Old 06-28-2012, 09:27 PM   #169
Lonewolf
Lonewolf's Avatar
Drives: Moped
Originally Posted by NRGBalanced View Post
I picked up a stethoscope some time ago when I was trying to diagnose a pulley bearing issue on another car, and I took it out to the BRZ. I hunted around that side of the car until I came upon this spot with the probe:
The chirp at this point finally came into the earpieces of the stethoscope and was matched with the low-frequency tapping I had heard while touching the probe to the other metal parts in that area.
It sounds like the chirp is the result of the insulation and metal components in the DI pump area acting like a high-pass filter, so that we only hear the highest pitch of the tapping.
I am not a skilled diagnostician, so take this with a grain of salt. Maybe someone with better ears will go poke around in this specific area.
I'm glad someone took the time to scope this sound...
Old 06-29-2012, 12:13 AM   #170
eriktherod
Drives: 2013 Scion FR-S Firestorm Red MT
I started the car up a few minutes after coming home and I noticed the chirp noise is definitely there from the start but goes away within 15-30 seconds and all I hear is the sound of the belts (more of a squeaky noise than the chirp).
eriktherod is offline   Reply With Quote
Old 06-29-2012, 02:01 AM   #171
Razz
Razz's Avatar
Drives: Fast
Originally Posted by taosracer View Post
Idler pulley installed today, drove home...
Complete FAIL
No change at all, still chirping away after it warmed. I'm feeling like an idiot because I had confidence in the tech's diagnoses.
Stupid cricket sound.....
Not necessarily... The work with corporate engineers. They wanted to eliminate this as the source of the problem.
Razz is offline   Reply With Quote
Old 06-30-2012, 01:29 AM   #172
YukiHachiRoku
Lex Luger
YukiHachiRoku's Avatar
Drives: 2004 GS430
Originally Posted by YukiHachiRoku View Post
Thread is on my radar, but I'm not sweating it too much, yet....
ok, my car vibrates, make funny rattling noises at WoT... wtf? anyone else having this problem? I'm about to take it in and let them check it out for awhile...
YukiHachiRoku is offline   Reply With Quote
Old 06-30-2012, 11:38 PM   #173
xcelir8brz
Drives: 2013 BRZ Limited
I have crickets! Ugh. 1900 miles in my 6AT BRZ.
xcelir8brz is offline   Reply With Quote
Old 07-01-2012, 01:31 AM   #174
NRGBalanced
NRGBalanced's Avatar
Drives: '13 Subaru BRZ Limited WRB
Got a different kind of chirp today. We've identified that the A/C compressor clutch kicks on and off a lot, but my car with 1300 miles on it just started chirping when the compressor clutch engages and the car is under load (in gear, 3-4k RPM).
It's driving me crazy because the compressor cycles every 5 seconds at times. I know it's something to do with the A/C because the sound went away when I turned the A/C off.
NRGBalanced is offline   Reply With Quote
Old 07-01-2012, 01:43 AM   #175
Pscylo
Pscylo's Avatar
Drives: Raven FR-S
I have had a bucket of fish bait hanging out under my hood at idle from day 1 with less than 20 miles on the car. Only time I hear it is when I am idling next to something for it to reflect the noise back to me, and the audible noise goes away with any increase in RPM.
Pscylo is offline   Reply With Quote
Old 07-01-2012, 02:14 AM   #176
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
My engine makes noises... and the car vibrates sometimes. The noises get louder as I increase the throttle and RPM's. Also, the vibrations go up in the same way.... Should I take it to the dealer and get it cheeked out?
Ladies and gentlemen, take a deep breath... Some people are trying too hard to find something wrong in the car and are reporting things that are normal (vibrations, sounds). I am of the group that thinks that for example, the cricket noise is an unintended consequence of the DI, not anything that will affect reliability,driveability,longevity of this car. (I might be wrong, but that's what I am sensing from all of these threads)
In the age we live in right now, car manufacturers spend a LOT of R&D time and money, trying to make the ride as smooth as possible, removing the "feel" from the drive (removing the noises and vibrations away from the driver). THIS car that we bought is a sportscar. It was designed and intended to let the driver know and feel those sounds and vibrations, and that is a good thing.
