| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
#29 |
Let's start with you explaining to me the difference between the two. What's your understanding?
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Drambeenie (02-21-2017) |
#30 |
Drives: Black 17 BRZ LT MT PP
They checked the car and said everything is fine. Checked the computer, ran through the gears with a 45 min test drive, said the transmission fluid looks good. If it happens again they said to bring it back.
Sounds like I need to double clutch. Could someone fill me in on this? |
#31 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
Don't really need to downshift to 1st at all for most common driving situations other than to make noise.
I only very rarely go to first other than at a complete stop. Maybe uphill, slowing for an acute switchback. Don't JAM it and you'll be fine. Rev matching has been covered here extensively as well as on Youtube.
"I gotta rock." -- Charley Brown |
#32 | |
#33 | |
| The Following 4 Users Say Thank You to Ultramaroon For This Useful Post: |
#34 | |
If you want a much more detailed description let me know. But in short- rev matching is for smoothing the relationship between the engine and car, whereas double clutching is for smoothing the relationship between the first half and second half of the transmission. Another way to look at it, is the clutch is the synchro between the engine and drivetrain. The synchro is the clutch between input/output parts of the trans. |
| The Following User Says Thank You to wheelhaus For This Useful Post: | Ultramaroon (02-21-2017) |
#35 |
You were much nicer than I was. Maybe my trolldar was off.
#36 | |
Drives: Black BRZ PP on order
#37 |
I think the issue might be the gear selector. I've been driving the car more, but haven't had any awful crunching. Have had some trouble changing into first so I'm monitoring it.
Right now everything seems okay. |
#38 |
The Fail Boat
Drives: CWP S.B.
Change the transmisson fluid to something like motul gear 300 when you have problem next time.
Our transmission is build with tighter tolerance & it can be weird sometimes with stock fluid. |
| The Following User Says Thank You to chaoskaze For This Useful Post: | Drambeenie (03-10-2017) |
| Show us your Custom Roll Cage or Roll Bar and Harness Setup | Black Tire | Tracking / Autocross / HPDE / Drifting | 27 | 02-13-2015 09:59 PM |
| Crunch noise? | winsometang | Issues | Warranty | Recalls / TSB | 9 | 12-02-2014 01:38 PM |
| 6th to 5th Downshift Crunch | jcat5150 | Issues | Warranty | Recalls / TSB | 1 | 04-17-2014 03:41 PM |
| Second Gear Crunch? | NOHOME | Scion FR-S / Toyota 86 GT86 General Forum | 18 | 09-27-2012 02:52 PM |
| 5th Gear and 6th Gear 0% throttle to 80% throttle gear crunch? | kharn83 | Issues | Warranty | Recalls / TSB | 9 | 08-06-2012 07:44 PM |
