other components but try the low hanging fruit first.
Chad86 (03-11-2017)
Old 03-11-2017, 11:36 PM   #18
Chad86
Chad86's Avatar
Drives: Toyota GT86
I just took a look in the dark with a flashlight and don't see anything unplugged. I will inspect in daylight tomorrow and report back.
Old 03-11-2017, 11:40 PM   #19
Also go to Engine/Hybrid System> FA20 ENGINE CONTROL>SFI SYSTEM>P0455,P0456,P1451,P2404; Evaporative Emission Control System Leak Detected (Gross Leak)
Chad86 (03-11-2017)
Old 03-11-2017, 11:46 PM   #20
Chad86
Chad86's Avatar
Drives: Toyota GT86
Is it worth unplugging the battery to see if the code stays away? as I had the fuel leak fixed not that long ago.
I also have the Perrin CAI, not sure if this would affect this.
Old 03-12-2017, 12:09 AM   #21
This is strictly the evap system so, no, nothing to do with the CAI.
It'd be better to get one of those bluetooth elm32 goddammits so you can read/clear the codes on the fly. Unless you find and fix something specific, like tighten a loose hose, there's no point in disconnecting the ecu.
...but I sympathize with the desire to try it.
Chad86 (03-12-2017)
Old 03-16-2017, 02:06 AM   #22
Chad86
Chad86's Avatar
Drives: Toyota GT86
Battery reset cleared the CEL, but after a few drives it has now returned! I will contact my shop as the install is still under warranty.
Old 11-06-2017, 07:43 PM   #23
csax
Drives: Lightning Red 2013 BRZ
Lock Ring and MAP Sensor
Originally Posted by Kojiro View Post
Update: EVAP codes disappeared because fuel pump canister lock ring was not on tight/correct.
However, the stalling and running in a limp mode was still happening.
Found out through my tuner that my skunk2 4bar map sensor has malfunctioned.
Sure enough, bought a new one and all is working fantastic.
So if you ever have starting issues or your car run likes crap for a few minutes
and you're boosted, change your map sensor.
So low and behold like 10k miles after taking the car in under warranty and having subaru tighten that lock ring, my check engine light is back, and a few times I've noticed incredibly sluggish performance (which I'm assuming is limp mode). Also, my car isn't boosted, but I have reason to believe that the owner before me did (bumper fitment issues, lack of engine bay triangulation bars, and these issues). So my question is: is this purely to blame on the MAP sensor, or is this a combination of the lock ring and MAP sensor?
csax is offline   Reply With Quote
Old 02-22-2018, 11:58 AM   #24
InnovativeFT86
I'm not a dude.
InnovativeFT86's Avatar
Drives: 13 FR-S
Did you ever find out what caused your CEL? I'm currently getting the same code with the Sprintex SC kit installed just a few days ago. Retraced all hoses, everything looks good. About to check the lock ring which could have coincidentally failed??
InnovativeFT86 is offline   Reply With Quote
OFT Code U0122.. Limp mode.. Help cameronjones239 Software Tuning 16 05-19-2021 01:25 AM
Dead battery; starts up in limp mode kilrb Issues | Warranty | Recalls / TSB 15 01-04-2018 03:54 PM
Limp mode AFTER clearing CEL white_knight Issues | Warranty | Recalls / TSB 8 03-30-2016 09:40 PM
Which DTC do you turn off to remove the rear o2 without limp mode mad_sb Software Tuning 22 05-01-2015 12:10 AM
Car in Limp mode... No CEL Sportsguy83 Issues | Warranty | Recalls / TSB 60 08-20-2014 04:35 AM
