Old 09-20-2016, 10:35 AM   #757
puma
crew chief
puma's Avatar
Drives: Race car FR-S
did you have the time to weight the stock roof after all?
puma is offline   Reply With Quote
Old 09-20-2016, 09:25 PM   #758
mrk1
Drives: Sterling BRZ Ltd
Completely forgot, Im away for this week so maybe when i get back
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 02-26-2017, 04:08 PM   #759
mrk1
More liters maybe
The Build Thread
The Following 3 Users Say Thank You to mrk1 For This Useful Post:
DustinS (02-26-2017), ILLSMOQ (02-26-2017), rookie (02-27-2017)
Old 03-04-2017, 04:35 PM   #760
mrk1
FA20 is sold and ready to go.
The new heart arrived quicker then expected, this is a Ford 3.7 V6 from a '14 Mustang. I came across this brand spanking new one for a steal. 305 hp 280 tq
I'm trying to liquidate all my turbo stuff first so no real quick progress on this but Im excited to have finally picked a motor.
The Build Thread
The Following 4 Users Say Thank You to mrk1 For This Useful Post:
DustinS (03-06-2017), Guff (03-04-2017), OND (07-02-2017), solidONE (03-05-2017)
Old 03-05-2017, 02:22 PM   #761
mrk1
Rough test fit, hit where I expected, plenty of room where I wanted it.
The Build Thread
Decay107 (03-05-2017), DustinS (03-06-2017), RIP.S2000 (03-31-2017), venturaII (03-05-2017)
Old 03-06-2017, 06:34 AM   #762
GT86Olli
Drives: GT86 Inferno Orange
Why this engine and not a turbo or supercharger?
GT86Olli is offline   Reply With Quote
Old 03-06-2017, 10:38 AM   #763
mrk1
I've had at least 2 turbo setups on this car, just looking for something new and different. As the old saying goes, there's no replacement for displacement.
The Build Thread
Old 03-06-2017, 02:04 PM   #764
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Compact 60 degree V6, ~300 bhp, ought to be sweet.
Old 03-08-2017, 08:25 AM   #765
mrk1
I'm hoping to make a few more HP. By the time it's running it will have headers, exhaust, intake and a tuned standalone. Maybe something more exciting then pump 93 if I feel up to it.
The Build Thread
The Following User Says Thank You to mrk1 For This Useful Post:
venturaII (03-10-2017)
Old 03-26-2017, 07:35 PM   #766
mrk1
Finally getting back to some cage work. Trying out door bar designs, I like how this is looking.
The Build Thread
DustinS (03-27-2017)
Old 06-18-2017, 08:00 AM   #767
mrk1
Cage is just about done, now back onto the engine swap. Cutting up a 3.5 FWD oil pan, it looks like a better starting point then the rear sump Mustang pan.
The Build Thread
Old 07-02-2017, 04:59 PM   #768
mrk1
Test fit the engine and trans, found more things that need to move but its progress.
The Build Thread
Lonewolf (07-02-2017)
Old 07-04-2017, 11:53 AM   #769
Brzzee
Brzzee's Avatar
Drives: 2015 Subaru BRZ WRBP Limited 6MT.
I noticed the 3.7 water-to-oil cooler is off the engine. Could you please post a picture of its rear (i.e. the mating surface between the cooler and its mount on the engine)?
I'd like to compare it to the 2012+ 5.0 Boss Mustang cooler kit I have on my bench for my BRZ oil system cooler project (2 qt accusump install, filter relocate, and cooler).
The Mustang cooler has water inlets that are bent as well as the block mounting flange has a 270 degree lip that protrudes from the mounting flange's surface. The straight inlet/outlet and a flat rear flange would make my life much easier.
Appreciate the help as I can find nothing on the Net that shows the rear of the cooler.
If it will be a better fit for my adapter, and you're not going to use it I'll buy it from you.
Thanks
Brzzee is offline   Reply With Quote
Old 07-04-2017, 12:17 PM   #770
Brzzee
Brzzee's Avatar
Boss Mustang Cooler Detail
These two images show the inlet/outlet configuration and the rear with lip.
AMR Performance: How to remove the factory bumper (walk-through images inside) AMR Engine, Exhaust, Transmission 9 04-10-2013 07:45 PM
86 Modelista walk around and GT Limited SoCal_86 Scion FR-S / Toyota 86 GT86 General Forum 3 04-24-2012 11:53 AM
