Old 03-06-2017, 03:23 PM   #127
all4spl
If they are flipped truck manifolds, how are you still routing the exhaust where it needs to go?
all4spl is offline   Reply With Quote
Old 03-06-2017, 03:43 PM   #128
wutsaiu
wutsaiu's Avatar
Drives: 2015 Raven V8
Crossover pipe (2.5 inch) from drivers side to passenger side (Under crank pulley).
Merges under passenger side manifold.
Single exit 3inch exhaust routed similar to stock exhaust path.
wutsaiu is offline   Reply With Quote
Old 03-06-2017, 03:59 PM   #129
all4spl
do you have any pictures of this setup? or what the manifolds look like? Wonder if this would create a loss of power.
Old 03-06-2017, 05:15 PM   #130
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
People do it all the time with swaps. Turbo kits are easy to make due to this configuration.
Old 07-09-2017, 07:21 PM   #131
wutsaiu
wutsaiu's Avatar
Installed a P3 Vent Gauge.
Contacted them directly and asked for the FRS/BRZ gauge with LS (Camaro) programming. Works great.
The only part I don't have working for me is speed but that's just because I don't have my GM ecu connected to any speed sensor.
[ame="https://www.youtube.com/watch?v=hNCFV_Nqad4"]P3 Vent Gauge Scion FRS 6.2L LS3 Swap - YouTube[/ame]
The Following 6 Users Say Thank You to wutsaiu For This Useful Post:
Draco_PR23 (04-03-2018), D_Thissen (07-09-2017), gtpvette (07-10-2017), Lonewolf (08-03-2017), PR138 (07-09-2017), Sportsguy83 (07-10-2017)
Old 07-10-2017, 12:12 AM   #132
tirespin782
Drives: 02 s2k, 08 350z, 08 Fit sport
I'm not trying to pick at you, but loss of power compared to? A tubular manifold? One with equal lengths a a merge collector? Unequal lengths and a merge collector? See where I'm getting at. There are always compromises. Look at OEM R35 turbo manifolds for example. They aren't beautiful, they aren't tubular or equal length, but they have been proven to work.
tirespin782 is offline   Reply With Quote
Old 07-25-2017, 03:05 PM   #133
wutsaiu
wutsaiu's Avatar
Installed my new transmission.
7 speed TR6070 from 2014 Corvette.
Replaced the trans-axle tail housing with a T56 Magnum Tail and a custom made spacer plate. Also replaced the front (mid-plate) with Magnum.
Couldn't get reverse idler gear to fit in the tail housing so it's missing right now.
Hoping to take it apart over winter and have reverse for next year.
Not as nice as a Magnum XL but it's something different.
The Following 10 Users Say Thank You to wutsaiu For This Useful Post:
Draco_PR23 (04-03-2018), DustinS (07-25-2017), D_Thissen (07-25-2017), Lonewolf (08-03-2017), mrg666 (07-31-2017), Sportsguy83 (07-26-2017), Teseo (07-25-2017), tirespin782 (09-13-2017), wooly35 (07-25-2017), Zer0 (07-26-2017)
Old 09-13-2017, 07:34 AM   #134
wutsaiu
wutsaiu's Avatar
Finally dyno'd my engine.
386whp 367wtq
Not bad considering I have single 3inch exhaust and no tune.
The Following 7 Users Say Thank You to wutsaiu For This Useful Post:
BirgeyT1 (09-13-2017), DAEMANO (06-11-2018), Draco_PR23 (04-03-2018), DustinS (01-12-2018), D_Thissen (02-15-2018), Sportsguy83 (09-16-2017), wooly35 (09-13-2017)
Old 09-13-2017, 06:57 PM   #135
wooly35
Drives: 2014 Scion FR-S LS3
386whp 367wtq
Nicely done! Seems we both made almost identical numbers....
2014 scion FR-LS3 lol
wooly35 is offline   Reply With Quote
The Following User Says Thank You to wooly35 For This Useful Post:
wutsaiu (09-14-2017)
Old 04-02-2018, 06:42 PM   #136
vijay.dy06
Drives: Red BRZ
All I did was pop off the passenger side panel and rewire to bypass the fuel pump controller. Under the hood I connected the GM ECU fuel pump wire to the correct spot on the 86 fuse panel. I've had no issues with fuel after two summers of driving. Never touched the tank or pump or regulator.
What/how did you rewire tobypass the fuel pump controller?
Sent from my SM-G950U using Tapatalk
vijay.dy06 is offline   Reply With Quote
Old 04-03-2018, 09:15 AM   #137
MRS-Colin
Drives: 2001 Impreza 2.5 RS
It's been a hot minute. How is the TR6070 working?
Colin Beck
MRS-Colin is offline   Reply With Quote
The Following User Says Thank You to MRS-Colin For This Useful Post:
DustinS (04-03-2018)
Old 04-03-2018, 09:46 AM   #138
wutsaiu
wutsaiu's Avatar
Working well aside from having no reverse. Still trying to solve that. Much stronger transmission than an old T56.
Old 04-03-2018, 09:49 AM   #139
wutsaiu
wutsaiu's Avatar
Cut the power wire to the controller and cut the positive wire to the pump and connect them together. This way the 12v goes straight to pump instead of through controller.
Old 04-03-2018, 10:11 AM   #140
MRS-Colin
Looking into doing this in a different LS swap vehicle. Any details you could provide on the adapter or the hurdles you have with the reverse gear would be awesome. Used TR6070's are incredibly cheap and a good alternative to overpriced T56's.
Colin Beck
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
WTB A/T BRZ/FR-S CA Budget 21k Euan Want-To-Buy Requests 4 07-20-2015 11:50 PM
$2K Budget. What Would You Do? Skippman Electronics | Audio | NAV | Infotainment 46 02-22-2013 11:23 AM
New tires on a budget jflogerzi Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 01-23-2013 06:32 PM
There goes my MOD'ing Budget RedRocket Scion FR-S / Toyota 86 GT86 General Forum 35 10-19-2012 08:14 AM
