| Software Tuning Discuss all software tuning topics. |
Looks like i screwed for my turbo tune
Thanks a lot of
#2 | |
Drives: FT86
Is your maf housing same size as the stock maf housing diameter. If you maf housing is a larger diameter then i think you maf scaling is incorrect. For bigger housing diameter you should have larger flow numbers for same volts. standard injectors, is scaling correct Check you direct injection open tine is not more than about 6m/s and your ports about 15m/s that about the limits you want with some in reserve. maybe use the VGI maf scaling tool its much easier than YIKES http://www.romraider.com/forum/viewtopic.php?t=10481 maybe also look at these tunes for early SBD turbo kits, think they were about 7 psi should give you some ideas. just scroll to top of page for tunes http://www.ft86club.com/forums/showthread.php?p=1855197 Last edited by steve99; 02-26-2017 at 07:27 PM. |
#3 | |
If i want open loop to rich,how should i do? |
#4 |
Drives: UK GT86
Have you changed the MAF Limits and Load Limits?
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | steve99 (02-27-2017) |
#5 |
"Looks like i screwed for my turbo tune"
#6 |
Drives: 2013 satin white brz limited
#7 |
#8 |
yes i did~ attached the file
#9 |
Drives: UK GT86
.: Stealth 86 :.
#10 |
#11 |
Drives: UK GT86
You can see in the photos that your engine load limits 1 and 2 (probably A and B in Romraider) are still stock.
.: Stealth 86 :.
#12 |
Drives: FT86
#13 | |
Drives: FT86
OP you will need to change 4 limit tables maf g\s limit to say 500 g\s overall load limit to say 4 load limit per rpm tables A and B to use higher load limits at rpm |
#14 |
i'm sure i did it.
| Vishnu OFT Tune Coming Soon for the SBD Turbo Kit! | spdbydesign | Software Tuning | 43 | 11-21-2018 02:15 PM |
| B01D 6AT SBD Turbo Tune Questions *Tune Attached* | Pro60modman | Software Tuning | 6 | 09-05-2016 10:04 PM |
| FRS/BRZ Turbo Tune | teddydoggy | Great Lakes | 4 | 09-18-2015 12:17 AM |
| Greddy Turbo Tune | jhusey | Forced Induction | 2 | 11-06-2014 01:42 PM |
| turbo tune dfw | bjun | Southwest | 31 | 10-22-2014 01:10 PM |
