Old 03-06-2017, 11:05 AM   #15
DaBoBo21
Brett
DaBoBo21's Avatar
Drives: ‘94 Supra
Yeah, like I said before, my girlfriend and I ended up using bolts and lock washers we had laying around the garage. I ended up taking my BRZ to a Midus and they torqued it down a little more for me and found no leaks. I suppose that's just how this exhaust is suppose to fit until you replace the front pipe. I too found it difficult to fit the stock bolts and springs. Without a way to compress the springs, it almost isn't possible. We wanted to be better safe than sorry and went with bolts that fit. Thanks for the input, guys.
DaBoBo21 is offline   Reply With Quote
Old 03-06-2017, 01:43 PM   #16
DaBoBo21
Brett
DaBoBo21's Avatar
Drives: ‘94 Supra
On an unrelated note... Love the sound of this exhaust. Videos do not do it justice. Nice aggressive note.
Old 03-06-2017, 02:04 PM   #17
Detroiter
Detroiter's Avatar
Drives: 2014 Scion FR-S Monogram
Couldn't agree more the sound is so much different than any dual exit I've heard. Every video I've tried to take of it makes it sounds okay where in person there is so much low rumble it almost sounds like I have UEL below 2k rpm. I love it
Raven
OFT Stage 2 UEL E85 | Tomei UEL Headers | Catless FP | Greddy Revolution RS Catback | HKS Air Filter | Toyota Badge Swap
Detroiter is offline   Reply With Quote
Old 03-06-2017, 02:37 PM   #18
DaBoBo21
Brett
DaBoBo21's Avatar
Drives: ‘94 Supra
It really does, man.
Old 03-06-2017, 05:24 PM   #19
thecarfilmer
IG: @nickwiththefrs
thecarfilmer's Avatar
Drives: 2016 Scion FR-S Halo
Oh, that makes sense!
Damn, well they certainly don't make installing this easy, do they?
@thecarfilmer how did you install yours? Any issues?
I had an Invidia front pipe at the time. Neal did it no problem. Not sure if there is a difference between a stock and aftermarket fp
thecarfilmer is offline   Reply With Quote
The Following User Says Thank You to thecarfilmer For This Useful Post:
DaBoBo21 (03-07-2017)
Old 11-23-2017, 01:32 PM   #20
Brzxton
Drives: 2015 Subaru Brz
Having trouble putting on the rubber hanger on the exhaust. Any tips?
Edit: figured it out just out tons of soap
Brzxton is offline   Reply With Quote
The Following User Says Thank You to Brzxton For This Useful Post:
DaBoBo21 (11-28-2017)
Old 11-28-2017, 10:52 AM   #21
DaBoBo21
Brett
DaBoBo21's Avatar
Drives: ‘94 Supra
Yeah, I ended up using some WD40 to get that last hanger on. It was a b*tch for sure.
Old 12-03-2017, 07:32 PM   #22
elgin63
Drives: 2017 BRZ
I had the same problem.
I dont have stock bolts anymore.
How can I get stock bolts and whats the size?
Thank you
elgin63 is offline   Reply With Quote
Old 12-03-2017, 11:08 PM   #23
DaBoBo21
Brett
DaBoBo21's Avatar
Drives: ‘94 Supra
Thank you
I ended up using the bolts provided by Greddy for the connection between the FP and MP. In addition, I used two lock nuts/ washers just to be sure the bolts wouldn’t come loose. You’re not going to get a flush mount because the Greddy MP isn’t going to fit over the donut of the stock FP. Just do your best to secure the connection so there’s no leaks. I’ve had mine on since March and everytbing is still secure with no leaks.
Old 12-04-2017, 04:33 AM   #24
elgin63
Drives: 2017 BRZ
Thank you. But I wondering where can I order stock bolts because I wanna order an aftermarket front piep...
Old 12-04-2017, 08:38 AM   #25
DaBoBo21
Brett
DaBoBo21's Avatar
Drives: ‘94 Supra
You could go to your local Subaru and talk to the parts department, I'm sure they may be able to help you. Otherwise, you're going to have to do some digging on Google or see if someone on here could spot you the bolts if they're no longer using them.
Greddy Supreme SP Exhaust & Revolution RS Single Exhaust Evasive Motorsports Groupbuys 119 01-31-2017 01:53 PM
WTB: GREDDY REVOLUTION RS EXHAUST thecarfilmer Want-To-Buy Requests 0 10-30-2016 09:23 PM
Single Exit exhaust (Passenger Side Exit) SlammedSilly Engine, Exhaust, Transmission 25 06-09-2016 12:17 PM
Greddy Revolution RS Single Exit Exhaust Duhrell Want-To-Buy Requests 1 06-04-2016 06:25 PM
FS : Greddy Single Exhaust Revolution Rs (local pickup only) Chrisgalactic Engine, Exhaust, Bolt-Ons 36 03-07-2016 01:16 PM
