#15 |
Drives: 2004 tsx aspec manual /FRS WHITEOUT
Would a 35 offset fit in the front?
#16 | |
This time around, no big center lug nut Everything else is different. But we really wanted to make a wheel that is new but familiar at the same time
#17 |
#18 |
| The Following User Says Thank You to yoshiharadesign For This Useful Post: | poormans_LFA (06-29-2012) |
#19 |
The weight of the wheel is actually not super light. It comes in at roughly around 23-5lb depending on the pad thickness. This wheel though design wise cant be super light weight because of the step design element. For a lighter weight set up, we have the d-12c which at 18x8 is at 19lbs. This wheel is available already through discounttiredirect.com. Again, each one of our initial designs are meant to appeal to each type of enthusiast. If you want to have a light weight wheel that is light on the wallet as well, the D-12c is a great wheel. Our philosophy behind Dai's wheel line up is to have great looking and performing wheels at an attainable price with high quality since Dai really identifies with his fans and knows not everyone can afford super high priced wheels.
| The Following 3 Users Say Thank You to yoshiharadesign For This Useful Post: |
#20 |
FT86Club.com O.G.
Drives: Gunmetal Gundam Wing Zero Custom
D-12C looks good AND it comes in 5X100!! Nice!!
#21 |
#22 |
update: installed wheels no drop yet... Looks fantastic with 3 inch lip
Im sure after the drop its going to look even better!
| The Following 5 Users Say Thank You to yoshiharadesign For This Useful Post: | Choco (01-21-2015), Chupacabra (07-01-2012), CoRi J (06-30-2012), denkigrve (06-30-2012), nix (07-15-2012) |
#24 |
Drives: Fast
Tire width is too narrow for wheel
#25 |
FT86Club.com O.G.
Sits up a bit high, but I bet after a little dump it will perfect-O. Please do share more pics after your friend installs the coilovers/lowering springs.
#26 |
U mean the Fronts or rear? 225/40r18. 245/35r18. Of course the set up if people want to can be bigger
#27 |
#28 |
Drives: 1995 Nissan Sentra
what is the price on these?
| Wheel Directory: Yoshihara Design DY-D5C 18x9.0 +35 | Lanbaldo3 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 26 | 09-15-2016 12:37 PM |
| Wheel Directory: Yoshihara Design DY-37C 18x9.0 +25 | PekoPeko | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 05-23-2014 04:53 PM |
| Wheel Directory: Yoshihara Design DY-37C 18x8.0 +30/18x9.0 +35 | ish20 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 11 | 12-03-2013 11:08 PM |
| Wheel Directory: Yoshihara Design Champion 18x8.0 +30/18x9.0 +35 | JoeBoxer | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 36 | 11-24-2013 02:33 PM |
| New yoshihara design wheel | yoshiharadesign | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 129 | 11-01-2013 09:16 AM |
