Old 02-27-2017, 10:25 PM   #1
VoltsFRS2013
VoltsFRS2013's Avatar
Drives: 2022' GR86 Premium 6MT
Exhaust Systems for below $600
Turning 18 in about a week and having some money saved up I was thinking about making a move on an Exhaust kit, the one i had been looking at in particular was the Mxp Comp RS Catback which I believe is being sold exclusively through FT86SpeedFactory. I watched the FT86 speed factory's installation and demo and they sounded and looked pretty neat. Does anyone here have experience with those in particular who can give me a personal review on them or even a heads up on more systems around that $599-$650 range? I'd appreciate it! thank you so much.
Here's a link to the product I had mentioned above. http://www.ft86speedfactory.com/mxp-...l#.WLTtNG8rKUk
VoltsFRS2013 is offline   Reply With Quote
Old 02-28-2017, 09:57 AM   #2
Timmy_Jones
Spun
Drives: 23' Supra
Go to eBay or Amazon and search 'Manzo' .... they have a few different versions. From memory they have.
Type 1 - similar to the Q300
Type 2 - Similar to a greddy exhaust, not sure which one, but its 2.75" piping and VERY loud with a UEL...that said, I own this and love it
Type 3 - Similar to #2 above, maybe a bit quieter? Not sure...
I don't think any of these are more than $400
Timmy_Jones is offline   Reply With Quote
Old 02-28-2017, 10:07 AM   #3
Clee
Clee's Avatar
Drives: 2017 Toyota 86
you have so many choices/combo to choose from in that price range!
Invidia N1 catback
Tsudo Straight Pipe
Megan Racing
etc.. etc...
Don't forget that you can go with axle-backs too/muffler delete. Really depends on what your goals are for the future with your exhaust set up.
Clee is offline   Reply With Quote
Old 02-28-2017, 10:29 AM   #4
carsebuco
How do I shift?
carsebuco's Avatar
Drives: '13 GBS BRZ
Nameless Axleback is the way to go... it sounds like a horny beast chasing it's prey down the forest
carsebuco is offline   Reply With Quote
The Following 2 Users Say Thank You to carsebuco For This Useful Post:
Clipdat (02-28-2017), humfrz (02-28-2017)
Old 02-28-2017, 10:38 AM   #5
Johnders2586
I have the Comp RS- It sounds good IMO, it can be a little "boomy" inside the car with a lot of low frequency noise, but that's subjective. I recently added a header and its relatively loud, if you plan on doing more exhaust work down the road (front pipe, header etc) id recommend something quieter to start. Unless of course you want it loud. I have put an exhaust on every car I've owned and this is probably the loudest of them all on the inside of the car.. But its a solid exhaust for the $$
Johnders2586 is offline   Reply With Quote
Old 02-28-2017, 12:37 PM   #6
I've been happy with this one.
* adds a bit of growl to the exhaust note
* well made
* easy to install
* very little drone
I suggest the 2.5" piping and 5" mufflers.
humfrz is online now   Reply With Quote
Old 02-28-2017, 01:07 PM   #7
renfield90
The Stig's German cousin
18? If you're planning to go to college, save that money. If you're not, or you are going but enjoy making poor financial choices in your life, continue.
Personally, just get a muffler delete. Much cheaper solution to "I want this thing to make noise." You could probably find one used for $100, spend the $500 left on an OFT and start saving for a header. Boom, you get noise and more power.
The Following User Says Thank You to renfield90 For This Useful Post:
SCQTT (03-03-2017)
Old 02-28-2017, 01:23 PM   #8
Bowen
Powered by Crickets
Bowen's Avatar
Drives: 14' SWP MT Limited BRZ
OP check out the MXP RS exhaust over at FT86 SPeed Factory, they sound wicked for the price, and look really good too.
Build Thread / OFT Stage 2, Tomei UEL, Perrin Resonated, ST Coils, 2 Sets of Wheels, Rally Armor, TOMS Tails.
Bowen is offline   Reply With Quote
Old 02-28-2017, 01:26 PM   #9
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
Yonaka makes a decent exhaust for $350. I had one on my old Integra. My sister drives it now and it's still holding up well. Probably close to 50k miles at this point.
http://www.yonaka.com/Yonaka_13_17_S...p/ymcb-frs.htm
BigTuna is offline   Reply With Quote
The Following User Says Thank You to BigTuna For This Useful Post:
Old 02-28-2017, 01:28 PM   #10
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Another vote for a muffler-delete pipe, save your money for beer.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 02-28-2017, 01:35 PM   #11
MurderousPandas
MurderousPandas's Avatar
Drives: 2013 Scion FRS
Why not headers? Get some more noise and make more power. If you want just noise, you should've got a Honda.
"Chasing speed with patience"
MurderousPandas is offline   Reply With Quote
Old 02-28-2017, 01:36 PM   #12
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
Even better than that, drop your stock header, bash the cat out, have a local with a tactrix cable flash on the OFT Stage 2 EL header map, (93 octane if it's available,) and have a local exhaust shop make an axleback for you to taste.
Total cost: a set of head gaskets, a 6 pack for the local with the cable, and $100 to support a local business....AND it'll be quick!
JazzleSAURUS is offline   Reply With Quote
Old 02-28-2017, 01:52 PM   #13
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
I got parts online and made custom cat-back at local shop. Came out <$500
Old 02-28-2017, 02:35 PM   #14
JazzleSAURUS
Image isn't loading for me, that's a good way to go though!
Most local shops will have parts they like to use, and can to decent work with stainless.
Remember: mandrel>pie cuts>crush bends.
Exhaust Systems PECEOUT Engine, Exhaust, Transmission 13 01-25-2017 03:28 PM
exhaust systems joshkaspr Engine, Exhaust, Transmission 11 03-28-2014 11:32 AM
Volunteers for exhaust systems ChristosG CANADA 9 03-08-2013 08:37 PM
Exhaust Systems hunter3232792 Engine, Exhaust, Transmission 23 12-10-2012 06:14 PM
