Old 02-28-2017, 11:13 PM   #1
186
186's Avatar
Drives: 2013 White MT BRZ
Any diy for Replacement window glass ?
Hello guys , someone recently has thrown a spark plug through my driver side glass window when it was parked at my complex for no reason so now I am stuck trying to replace the window .. I have already have the replacement glass window just seeing if there where any diy on this as I have no idea what to do !thanks in advance
2013 White MT BRZ
186 is offline   Reply With Quote
Old 03-01-2017, 12:07 AM   #2
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
It's fairly straight forward since its the entire assembly. Take the door panel off while unclipping the electronics and sliding out the cable on the door handle. Then peel the plastic back carefully. You should see where the bolts to undo and then repeat in reverse.
Did you get OEM glass as a replacement?
Old 03-01-2017, 02:32 AM   #3
Service manual>Vehicle Exterior>WINDOW / GLASS>POWER WINDOW REGULATOR MOTOR
Click the link on my sig.
FLYFISHR (03-01-2017), Photomikes garage (06-07-2018)
Old 03-01-2017, 02:36 AM   #4
186
186's Avatar
Thanks guys I bought one that looks similar to this one http://m.ebay.com/itm/2013-2015-SCIO...257Ciid%253A12 is there anything else I would require?
2013 White MT BRZ
Old 03-01-2017, 02:42 AM   #5
186
186's Avatar
Do I need anything else except for my glass window and tools of course ? My window Motor regulator and everything was working fine before the glass got broken so is the glass window all I need or do I need any new parts from Subaru ?
2013 White MT BRZ
Old 03-01-2017, 02:52 AM   #6
If you're careful with a razor blade you can cut the butyl adhesive and reuse the vapor barrier. That's about it.
Old 05-03-2017, 07:43 PM   #7
186
186's Avatar
Finally got to it today lol .. but my only problem is I took out all of the bolts and everything that I needed too to prepare to place the new window but my major issue is that I can't get the whole glass window to slide in the door so I can bolt it up ... it keeps touching the window trim so I can't slide the glass in all the way to bolt it up .. I was thinking of removing the painted aluminum part of the door but it's to much work and I know there's a way to just slide it in .. any pointers will be wonderful .. I was going back tom to see what can be done wanted to post here first
2013 White MT BRZ
Rear Window Glass MicheleAbbate Exterior Parts (Aero, Lighting, Etc.) 26 12-21-2020 11:08 AM
Door window replacement? zypher10 Issues | Warranty | Recalls / TSB 11 12-26-2016 07:54 PM
Rear quarter glass smashed.. Replacement advice please kev60625 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 14 10-15-2016 03:26 PM
FS: OEM Window glass and mechanisms MicheleAbbate Exterior Parts (Aero, Lighting, Etc.) 41 05-17-2016 08:15 PM
WHAT COLOR IS THE FACTORY TINT IN THE WINDOW GLASS? White64Goat BRZ First-Gen (2012+) — General Topics 3 10-13-2012 12:15 AM
