Old 01-30-2017, 08:58 PM   #323
driftjayGT86
driftjayGT86's Avatar
Drives: 2016 Scion FR-S 6 Spd
thanks so much for the response. and I wanna do a 2JZ swap on my 86 but the research is real lol my only remaining question is what driveshaft and diff and axels did u have to use? (for the 2JZ swap)
driftjayGT86 is offline   Reply With Quote
Old 01-30-2017, 11:06 PM   #324
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
Stock rear diff, could go with the full blown 8.8 swap if there are any issues with power. Drive shaft shop pro axle/hub kit, then custom length driveshaft depending on which trans you use
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
The Following User Says Thank You to spitfire481 For This Useful Post:
Kris86 (01-31-2017)
Old 01-31-2017, 02:27 PM   #325
Kris86
Kris86's Avatar
Drives: RHD Gt86
Originally Posted by spitfire481 View Post
Those are $5900 FYI. My set will be all helical and shooting to cost less than the PAR set. They are still working on getting measurements to make the gears as large as possible within the factory case. We sent them spare manual transmissions to work with. Gears, much better bearings, timed synchros for high rpm shifting, etc. we were going to change some ratios around but with the 26" rear tire and the 3.73 diff I can hit 141 in 4th at 8200rpm so that's no longer an issue
what ever happened to this gear set? did the shop pull through?
Toyota - Making Dreams A Reality
461hp on 91octane - JDL turbo GTX3076r GEN 2 - Mazworx CD009 transmission
Kris86 is offline   Reply With Quote
Old 01-31-2017, 02:41 PM   #326
spitfire481
Drives: 2JZ FRS
No idea honestly. Started taking so long I went with the tremec instead
MoTeC
Build Thread
@spitfire481
Old 01-31-2017, 02:42 PM   #327
Kris86
Kris86's Avatar
Drives: RHD Gt86
cool... do u mind telling me who the shop was?
Old 01-31-2017, 02:46 PM   #328
spitfire481
Drives: 2JZ FRS
Jacks transmissions
MoTeC
Build Thread
@spitfire481
Kris86 (01-31-2017)
Old 02-01-2017, 01:14 PM   #329
Kris86
Kris86's Avatar
Drives: RHD Gt86
so when u plan on taking her to the dyno?
Old 02-01-2017, 01:46 PM   #330
spitfire481
Drives: 2JZ FRS
I still have a small list of things to do, then we have to build the firmware and get the car running and driving. then we can tune for power. should only make 650-700whp through the auto, but that's enough to go low 9's, maybe touch an 8 second pass
MoTeC
Build Thread
@spitfire481
The Following 2 Users Say Thank You to spitfire481 For This Useful Post:
BRZGM3 (02-16-2017), Kris86 (02-01-2017)
Old 02-16-2017, 09:30 PM   #331
spitfire481
Drives: 2JZ FRS
Well everything is wired. Turned the key and powered the car up for the first time and everything is 100%. Driveshaft is being built and my tuner is coming by next week to build the motec firmware and start the car for the first time
MoTeC
Build Thread
@spitfire481
The Following 3 Users Say Thank You to spitfire481 For This Useful Post:
BRZGM3 (02-16-2017), djdnz (02-19-2017), Kris86 (02-17-2017)
Old 02-16-2017, 09:38 PM   #332
BRZGM3
BRZGM3's Avatar
Drives: CBS brz limited
Damn! She's almost there man. I know it's been a long process. You gotta post some update pictures!!
BRZGM3 is offline   Reply With Quote
Old 02-16-2017, 09:56 PM   #333
spitfire481
Drives: 2JZ FRS
I'll be at the shop all weekend so I'll grab some updated pics. Interior is all back in minus a passenger seat. Makes for more space to get in the car and access the harness to make any pinout changes that might need to be made so until it's tuned that'll stay out.
MoTeC
Build Thread
@spitfire481
Old 02-18-2017, 11:12 PM   #334
spitfire481
Drives: 2JZ FRS
Getting closer. Still need to order a new bumper since this one has a hole in the side from the fa20 exhaust, paint that and the hood. Interior is basically done. Motec dash is in and the car has power and everything works. Just need to get the ecu firmware done and hopefully have it running next week
MoTeC
Build Thread
@spitfire481
Old 02-21-2017, 08:56 PM   #335
spitfire481
Drives: 2JZ FRS
Started building the exhaust today. Round to oval for ground clearance, back to round and a vibrant muffler in the back
MoTeC
Build Thread
@spitfire481
civicdrivr (02-22-2017), DustinS (02-21-2017), Summerwolf (02-21-2017)
Old 02-22-2017, 05:49 PM   #336
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Out of curiosity, what was the reason that you kept the piping out of the tunnel?
Parting out HERE
civicdrivr is offline   Reply With Quote
God's Build GodSays Member's Car Journals 13 04-17-2013 01:31 PM
My build... well some of it cruzinbill Electronics | Audio | NAV | Infotainment 41 04-01-2013 04:02 PM
STX build Evil86 Tracking / Autocross / HPDE / Drifting 2 01-08-2013 03:40 PM
My BRZ build brztj Mid-Atlantic 3 09-08-2012 05:52 PM
