Old 02-13-2017, 09:22 AM   #2087
Wpomp
Drives: Asphalt FRS
Hey all, I just got a new set of summers, and am having some fitment issues. I have 17x9+35, running 255/45/17 BFG Sport comp-2 tires. I just put them on for a bit this weekend to see how the fitment was, as my last set was 17x9+40. I am noticing some rubbing in the rear that will require some rolling, and trimming the rear bumper tab. I have seen trimming the rear bumper tab many times, but having just looked at my car in that area for the first time, I am confused as to which part to trim? It looks like the bumper attaches to the rear quarter in this area, so I am confused as to how you would trim this without compromising the bumper staying on? Could someone point me in the direction of a DIY/pictures on which area to trim? Thanks!
Wpomp is offline   Reply With Quote
Old 02-13-2017, 09:31 AM   #2088
15limited
15limited's Avatar
How low are you?
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
Old 02-13-2017, 10:06 AM   #2089
frslee
Just drive it
Drives: 13' FR-S
Originally Posted by DuMa View Post
HI
Those look like Federal RS-RR, How do you like them?
frslee is offline   Reply With Quote
Old 02-13-2017, 01:08 PM   #2090
Wpomp
Drives: Asphalt FRS
Originally Posted by 15limited View Post
How low are you?
Never posted an image on here, so not sure if this will work. However, Not sure how much lower than stock I am, never measured the difference. Hopefully the pictures can illustrate properly. Really just looking for info on which area of the rear bumper "tab" people generally trim, because I believe that is where I am rubbing.
Thanks!
Old 02-13-2017, 01:45 PM   #2091
swarb
@Wpomp The tire you have installed is the wrong size. It is about 1" too tall. 255/40 is the better size.
What suspension do you have installed?
You will need to raise the car or trim the tab quite a bit. It will likely need be trimmed to the point where the push tab is no longer there and the bumper would be held on from the other clips and from the "L" part of the bumper would be "hooked" on. But if you pull on the bumper, the "L" part of the bumper will be easily pulled off as the tab is no longer there.
1. raise car
2. change tires
3. trim bumper or let tires auto trim bumper by rubbing
The Following 2 Users Say Thank You to swarb For This Useful Post:
Kris86 (04-28-2019), Wpomp (02-14-2017)
Old 02-13-2017, 02:10 PM   #2092
Wpomp
Drives: Asphalt FRS
1. raise car
2. change tires
Welp, Thats a big mistake on my part. Guess I shall see about a return if I can, and if not, live with the mistake. Raising the car was something I was going to do a bit of anyway, so that wouldn't be a big deal. I have ST coilovers on the car at the moment.
Thank you for the clarification on the bumper tab trimming, I appreciate the explanation!
Old 02-13-2017, 07:11 PM   #2093
Chayce808
Chayce808's Avatar
Drives: 2017 Subaru BRZ Crystal White Pearl
Got my wheels and tires mounted this past weekend 18x9.5 +40 with 265 35 18 MPSS 😀 #meatyftw
Sent from my SM-N920V using Tapatalk
Chayce808 is offline   Reply With Quote
The Following 9 Users Say Thank You to Chayce808 For This Useful Post:
8R6 (02-14-2017), drew_kar (02-13-2017), Keenercarguy (02-14-2017), mmmcambelsoup (02-14-2017), SkAsphalt (03-20-2017), slow15frs (02-14-2017), sqd (02-16-2017), swarb (02-14-2017), Wasabi (06-14-2020)
Old 02-13-2017, 08:19 PM   #2094
HachiRolle
Drives: 2017 Toyota 86
Any rubbing issues? And any chance you know your alignment specs?
Looks great!
HachiRolle is offline   Reply With Quote
Old 02-13-2017, 08:30 PM   #2095
Chayce808
Chayce808's Avatar
Looks great!
Thanks! Haven't had a chance to really drive the car much. Only drove it around in a parking lot, but when I did go over a bump the rear bumper tab rubbed so I used a dremel to shave it down. At full lock the tire rubs the fender liner. Also rolled the front fender near the sidemarker just to be safe. Alignment right now is set at -1.8 camber front and back and toe is set to
.08 front and back.
Old 02-13-2017, 08:51 PM   #2096
HachiRolle
.08 front and back.
Thanks for the info, gives some insight into my setup. I'm trying to fit an 18x10 +39 F and +44 R and it seems very mixed on going with a 255 vs. 265 depending on the tire, but your setup is fairly close to mine
Old 02-14-2017, 08:07 AM   #2097
15limited
15limited's Avatar
Yeah I'm running 245/45 and almost lowered 2" in the rear with no rubbing, but it's close. Yeah unfortunately live with it or take a hit on selling the tires slightly used and getting some smaller tires. Do you have adjustable LCA's? Dialing in some camber might get the top of your tire far enough away from that tab, but those tires are pretty fat haha good luck!
Old 02-14-2017, 10:31 AM   #2098
Wpomp
Drives: Asphalt FRS
Quote
Tire rack offered me a 50% return since they had already been mounted, since the bead was used once they can't sell them as "new". Oh well, the correct size is already at the shop and waiting to have me take the wheels to em. Semi-costly mistake, but rather do it right, than make things work with the wrong tires. Not currently running aftermarket LCA's. Perhaps in the future.
It definitely looked like I could have made it work, but I'm willing to accept that I made a mistake haha. Live and learn.
Old 02-14-2017, 05:59 PM   #2099
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
It's been cold af lately TN weather is the worst.....But hey Happy Valentines everyone
But here you guys go! I think I'm having issues at full lock, I'm either hitting or rubbing something. I'm also noticing at full lock the car tends to "raise" up a little I tried that when I was parked in my drive way.
Tein Flex Z, Lowered an inch all around. Haven't gotten an alignment yet I'm not sure where I'm sitting at with an inch drop. I'm still debating on LCAs.
Hankook Ventus RS3 265/35/18
Gramslight 57Xtreme 18 X 9.5 +40
Last edited by Alltezza; 02-17-2017 at 03:51 PM. Reason: More pics sunny day! Added offset
Alltezza is offline   Reply With Quote
Old 02-14-2017, 11:34 PM   #2100
DuMa
DuMa's Avatar
Drives: LR BRZ Limited
theyre grippy
theyre noisy
theyre oversized
theyre loud
theyre cheap
sometimes when im cruising on the highway and i think theres a jet following me. no its just the fucking tires screaming.
A++ would buy again.
DuMa is offline   Reply With Quote
The Following 12 Users Say Thank You to DuMa For This Useful Post:
15limited (02-14-2017), Cole (04-12-2017), DustinS (02-15-2017), frslee (02-15-2017), FujiwaraTofu86 (02-16-2017), gkubed (03-12-2017), lextrueno (08-21-2019), mmmcambelsoup (02-21-2017), nzer (02-15-2017), SuperTom (11-13-2018), TMXSTAR (05-07-2017), Webby (02-27-2017)
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 05:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 06:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 12:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 01:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 03:05 PM
