Old 03-07-2017, 05:18 PM   #1
giorgi0424
Drives: '14 SWP BRZ
How is p0018 not covered under powertrain warranty....?
Installed my catless borla UEL header with stock front pipe and Tsudo catback @47k miles, and up came, the same day, a p0018 code (Camshaft+crankshaft correlation sensor). Now, from my understanding, this going unattended can cause jumped timing= blown engine. When the lights are on (CEL and Traction light simlutaneously) in between me clearing the code, the car is detuned, but not in full limp mode.
I stopped by subaru to get some input on this problem, and they said that p0018 is not covered under warranty. i don't understand the logic in this. I've done nothing to affect the engine, yet this problem could cause serious engine issues making me curious why it wouldn't go under powertrain.
Good news is that we're in agreement that a header has nothing to do with any of this, so my warranty won't be voided if the culprit is a component which would be covered under the powetrain warranty. Also, I hit up Moto-east - where i'm going to get it tuned once this is sorted - to see if they have come across any incidents where a header caused this problem, and they said absolutely not, as the two are unrelated
Any input, guys?
giorgi0424 is offline   Reply With Quote
Old 03-07-2017, 05:21 PM   #2
JoeC
Drives: Subaru BRZ Limited
I thought the warranty was only 36k miles Is there a factory powertrain warranty that is covered longer?
JoeC is offline   Reply With Quote
Old 03-07-2017, 05:23 PM   #3
giorgi0424
Drives: '14 SWP BRZ
bumper to bumper is 3yr36k, while powertrain is 6yr60k
Old 03-07-2017, 05:33 PM   #4
swarb
Go to another dealer and try to get it fixed.
Or get it in writing and then lawyer up.
The Following User Says Thank You to swarb For This Useful Post:
Overdrive (03-19-2017)
Old 03-07-2017, 05:34 PM   #5
JoeC
nice. I honestly didn't even realize that...
Old 03-07-2017, 05:39 PM   #6
giorgi0424
Drives: '14 SWP BRZ
I'd hate to go down this route. I was told that we have to at least do a diagnosis which will cost $120. Then, depending on what is causing the problem, the powertrain warranty will either cover it or will not. I honestly can't think of any component that could be the cause that wouldn't be related to the powetrain in one way or another. I'm thinking if the problem ends up being covered, then even the diagnosis should get covered.
Old 03-07-2017, 05:40 PM   #7
giorgi0424
Drives: '14 SWP BRZ
sorry I meant it's 5yr60k, not 6 years.
Until today I thought it was 5yr50k, not 60k. Regardless, it's better than just 3yr36k, lol
Old 03-07-2017, 05:52 PM   #8
swarb
Whoever told you it's not covered is giving you the wrong information. There is a process which involves the diagnosis you mentioned. Don't accept any words as truth unless it is in writing. $120 will be waived if the warranty repair is approved.
giorgi0424 (03-07-2017)
Old 03-07-2017, 05:54 PM   #9
JoeC
now I'm totally confused! kidding kidding. thanks for the info.
Old 03-07-2017, 05:55 PM   #10
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
https://www.subaru.com/owners/vehicl...ties-2013.html
Powertrain Limited Warranty
POWERTRAIN COVERAGE for all models is 5 years or 60,000 miles, whichever comes first. Subject to the exclusions listed in this warranty, it covers the major powertrain components listed below.[2]
Powertrain Coverage Components
Engine
Engine block and all internal parts
Cylinder heads and valve trains
Oil pump, oil pan
Timing belts or gears and cover
Water pump
Flywheel
Intake and exhaust manifolds
Oil seals and gaskets
Transaxle and Differential
Transaxle case and internal parts
Torque converter
Electronic transmission control unit
Seals and gaskets
Axle shafts and constant velocity joints [except boots][3]
Propeller shaft
Wheel bearings
Electrical is not covered.
The Following 2 Users Say Thank You to mav1178 For This Useful Post:
funwheeldrive (03-08-2017), giorgi0424 (03-07-2017)
Old 03-07-2017, 06:16 PM   #11
infinitewhiskey
Drives: 2016 Oceanic FR-S
I actually had that code come up when one of my O2 sensors on my header somehow backed out. Not sure if they're related but it never came back up once I installed the sensor correctly.
infinitewhiskey is offline   Reply With Quote
Old 03-07-2017, 07:33 PM   #12
giorgi0424
Drives: '14 SWP BRZ
Oh, interesting! I'll have to take a look at that for sure
Old 03-07-2017, 07:41 PM   #13
giorgi0424
Drives: '14 SWP BRZ
Was yours a catless header or chatted and did you already have a tune on it when that happened
I haven't tuned mine yet and it's catless. I also haven't even gotten he p0042 code yet for cat efficiency
Old 03-08-2017, 09:16 AM   #14
stevesnj
stevesnj's Avatar
Call Subaru and tell them the issue.
My 2016 Build thread
The Following User Says Thank You to stevesnj For This Useful Post:
giorgi0424 (03-22-2017)
camshaft, crankshaft, header, p0018, warranty
Wheel Hub causing hum? Warranty covered? HachiRo Issues | Warranty | Recalls / TSB 3 04-21-2016 11:43 PM
Experiences with Subaru Powertrain warranty? armstrom Issues | Warranty | Recalls / TSB 17 04-03-2016 12:01 AM
Headers and Powertrain Warranty? smg1138 Engine, Exhaust, Transmission 5 07-27-2015 01:27 PM
"This repair is not covered by Subaru's limited warranty" RE: 4th gear tranny grind DoomsdayJesus Issues | Warranty | Recalls / TSB 108 04-29-2014 01:15 AM
Should this be covered by warranty and can Subaru repair this? brzadmir Issues | Warranty | Recalls / TSB 16 08-01-2013 12:08 AM
