#323 |
Drives: 2016 Scion FR-S 6 Spd
thanks so much for the response. and I wanna do a 2JZ swap on my 86 but the research is real lol my only remaining question is what driveshaft and diff and axels did u have to use? (for the 2JZ swap)
#324 |
Drives: 2JZ FRS
Stock rear diff, could go with the full blown 8.8 swap if there are any issues with power. Drive shaft shop pro axle/hub kit, then custom length driveshaft depending on which trans you use
| The Following User Says Thank You to spitfire481 For This Useful Post: | Kris86 (01-31-2017) |
#325 | |
Drives: RHD Gt86
what ever happened to this gear set? did the shop pull through?
Toyota - Making Dreams A Reality
461hp on 91octane - JDL turbo GTX3076r GEN 2 - Mazworx CD009 transmission |
#326 |
Drives: 2JZ FRS
No idea honestly. Started taking so long I went with the tremec instead
#327 |
Drives: RHD Gt86
cool... do u mind telling me who the shop was?
#328 |
Drives: 2JZ FRS
Jacks transmissions
#329 |
Drives: RHD Gt86
so when u plan on taking her to the dyno?
#330 |
Drives: 2JZ FRS
I still have a small list of things to do, then we have to build the firmware and get the car running and driving. then we can tune for power. should only make 650-700whp through the auto, but that's enough to go low 9's, maybe touch an 8 second pass
#331 |
Drives: 2JZ FRS
Well everything is wired. Turned the key and powered the car up for the first time and everything is 100%. Driveshaft is being built and my tuner is coming by next week to build the motec firmware and start the car for the first time
#332 | |
Drives: CBS brz limited
Damn! She's almost there man. I know it's been a long process. You gotta post some update pictures!! Sent from my iPhone using Tapatalk |
#333 |
Drives: 2JZ FRS
I'll be at the shop all weekend so I'll grab some updated pics. Interior is all back in minus a passenger seat. Makes for more space to get in the car and access the harness to make any pinout changes that might need to be made so until it's tuned that'll stay out.
#334 |
Drives: 2JZ FRS
Getting closer. Still need to order a new bumper since this one has a hole in the side from the fa20 exhaust, paint that and the hood. Interior is basically done. Motec dash is in and the car has power and everything works. Just need to get the ecu firmware done and hopefully have it running next week
#335 |
Drives: 2JZ FRS
Started building the exhaust today. Round to oval for ground clearance, back to round and a vibrant muffler in the back
| The Following 3 Users Say Thank You to spitfire481 For This Useful Post: |
#336 |
Drives: 2018 Golf R
Out of curiosity, what was the reason that you kept the piping out of the tunnel?
Parting out HERE
| God's Build | GodSays | Member's Car Journals | 13 | 04-17-2013 01:31 PM |
| My build... well some of it | cruzinbill | Electronics | Audio | NAV | Infotainment | 41 | 04-01-2013 04:02 PM |
| STX build | Evil86 | Tracking / Autocross / HPDE / Drifting | 2 | 01-08-2013 03:40 PM |
| My BRZ build | brztj | Mid-Atlantic | 3 | 09-08-2012 05:52 PM |