NOW, this car is not perfect nor are the companies that made it so obviously, some cars will have defects and warranty repairs will be made. I am by no means trying to say that all cars are perfect and have no problems.
But please STOP trying so hard to find all of those defects and enjoy the damn car. When REAL issues arise, take it to the dealer and get it taken care of.
The Following 3 Users Say Thank You to Sportsguy83 For This Useful Post:
b.e (07-01-2012), illmatic (07-01-2012), MRZ415 (07-03-2012)
Old 07-01-2012, 02:47 AM   #177
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
FR-S and BRZ have both been verified by the techs that worked and designed the engine that the cricket chirps is not intentional and something is wrong.
On another note, CU2MIKE was cleaning my car and a cricket literally jumped out of the soap and died - I would have been ecstatic and cracking up if that was the chirping noise rofl!
The Following 2 Users Say Thank You to Bonburner For This Useful Post:
Sportsguy83 (07-01-2012), YukiHachiRoku (07-02-2012)
Old 07-01-2012, 03:01 AM   #178
Brimford
Drives: Whiteout / MT FR-S
So what is the decision on this, should i go to the dealer and say something, or just sit back and wait for a recall? I definitely don't want the car to be experimented on especially when my only problem is a noise that I have no idea if it's even causing me problems. The car runs great, and sounds amazing.
Brimford is offline   Reply With Quote
Old 07-01-2012, 03:12 AM   #179
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
I'm planning on waitin a bit 'till I hear some nice results on the forums - I don't drive as often as other people (I won't drive to work/school bc parking is $) and I can just skateboard everyday for free.
Plus gas is stupid expensive over at Santa Barbara.
Since she isn't used much nor too hard I'll sit back for a bit ..
The proper means of dealing with the engine has not been identified.
I will be taking it in for the rattling noises soon enough though.
Old 07-01-2012, 03:16 AM   #180
Brimford
Exactly, im seeing people going in to get things fixed and so far it seems like the techs have screwed up the cars or have just been wasting our times. I can live with a chirp as long as its not detrimental for me..
Sorry about gas where you are at bud, i just got premium for 3.19 today so im happy
Old 07-01-2012, 03:19 AM   #181
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
Man, I filled gas at 3.79 and that was 'cheap' back in Orange County; SB borders 3.99 as cheap.
But yeah - waiting it out seems like the better choice, although you can pray to get lucky like Whiteout FRS and get a brand new FRS replacement in place of the older FRS!
Yeah, I'm super jealous, I want to start fresh after what happened to mine, ugh.
Old 07-01-2012, 03:34 AM   #182
Sportsguy83
Drives: Limited BRZ
Can you point me in the direction of that Official word, not from a tech at the dealer, but from the Engineers who designed the engine? Not trying to be a smarta$$, just genuinely asking.
Techs at dealers can be trusted similar to salesman. They feed a bunch of crap to customers. When I read an official word from Subaru or Toyota, then its different.
Now go back to my post. As I said, neither the companies or the car are perfect. There will be cars that will have issues. I am just saying, some people are complaining about some silly stuff, just because it is the first time they hear it.
Now go back to my post one more time. I said when REAL problems arise, warranty work will be done. So, when this "Issue" is REAL, and a recall happens, I will gladly take my car to the dealer and get it fixed. At this moment, I will not worry about it and enjoy my car which is working great.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Fenrir (07-01-2012)
Hard shifting into first gear; normal? blalor Engine, Exhaust, Transmission 54 08-31-2017 10:57 PM
Idle issue? yayforaddison Issues | Warranty | Recalls / TSB 891 07-14-2016 11:42 AM
What function can it be used for, the idle button place yuli8466 Cosmetic Modification (Interior/Exterior/Lighting) 50 01-29-2013 04:17 PM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 01:00 PM
Scion goes normal terrypm Other Vehicles & General Automotive Discussions 21 05-02-2012 11:16 AM
