Old 11-01-2016, 10:05 PM   #113
ILLSMOQ
Drives: 2017 WR BLUE BRZ
Originally Posted by cf6mech View Post
Look to Vorschlag new V8 converted Beta build, they seem to think this car is ....it makes a huge difference....
Is there some updated info on the blog?
ILLSMOQ is offline   Reply With Quote
Old 11-02-2016, 03:22 PM   #114
cf6mech
Drives: FRS Silver LS1 swapped.
https://vorshlag.smugmug.com/Projects/2013-Scion-FRS/
http://www.vorshlag.com/forums/showt...8396#post58396
cf6mech is offline   Reply With Quote
Old 11-02-2016, 05:09 PM   #115
fizzymike
fizzymike's Avatar
Drives: 2014 Silver BRZ
Thats an awesome build dude, I dont think anyone here would disagree. Major props it looks great!
fizzymike is offline   Reply With Quote
The Following User Says Thank You to fizzymike For This Useful Post:
wutsaiu (11-02-2016)
Old 11-02-2016, 09:06 PM   #116
tofurun
tofurun's Avatar
Drives: 2014 BRZ Limited 6MT
@humfrz now thats the sound of america.
tofurun is offline   Reply With Quote
Old 12-18-2016, 07:28 PM   #117
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by wutsaiu View Post
Unlike the race car builds I wanted stock gauges to work. I used an Arudino micro controller with Canbus module to accomplish this.
With this I managed to get the tach and power steering functioning and the CEL off. Traction control is off and airbag system light is on but those don't bother me. I would like to get ABS working eventually, I just haven't devoted the time yet.
Lots of respect good sir! It's incredible what you have achieved! I have a few questions for you. Do you have A/C working with the Arduino? Does your fuel gauge only go full/half/empty? Did you ever get the water temp gauge working?
Would you know if this setup would work with push button start?
Thanks for your time and happy holidays!
Old 12-18-2016, 09:37 PM   #118
wutsaiu
wutsaiu's Avatar
Drives: 2015 Raven V8
I do not have AC, don't really care for it.
Fuel gauge is 'simplified' but its better than full/half/empty, it does 1/4s lol.
I did at one point find the code to get water temp working but I didn't bother to program it since I have a gauge with actual numbers.
I'm sure soon there will be more complete options, like MRS.
I'm happy that I at least managed to get as much working as I did, and it cost me very little.
wutsaiu is offline   Reply With Quote
The Following User Says Thank You to wutsaiu For This Useful Post:
Sportsguy83 (12-18-2016)
Old 12-18-2016, 09:39 PM   #119
Sportsguy83
Drives: Limited BRZ
Yes, I plan on getting his device 👍👍👍
Old 12-30-2016, 09:55 AM   #120
J-Money
J-Money's Avatar
Drives: GT-86
How much clearance under the car do you have. any pictures?
J-Money is offline   Reply With Quote
Old 12-30-2016, 12:11 PM   #121
wutsaiu
wutsaiu's Avatar
No photos of under the car.
The only clearance problem I have is exhaust.
I went with single 3" and it sticks down in a few spots due to the T56 taking up more of the tunnel than stock transmission would.
Old 01-27-2017, 09:36 AM   #122
Sportsguy83
Drives: Limited BRZ
Stock fuel pump. I rewired it to bypass the controller, GM ecu controls the pump but it's not throttled. Physically I combined both feed lines into one inside the engine bay. Works fine but I'm sure I'm at the limit of the pump. If I decide to make more power I'm swapping pumps.
It's the same pressure that my LS3 ECU required. 58psi (4bar) I believe.
Did you modify the stock fuel pressure regulator inside the fuel tank, or left that As Is?
Old 01-27-2017, 10:54 AM   #123
wutsaiu
wutsaiu's Avatar
All I did was pop off the passenger side panel and rewire to bypass the fuel pump controller. Under the hood I connected the GM ECU fuel pump wire to the correct spot on the 86 fuse panel. I've had no issues with fuel after two summers of driving. Never touched the tank or pump or regulator.
The Following 4 Users Say Thank You to wutsaiu For This Useful Post:
all4spl (01-27-2017), DustinS (01-27-2017), ILLSMOQ (01-27-2017), Sportsguy83 (01-27-2017)
Old 01-27-2017, 11:36 AM   #124
Sportsguy83
Drives: Limited BRZ
Thanks for always being very informative
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post:
DustinS (01-27-2017), wutsaiu (01-27-2017)
Old 03-05-2017, 04:04 PM   #125
FTA_Dave
Drives: 2013 Frs, E46 Bmw
Can I ask what manifolds you used? Stock truck?
FTA_Dave is offline   Reply With Quote
Old 03-06-2017, 07:43 AM   #126
wutsaiu
wutsaiu's Avatar
You got it.
Flipped truck manifolds, they face forward but still downwards.
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
WTB A/T BRZ/FR-S CA Budget 21k Euan Want-To-Buy Requests 4 07-20-2015 11:50 PM
$2K Budget. What Would You Do? Skippman Electronics | Audio | NAV | Infotainment 46 02-22-2013 11:23 AM
New tires on a budget jflogerzi Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 01-23-2013 06:32 PM
There goes my MOD'ing Budget RedRocket Scion FR-S / Toyota 86 GT86 General Forum 35 10-19-2012 08:14 AM
