Old 03-07-2017, 05:57 AM   #29
Bramick
Bramick's Avatar
Drives: 2013 BRZ Limited M/T
I don't have drone issues...
2013 BRZ Limited | 1965 Mustang GT Fastback
Bramick is offline   Reply With Quote
The Following User Says Thank You to Bramick For This Useful Post:
goonz_maroon (03-07-2017)
Old 03-07-2017, 08:35 AM   #30
jasonojordan
Drives: 2013 satin white brz limited
The ACE 400 is ridiculous on the street. Drove a locals car with them and the pull was amazing for NA. Just remember you need a tune from Delicious for max output from them. Seems every other dyno done on them showing low numbers was from a different tuner.
He had it paired with the HKS single exit and it sounded amazing
I was very torn between the 350 and the 400 when I was looking at headers. Ultimately ended up spending the little extra and going with the 350. Need to take the time to powder-coat my wheels so I can get the car out and about again.
jasonojordan is offline   Reply With Quote
The Following User Says Thank You to jasonojordan For This Useful Post:
Old 03-07-2017, 08:36 AM   #31
goonz_maroon
goonz_maroon's Avatar
Drives: 2015 Scion FR-S
If you don't mind me asking was there a preference as to why you chose the 350 over the 400? This is the question I am trying to mull over right now. Not much vids on the 400 atm
Sent from my SM-N910W8 using Tapatalk
goonz_maroon is offline   Reply With Quote
Old 03-07-2017, 08:41 AM   #32
goonz_maroon
Your setup is beastly 😆
The Following User Says Thank You to goonz_maroon For This Useful Post:
Bramick (03-09-2017)
Old 03-07-2017, 08:47 AM   #33
jasonojordan
My main reasoning was I was not 100% sure I won't eventually supercharge it. From everything I read about the 350 is it was one of if not the best choice of headers if you ever plan to supercharge in the future. The 400 was also just coming out when I got the 350 so not a lot of real-world feedback on it and I could afford the 350 so just went that route. Sorry I don't have any concrete reasoning's such as oh it makes so much more power then the 400 under these conditions.
Old 03-07-2017, 08:50 AM   #34
goonz_maroon
Thanks for the feedback. I like both headers and can't find any real reasons to choice one over the other, other than one has been tried and tested and the other is relatively more new. Both sound great and perform great.
Old 03-07-2017, 09:31 AM   #35
jasonojordan
Yep I was in your exact same position 4 months or so ago when I was looking at buying mine. Basically the advice people gave me is if you can afford the 350 go with the 350. If you cant go with the 400. The 350 is a tight squeeze even on left hand drive cars. You will have to lift up the motor for install of the over pipe . I do not know if this is the case with the 400 or not. Either way motor and such is pretty easy to manipulate when you loosen up the nuts on the 2 engine mounts. Just make sure to loosen them don't take them all the way off or you can accidentally lift the studs out of the hole and its a royal pain to get them to drop back in.
Old 03-07-2017, 11:11 AM   #36
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
@CSG Mike can give some feedback I'm sure
Old 03-09-2017, 06:22 AM   #37
Bramick
Bramick's Avatar
I used this as an opportunity to install motor mounts at the same time..
goonz_maroon (03-09-2017)
Old 03-09-2017, 08:31 AM   #38
jasonojordan
I contemplated it but after seeing how easy it was to lift the motor I said meh next time I'm already over my self imposed spending limit for the car this year lol.
The Following 3 Users Say Thank You to jasonojordan For This Useful Post:
Bramick (03-09-2017), driftking96 (03-22-2017), goonz_maroon (03-09-2017)
Headers Question mattyd97 Engine, Exhaust, Transmission 29 10-29-2015 11:19 AM
Gaskets & Headers question Bach415 Engine, Exhaust, Transmission 16 06-30-2015 05:27 PM
Question about the Fa20club UEL headers Chuck. Engine, Exhaust, Transmission 7 04-22-2014 08:30 AM
Turbo Question regarding Headers Admired Forced Induction 13 10-16-2013 08:27 AM
question for guys with headers Xdragonxb0i Engine, Exhaust, Transmission 22 04-22-2013 12:49 PM
