Old 02-20-2017, 09:54 PM   #29
Originally Posted by BboyRuda View Post
How does it help? Why not just rev match (without double clutching) like the rest of the gears?
Let's start with you explaining to me the difference between the two. What's your understanding?
Drambeenie (02-21-2017)
Old 02-21-2017, 10:02 AM   #30
Drambeenie
Drambeenie's Avatar
Drives: Black 17 BRZ LT MT PP
They checked the car and said everything is fine. Checked the computer, ran through the gears with a 45 min test drive, said the transmission fluid looks good. If it happens again they said to bring it back.
Sounds like I need to double clutch. Could someone fill me in on this?
Drambeenie is offline   Reply With Quote
Old 02-21-2017, 12:21 PM   #31
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Don't really need to downshift to 1st at all for most common driving situations other than to make noise.
I only very rarely go to first other than at a complete stop. Maybe uphill, slowing for an acute switchback.
Don't JAM it and you'll be fine.
Rev matching has been covered here extensively as well as on Youtube.
Old 02-21-2017, 12:28 PM   #32
spike021
spike021's Avatar
So if you're going to a red light you just rev match till second gear and then just slow to a stop, throw it in neutral till green, and then go to first like normal?
spike021 is offline   Reply With Quote
Old 02-21-2017, 01:08 PM   #33
Nah. There is truly no need to double clutch but it's a nice arrow to have in your quiver. Plenty of instructional stuff out there on the interwebz.
The Following 4 Users Say Thank You to Ultramaroon For This Useful Post:
daiheadjai (02-21-2017), Drambeenie (02-21-2017), Psilox (03-09-2017), wheelhaus (02-21-2017)
Old 02-21-2017, 07:21 PM   #34
wheelhaus
wheelhaus's Avatar
Because the trans has synchros, in theory you could just mash the stick into the gear you want, but the synchros are doing a lot of work to get into the low gears above 10-20mph because there is a large rpm gap. Upshifting is easy, things naturally want to slow down, but downshifting requires the synchros to accelerate parts of the tranny to higher speeds, this is a harder process. Double clutching bypasses the synchros so getting past the rpm gap is done by the clutch/engine which has way more authority than the tiny little synchros.
If you want a much more detailed description let me know. But in short- rev matching is for smoothing the relationship between the engine and car, whereas double clutching is for smoothing the relationship between the first half and second half of the transmission.
Another way to look at it, is the clutch is the synchro between the engine and drivetrain. The synchro is the clutch between input/output parts of the trans.
The Following User Says Thank You to wheelhaus For This Useful Post:
Ultramaroon (02-21-2017)
Old 02-21-2017, 09:03 PM   #35
You were much nicer than I was. Maybe my trolldar was off.
Old 03-05-2017, 08:32 PM   #36
chuckseabreeze
Drives: Black BRZ PP on order
Curious how the transmission is holding up...
chuckseabreeze is offline   Reply With Quote
Old 03-09-2017, 02:49 PM   #37
Drambeenie
Drambeenie's Avatar
I think the issue might be the gear selector. I've been driving the car more, but haven't had any awful crunching. Have had some trouble changing into first so I'm monitoring it.
Right now everything seems okay.
Old 03-10-2017, 04:26 PM   #38
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Change the transmisson fluid to something like motul gear 300 when you have problem next time.
Our transmission is build with tighter tolerance & it can be weird sometimes with stock fluid.
The Following User Says Thank You to chaoskaze For This Useful Post:
Drambeenie (03-10-2017)
Show us your Custom Roll Cage or Roll Bar and Harness Setup Black Tire Tracking / Autocross / HPDE / Drifting 27 02-13-2015 09:59 PM
Crunch noise? winsometang Issues | Warranty | Recalls / TSB 9 12-02-2014 01:38 PM
6th to 5th Downshift Crunch jcat5150 Issues | Warranty | Recalls / TSB 1 04-17-2014 03:41 PM
Second Gear Crunch? NOHOME Scion FR-S / Toyota 86 GT86 General Forum 18 09-27-2012 02:52 PM
5th Gear and 6th Gear 0% throttle to 80% throttle gear crunch? kharn83 Issues | Warranty | Recalls / TSB 9 08-06-2012 07:44 PM
