Old 06-29-2012, 11:43 AM   #1
jarviz
jarviz's Avatar
Drives: Raven FRS MT
1000 miles
I'm about to break 1000 miles on my car and read some posts that it's a good idea to get an oil change at this time.
Are there a lot of people doing this and is there some special type of oil I should get or is the manufacturer recommended good enough?
Is it okay to bring it to any mechanic or should I just bring it to toyota for now?
jarviz is offline   Reply With Quote
Old 06-29-2012, 11:54 AM   #2
eriktherod
Drives: 2013 Scion FR-S Firestorm Red MT
I'm waiting for 5000 but lots of people have done it beforehand (100, 1000, 2000 miles you name it).
The Mobil 1 0w20 Toyota uses is fine (my dealer has said Mobil 1 is their supplier), 5.8 quarts I believe. Though a few have said do 5 quarts, check, and top off.
It's easy to do the oil change, but maybe a Toyota/Subaru dealer would be more familiar with the car.
eriktherod is offline   Reply With Quote
Old 06-29-2012, 12:30 PM   #3
jarviz
jarviz's Avatar
Does toyota charge extra for an oil change compared to a regular mechanic?
Has anybody gotten their oil changed yet at a mechanic - were there any issues/
Old 06-29-2012, 12:31 PM   #4
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
The car holds 5.5 quarts plus the size of your filter. With the stock filter 5.8 was perfect for me. I changed it out at 1400m (I was going to do 1k but got busy).
After that I will follow the regular guidelines.
If you do it yourself it's a good way to get to know your car, but most people don't have the ramps/chucks to get the car up. It is pretty easy however.
Hawaiian is offline   Reply With Quote
Old 06-29-2012, 12:39 PM   #5
Chewie4299
Spaceman
Chewie4299's Avatar
Drives: 2013 Firestorm Scion FR-S
I haven't done it yet but it looks as though this oil change is going to be second only to my jeep in terms of ease.
FRS has the filter in the best position ever but the jeep never required jack/ramps.
Sent from my Galaxy Nexus using Tapatalk 2
Chewie4299 is offline   Reply With Quote
Old 06-29-2012, 12:53 PM   #6
R8
Spinning Triangles
R8's Avatar
Drives: RX-8
Should any problems arise with the car, it's easier to prove maintenance was done properly if the dealer has been doing it.
You *can* use anyone and just save the receipts, but still... using the dealer removes that question mark.
R8 is offline   Reply With Quote
The Following User Says Thank You to R8 For This Useful Post:
eriktherod (06-29-2012)
Old 06-29-2012, 12:59 PM   #7
patchulaz
Drives: 2008 tC
what is the advantage to changing the oil at 1000 miles instead of 5000? i believe the manual just says every 5000 miles. i've heard of "breaking in" an engine, but i was under the impression that this is somehow done at the factory before the car is delivered now?
patchulaz is offline   Reply With Quote
Old 06-29-2012, 01:00 PM   #8
R8
Spinning Triangles
R8's Avatar
Drives: RX-8
In case there are metal shavings from break in floating around in the oil.
Old 06-29-2012, 02:42 PM   #9
driftartist
Kurenai Samurai
driftartist's Avatar
Drives: Red and manual
isnt that what the oil pump strainer and oil filter are for? ill probably play it safe and change it a 3,500 or 4k though just cause...
driftartist is offline   Reply With Quote
2012 Shelby 1000 M-17 Other Vehicles & General Automotive Discussions 13 03-28-2012 11:36 PM
1000 dollar deposit first in line for a whiteout FR-S TougeFR-S Scion FR-S / Toyota 86 GT86 General Forum 20 02-20-2012 10:58 AM
Updated: Toyota GT86 - facts from Japan (Handmade and only 1000 units/yr - DEBUNKED) Leeky Scion FR-S / Toyota 86 GT86 General Forum 376 12-02-2011 08:49 AM
