Old 02-22-2017, 10:09 AM   #15
STV3
Señor Member
STV3's Avatar
Originally Posted by 2017-BRZ View Post
alternative facts ha ha..
93 octane 1/2 tank fuel..30 dgree F...6K shift
under 6 seconds... stock.
2017 owners welcomed to test and verify..
I can't lay claims for earlier model years.
Highway speed passing no problems either.
Well in that case my mountain bike too can accelerate in under 6 seconds....
STV3 is offline   Reply With Quote
Old 03-11-2017, 02:11 PM   #16
2017-BRZ
Drives: 2017Crystal White Pearl BRZ Limited
Originally Posted by Ernest72 View Post
OP having both a 16 BRZ and an 04 modded WRX I can understand both sides. The car is not slow its just NA. None of that surge of power from a turbo. If you really get used to that surge than you will miss it. Both are fun, but I have to admit to BRZ is more fun and playful and the steering is great. 250 HP stock would have been perfect for this car. For now I am stock on the warranty, but in the future I'll bump it up some. These cars are more fun in the twisties than any highway pulls.
I had a turbo car.. a very good turbo car. VTG 997TT.
I know what acceleration is 0-60 in the 3's...
All I'm saying is power to weight ratio is often overlooked with HP numbers on paper and 0-60 times being the forefront only "BIG DEAL" of a great driving experience.
And for experienced drivers we know there is much more to it than this.
Get yourself a good set of tyres to put all the traction to the pavement and learn the driving habits of the car.
It's not about mashing the pedal..that wont get you best acceleration not at least until you arrive in the upper range revs of about 5K..
rev match consistently and utilize 4th gear efficiently..
2017-BRZ is offline   Reply With Quote
Old 03-11-2017, 11:56 PM   #17
Poodles
Drives: 2015 Series.Blue
Originally Posted by Stephen W. View Post
I was not aware that the “Twins” were “Flex Fuel Vehicles” from the factory.
I know that many feel there is only an up side to ethanol fuels. However, ethanol laced fuels can and have caused problems with some vehicles. I speak from personal experience. There is more to making a FFV than adding a sensor, a new tune and e85.
FFVs are specially designed to run on regular unleaded or any ethanol fuel blend up to 85%. It is my understanding that any part of the vehicle which comes in contact with such blended fuel has to be upgraded to tolerate said fuel. Normally, these parts include an upgraded fuel tank, the fuel lines, fuel injectors, fuel pump components, etcetera with ethanol compatible parts as well as the aforementioned sensor and ECU tunes.
I’m not wanting to ignite another e85 debate, there are already plenty of those on this and other forums. I’m just stating my concern on using fuels that as yet are not recommended by the factory. It may well be that many of the components in the “Twins” are already ethanol compatible. But if that were the case why would the factories not advertise the fact?
It's simple. Most new cars are designed with a high ethanol tolerance now because E10 is so prevalent. The extra cost of the flex fuel sensor and tune simply isn't there, especially when Subaru doesn't have a single flex fuel vehicle in their lineup. You don't advertise that your car is only part way flex fuel capable, that's stupid...
These cars have been around long enough and for enough miles already to prove that E85 tunes are safe. The tune can only get so much out of it though, so true 85% ethanol isn't even needed, meaning that it's quite safe.
If you are worried about it, you can add the sensor and tune, and then it operates just the same as any other flex fuel car.
Old 03-16-2017, 04:21 PM   #18
Xxyion
Lowly Cartuber
Xxyion's Avatar
Drives: 2016 BRZ, 2005 Honda S2000
I'm going to have to agree with OP on this.
But a lot of this i find has to do with the new gear ratio.
My 2016 BRZ is boosted with the Edelbrock SC. It defiently has a lot of kick to it. However i recently test drove a new Series Yellow with PP. Honestly i almost enjoyed it more. If anything i think what "slows" this car down the most is the torque dip. And that can be easily remedied.
I enjoyed it so much that i'm going back to NA and i'll probably just end up making changes to my 2016 MY to replicate what is now stock in the 2017s
2016 Limited MT WR Blue BRZ | Delicious Flash n Go Tune | Delicious Flex Fuel Kit | Nameless 2.5" with 5" Mufflers | JDL UEL Headers | Bayson R Diffuser/Side Skirts | APR Front Splitter | VIS Racing GT Wing | ST Suspension Coilovers | Grammlights Rays 57CR 17x9 +38 | Sumitomo HTR Z iii 235/45/17 |
Xxyion is offline   Reply With Quote
The Following 2 Users Say Thank You to Xxyion For This Useful Post:
funwheeldrive (03-16-2017), NLS8520 (03-17-2017)
Old 03-16-2017, 04:59 PM   #19
reeves
Ethanol content is 15-20% in some stations.. whether that's intentional or by accident, still.. Manufacturers have to account for that.
Also, when the 86 first came out, the official press release said the car won't have a turbo because "there is no room" for it LOL. Wished I framed that article.
Toyota/Subaru knew they were making a car that would be modded to hell by the aftermarket community.. the 86 is very FI and E85 friendly, it's part of the charm.
Old 03-16-2017, 05:15 PM   #20
funwheeldrive
The closest e85 station if 45 minutes away from me.
