| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#2101 | |
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
#2102 |
Oh and even on 17X9 Weds? What size Federals are you rubbing, I mean running 😈
#2103 |
Drives: LR BRZ Limited
#2104 |
Drives: 2013 BRZ 6mt limited
Nice set up!!! Always cool to see nice 86 in TN.
#2105 |
Drives: 2017 Subaru BRZ
New wheels & new meat. I'll probably take better photos when the sun is out.
VOLK TE37SL 18x9.5" +40 265/35 Yokohama Advan Neova AD08R Current specs Ride height: 25 1/2" Front 25 3/4" Rear. Measured from the ground through the center of the wheel to the fender Caster: 5.9 Camber: -2.0 Front -1.6 Rear Total toe: 0 Front .08 Rear ![]() ![]() ![]()
| The Following 4 Users Say Thank You to Lust For This Useful Post: |
#2106 | |
#2107 | ||
Drives: '13 SWP GT86
IG @squareddesign
http://www.squareddesign.se |
#2108 |
Drives: WRB Limited BRZ
Anyone got recommendations for LCAs?
I noticed Jive Turkey is running SPCs, what all are you guys running? |
#2109 |
Drives: 2017 Subaru BRZ Crystal White Pearl
#2110 |
#2111 |
Drives: 2014 GT86
I'd probably would get Velox for no comprimises one i like most, or SPC(=Whitline,=Eibach) if lowest price and oem-look-alike matter most. For other alternatives i'd look only if i'd happen to be from extreme drop stance crowd, i won't.
#2112 |
Just placed an order for SPCs, I'm starting to wish I got the LCAs with the coilovers......really don't wanna go back under there LOL.
I was looking at RSR and Cusco and Voodoo they all look nice af but I think SPCs from the looks of it looks like a more Functional street car setup. The high end brands look pretty fancy while SPC just looks plain but still gets the job done. |
#2113 |
the tuna, no crust.
Drives: 2014 Hachiroku of the year
all you really need rolled is the rear. the front part i'm talking about you can do yourself in five minutes with a rubber end of a screw driver and a microfiber. its super small and bends right in.
rear fenders i suggest a roll, so you can run minimal camber back there. can you get an alignment that has more camber to not get a roll? sure, but then why go through all of this modding and not have the car dialed in exactly how you want....this guy just sounds lazy also, you didn't post your offset. offset is probably most important in fitting wheels correctly SPC is great. i ran them for a long time. I originally had Cusco and i hated them. they are the reason i needed toe arms. they also are a huge pain in the **** to adjust so alignments took forever. i always tell people get SPC unless you want to spend more in which case get SPL. all other arms suck to adjust and seize up. even my cusco seized up after i anti seized them and everything |
#2114 |
Drives: Scion FRS 2016
I'm planning to run 18x10 et44 TE37RT square 265/35 in spring. Anyone know what I have to dial in to avoid rubbing?
I feel like I may rub on the inside (I'm running ST coilovers). will I need to roll the rear with minimum camber? Your inputs are appreciated
___________________
2016 MT|Varis Arising II body kit with carbon add-ons|Aimgain x Stancenation Spoiler|Valenti Japan Jewel headlights|Valenti 4th Brakelight|ST-X coilovers|SPC LCA|18x10 TE37RT|Hankook Ventus RS3 265/35|Work Chrome blue lugnuts|Corsa catback|JDM TOM's red taillights|JDM armrest|TRD carbon Fender garnish|Beatrush Rear bumper brace|Cusco front strut |
| Winter Tire Review Thread (Please contribute) | pastuch | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 344 | 03-13-2024 05:49 PM |
| Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 | ScionFR-S | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 97 | 09-09-2015 06:32 PM |
| Meaty rubber on flush spoke rims? | red_comet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 16 | 06-14-2013 12:21 PM |
| Official wheel/tire fitment thread needed | empower-auto | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 06-22-2012 01:40 AM |
| The Wheel and Tire Fitting Thread | EvoFanatic | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 03-15-2012 03:05 PM |
