Old 02-18-2017, 04:52 PM   #1
Dake
Dake's Avatar
Easy REAR Wheel Stud replacement - Shade Tree Mechanic Style
I made the idiotic mistake of cross-threading a lug nut one day and ruining a stud. I ran a die around the bolt which worked temporarily, but there wasn't much meat left for the nut to grab, so I knew I had to replace it.
All the tutorials I read or watched suggested the only way to replace the stud required pulling the hub off, but I'm here to tell you IT AINT TRUE! Assuming you are replacing the stud with OEM (or only slightly longer) hardware, it's a thirty minute job and that includes putting your tools away.
Step 1: Remove wheel
Step 2: Remove brake caliper (do not let hang from brake line)
Step 3: Remove brake disk/drum
-Steps one through three are pretty simple, but if you haven't done it before, there are other tutorials you can reference. It took me longer to get the disk/drum off thanks to rust around the hub than to do the rest of the job. I little soak with some PB Blaster, and wacks with a rubber hammer and we were in business.
Step 4: remove the RIGHT emergency brake shoe. There are three springs and a clip, all very easy to manage. I took pics of all the components for easy reassembly (but you seriously shouldn't mess this up).
-Here's everything removed and placed to the side for reattachment.
Step 5: Position the offending wheel stud at the one to two o'clock position. This gives plenty of room for the stud to pop out of the back of the hub.
Step 6: Whack the stripped stud with a hammer - a couple good shots and it should pop right out the back, bounce off the floor, and roll under some shelves in your garage for you to forget about until you move three years from now.
-Congratulations, you now have an empty hole!
Step 7: Put your shiny new stud in said hole, throw a stack of washers on the lug, put the lug nut on (don't cross-thread it!), and tighten it down. This will draw the knurled section of the wheel stud into the hub. If you don't have open-ended lug nuts you may need to back the nut off and add an extra washer or two to get the stud fully seated.
Step 8: Put everything back together and make it look pretty like the first pics up top. Put the disk back on. Put the brake caliper back on. Put your wheel back on. Torque everything to manufacturer recommended specifications, etc.
Step 9: You're done. Why are you still here?
I have no idea if this will work on the front because I haven't been dumb enough to strip a front bolt... yet. Good luck, don't break yourself or your car.
UPDATE (over two years later): After posting this, I stripped a couple more of the OEM butter lugs, so I just replaced them all with this method.
It's even easier on the front wheels. Same basic premise but with fewer small springs and bits to lose.
Dake is offline   Reply With Quote
The Following 5 Users Say Thank You to Dake For This Useful Post:
bcj (08-15-2019), Cole (02-18-2017), e30cabrio (10-07-2020), MJones_RB (05-10-2017), Trefoil (08-09-2017)
Old 02-18-2017, 06:07 PM   #2
number_Un0
Drives: 2013 FRS 10 series #0001
I also stripped one of my studs in the rear and didn't feel like removing the whole hub assembly.
I was able to replace it without having to remove the brake shoe though. I just had to play with the stud a little bit and I was able to squeeze the new stud in.
number_Un0 is offline   Reply With Quote
The Following User Says Thank You to number_Un0 For This Useful Post:
Dake (02-18-2017)
Old 02-18-2017, 09:23 PM   #3
Spinning Sushi
Legend
Spinning Sushi's Avatar
Drives: BRZ Limited
This method won't work if you're replacing your OEM wheel studs with extended ones like from ARP; the wheel hub needs to be removed.
Spinning Sushi is offline   Reply With Quote
The Following User Says Thank You to Spinning Sushi For This Useful Post:
JohnJuan (08-19-2019)
Old 02-18-2017, 10:18 PM   #4
I'm not a fan of hammering anywhere that sends a shock through the wheel bearings. This may be a relatively light tap but I'll leave this result of a pothole strike here. YMMV.
I understand that certain ball joint separation tools can be used as a wheel stud press but I've never had to replace a wheel stud. I've been lucky.
http://www.harborfreight.com/3-4-qua...tor-99849.html
kakacarrotcake (04-26-2017)
Old 02-18-2017, 10:56 PM   #5
Dake
Dake's Avatar
Yeah, I mentioned that it needs to be OEM or only slightly longer.
The forces involved in dropping a nearly 3000 lb car into a pothole at even parking lot speeds are many orders of magnitude greater than what can be delivered by a couple hammer blows.
The Following User Says Thank You to Dake For This Useful Post:
Ultramaroon (02-18-2017)
Old 02-18-2017, 11:42 PM   #6
Not peak forces, unless you're using a rubber mallet. That sharp impact is what ...maybe... does the damage.
edit: ...maybe...
Dake (02-19-2017)
Old 03-01-2017, 12:27 AM   #7
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Same here. I just pulled the rotor off and then rotated the hub til I got the new stud in. No need to remove the brake shoe.
The Following 2 Users Say Thank You to finch1750 For This Useful Post:
Overdrive (10-10-2020), VIP BRZ (03-23-2017)
Old 08-14-2019, 11:39 PM   #8
GrantedTaken
What kind of **** claims this is half an hour.
GrantedTaken is offline   Reply With Quote
Old 08-15-2019, 12:40 PM   #9
finch1750
finch1750's Avatar
If just doing one it basically is. Maybe 1 hour tops?
Old 08-15-2019, 10:10 PM   #10
soundman98
ProCrastinationConsultant
soundman98's Avatar
this is a case of beer, 2 friend, full saturday job for me!
Old 08-15-2019, 11:26 PM   #11
Dake
Dake's Avatar
Well, it's what it took me back when I did it - and I'm nigh on incompetent!
And since this has been resurrected, I'll add that the front wheels can be accomplished in much the same way (if not easier thanks to not needing to remove as much stuff).
Ultramaroon (08-16-2019)
Old 08-16-2019, 01:51 AM   #12
It goes much more quickly if the parts aren't cleaned or lubed before reassembly. I take my sweet time.
Old 08-16-2019, 01:40 PM   #13
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
I just bought the $20 bearing press tool from harbor freight.
Took off wheel, caliper, rotor. Then use the tool to push it out, rotate the hub to push the next one out. There is a small gap without having to remove anything extra on the rear.
Clueless
YamahaR86 is offline   Reply With Quote
The Following User Says Thank You to YamahaR86 For This Useful Post:
Old 08-17-2019, 02:02 PM   #14
GrantedTaken
So, replacing a stud is the same on front and rear?
No weird parking brake issues?
Just remove rotor and pop off the studs?
Wheel stud replacement Dave-ROR DIY (Do-It-Yourself) Guides 267 01-21-2022 09:20 PM
South Bay Wheel Stud Replacement? HachiRo Northern California 4 02-04-2016 05:56 PM
Replacement Windshield w/ blue shade band? hmong337 Scion FR-S / Toyota 86 GT86 General Forum 51 08-27-2015 07:00 PM
anyone know if there's a rear window shade? nycfl123 Scion FR-S / Toyota 86 GT86 General Forum 18 03-07-2014 03:39 AM
Replacement Lug Stud/Wheel Hub swift996 Issues | Warranty | Recalls / TSB 3 08-30-2013 02:58 PM