Old 03-16-2017, 05:27 PM   #21
ktulu7
Drives: 2016 GMC Canyon
I'll just keep rollin' with E0 fuel here in Iowa, which is ironically the land of ethanol. It's funny, but awesome, that just about all the gas stations in Central Iowa I've been to, have 3 types of gasoline: Regular (non-ethanol), Plus/Super/Whatever (same 87 octane but WITH ethanol and cheaper), and Premium (non-ethanol and 91 or 93 octane). 2 out of the 3 pumps will say "NO ALCOHOL" above them. It's peculiar compared to everywhere else in the US and Canada I've been to...
ktulu7 is offline   Reply With Quote
The Following User Says Thank You to ktulu7 For This Useful Post:
~el~jefe~ (03-17-2017)
Old 03-16-2017, 06:29 PM   #22
JohnnieBoy
JohnnieBoy's Avatar
Drives: 13 BRZL/12 Tundra TURD/09 FJR 1300
Originally Posted by gskv View Post
it'll make both happy if the vehicle had 40 more ponies
Originally Posted by Somerandom18 View Post
Headers, e85 and a tune. Problem solved. Hell even just e85 and a tune will do the job. Must say though, my 17 goes from 60-100 real quick. Car is next to stock. Did you keep the engine between 5k and redline at all while test driving? That's where the power is..
Sent from my Pixel XL using Tapatalk
Bought my used 2013 BRZL on January 18th. Had Zach at Delicious Tuning install a stage one tune on Jan 24th. Very noticeable upgrade, smoothed out the throttle and dissipated the flat spot in the torque curve. Then I installed one of their E85 kits and had him re-tweak the map on Feb 14th. Wow... what a difference! Enough to warrant the $1300? I think so... And just enough to hold me over until I come up with the scratch for an Edelbrock!!!
But as is, the car is no slouch. Dialing in suspension, wheels/tires, and exhaust along with a tune also helped... I am still finding myself going on drives for no reason!
JohnnieBoy is offline   Reply With Quote
Old 03-16-2017, 06:44 PM   #23
JohnnieBoy
JohnnieBoy's Avatar
Let me know when that day comes, I will be more than happy to take the Edelbrock off your hands for you!
Old 03-16-2017, 07:23 PM   #24
imnotsureaboutbrz
Drives: between cars...
Man... I wish we had E85.... or 93 octane.... or 91 octane... 90 is the best we get up here, unless you have a stash of Torco.
imnotsureaboutbrz is offline   Reply With Quote
Old 03-16-2017, 07:33 PM   #25
Xxyion
Lowly Cartuber
Xxyion's Avatar
Haha i already have a buyer lined up but if he decides to not go for it i'll let you know!
Old 03-16-2017, 08:09 PM   #26
geezerbrzeezer
Geezer
Drives: 2016 Subaru BRZ Sport Tech
Those four words truly and totally represent the spirit of the 86.
Period.
I don't care whether you assidentally swerved into it, or my genius shamelessly coopted it, but it is irrefutable truth.
geezerbrzeezer is offline   Reply With Quote
The Following User Says Thank You to geezerbrzeezer For This Useful Post:
tacos (03-17-2017)
Old 03-16-2017, 10:12 PM   #27
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
With or without mashing the pedals?
krayzie is offline   Reply With Quote
The Following User Says Thank You to krayzie For This Useful Post:
Old 03-17-2017, 09:43 AM   #28
DarkSunrise
DarkSunrise's Avatar
Originally Posted by Sport-Tech View Post
Agreed - around town it tests out fine, but at 70 mph when you punch it to grab that opening on the freeway, it's just not there - the MX-5 is better in that respect.
Not sure what it feels like from the driver's seat (haven't driven it yet), but in measured tests the new Miata is actually significantly slower above 60 mph. Over 1 second slower 60-100 and over 3 seconds slower 60-120.
60-100 mph
2013 FR-S: 10.2 sec
2016 Miata: 11.5 sec
60-120 mph
2013 FR-S: 20.0 sec
2016 Miata: 23.7 sec
http://media.caranddriver.com/files/...fr-s-specs.pdf
http://www.caranddriver.com/reviews/...rm-test-review
Originally Posted by nico_rsx View Post
Haha,
Well he also didn't say accelerate to what speed...
Maybe 0-60 KM/H
Or 20-60 MPH
LOL that was my first thought when OP said his car was sub 6 seconds.
Yeah I recently switched to a header that makes less peak HP but completely fills in the torque dip. It's surprising how it can change the feel of the car for street driving. Why swap out your SC though? Seems odd (no offense).
2022 BRZ Build
2013 FR-S Build
The Following 2 Users Say Thank You to DarkSunrise For This Useful Post:
funwheeldrive (03-17-2017), ~el~jefe~ (03-17-2017)
CSG Mike's personal 2017 BRZ build and thoughts. CSG Mike Member's Car Journals 235 09-09-2019 11:03 PM
Detroit Area 2016/2017 Owners Torry@HKSUSA Great Lakes 6 10-18-2017 09:46 AM
Detroit Area 2016/2017 Owners Torry@HKSUSA Scion FR-S / Toyota 86 GT86 General Forum 16 05-31-2017 11:48 AM
Can 2017 owners review new stereo/touchscreen SubieSyncro Electronics | Audio | NAV | Infotainment 77 05-04-2017 10:51 PM
Raceseng Ashiko (Shift Knob) owners...Your thoughts Namuna Cosmetic Modification (Interior/Exterior/Lighting) 15 11-26-2014 02:33 PM
