Old 01-31-2017, 05:03 PM   #85
Calvin27
Drives: GTS
Originally Posted by bem75 View Post
So, where is the sweet spot for a race engine? We ran the 15W-50 and temps climbed rapidly. I've also been advised by others in the know that they would never run a 50wt oil in the FA20. For stock clearances, I would agree with that. For a built engine, I tend to go with what the builder recommends.
As a note, a fellow racer with the exact same setup as mine ran a full season with Torco 5W-30 and had no issues. So, for a stock engine with FI, I'm interested to know the differences, under racing conditions, between 5W-30 and 0W-40. Any thoughts?
The Toyota 86 race series (Australia) runs a x-60 oil for stock internals. A few boosted guys that do circuit/track run 10-40 but hard to say what the impact here is as basically all forced induction will run oil coolers, compared to the stock configuration without one.
Calvin27 is offline   Reply With Quote
Old 02-01-2017, 06:31 PM   #86
TRAKRAVN
Drives: 2015 Scion FRS - Raven
With using that calculator would it not be possible to work out a recommended oil weight for an operating temperature? For example if you see 220F sustained at the track you should use X weight. If you see 240F sustained at the track you should use an X weight?
TRAKRAVN is offline   Reply With Quote
Old 02-01-2017, 07:30 PM   #87
cueball89
Drives: 15 Impreza
I suppose you could get a rough idea, there would be many variables I'd imagine.
Dezoris has good data here. http://www.ft86club.com/forums/showthread.php?t=76760 With his car, using the viscosity calculator, the lower limit on the viscosity across the 3 grades for what he deemed adequate oil pressure at varying temperatures is ~8.0-8.5.
My plan for my car and autox is bump up an oil grade, 30wt, and monitor the oil pressure and temperature changes. If I don't like the results I'll try a light 40wt or get an oil cooler. I don't think I need more than a 30wt oil as its just autox.
cueball89 is offline   Reply With Quote
Old 02-12-2017, 08:18 PM   #88
Calvin27
Drives: GTS
A bit of a bump here. Oil cooler is now in, do you guys recommend 0-20 with the oil cooler or still 5-30?
I'm thinking if you can keep the 0-20 relatively cool then it's properties should be ok. The reason for going back to 0-20 would be to maintain greater pressure than 5-30 to somewhat compensate for the oil cooler.
The Following User Says Thank You to Calvin27 For This Useful Post:
Chad86 (03-30-2018)
Old 02-13-2017, 08:35 AM   #89
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
For hardcore track use 5W30 would be better, but everyday use should be fine with 0W20. Especially if you've got a thermostat in the oil cooler adapter.
GSpeed is offline   Reply With Quote
The Following User Says Thank You to GSpeed For This Useful Post:
Chad86 (03-30-2018)
Old 02-15-2017, 09:21 PM   #90
zdr93523
zdr93523's Avatar
Drives: 2013 BRZ Limited
I run 10W-60 Liquimoly as required by the GT-86 Cup car owner's manual in my FI race car.
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523
Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car
www.makesmodels.com
www.camautomag.com
zdr93523 is offline   Reply With Quote
Old 02-27-2017, 10:20 PM   #91
BuffDriver
Drives: 2016 Subaru BRZ
So I have a 10 row cooler and a thermostatic adapter plate (all -10, fittings not banjos).
I am scheduled for my first driver training and track day 3/7/17 and am still uncertain whether to keep the OEM oil or go 5W30. I have a case of it in my garage as it's what I run in my truck.
My question is what exactly you mean by 'hardcore track use'? Does one day qualify as hardcore for the oil or do you mean multiple track times?
Edelbrock SC kit w/ ECUtek tune, Oil Cooler, UEL catted header, Perrin 2.5 Overpipe n Catted midpipe, 3.0 Catback resonated (all exhst ceramic coated), TRD short shifter, MTEC clutch n trans springs, Trans: Pentosin MTF2, Diff: Motul 75W90, Whiteline trans bushing, 3/4" clutch slave cyl., Ferodo DS2500 pads w/Motul 600 fluid, 17x8 wheels n 235/45ZR-17 tires
BuffDriver is offline   Reply With Quote
Old 02-27-2017, 10:26 PM   #92
Calvin27
Drives: GTS
Last track day without a cooler I ran 5-30 on a 30C day (hot) and even with 15 min sessions and a cooldown lap in between oil was getting real hot. Fast forward to oil cooler with 185F thermostat and I basically ran 30 minutes straight with no cooldown on 5-30 in 32C heat. In the end it was the tyre and brakes that couldn't keep up.
Old 02-28-2017, 08:56 AM   #93
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
It wouldn't be a bad idea to change the oil after your track day whichever you choose, but you've got nothing to lose by running 5W30. It shouldn't be too warm out, but periods of extended high-RPM and high load on the engine can still get oil temps up.
Basically, we never recommend people run 0W20 on track. Odds are your engine will be fine, but based on what we've see with sensors, 5W30 is likely safer for the engine.
BuffDriver (04-19-2017)
Old 05-04-2017, 11:50 AM   #94
OND
OND's Avatar
Drives: 2023 BRZ
It was within a few degrees, I'd consider that a normal variance between two sessions. If you were to average several sessions together that gap would likely disappear.
That is the part that doesnt make sense though. All things being equal, an increase in oil viscosity will always increase oil temperatures. If you see lower or same max oil temps when going from 0w20 to 5w30, that leads me to believe that the testing conditions were more favorable for 5w30.
OND is offline   Reply With Quote
Old 05-04-2017, 12:22 PM   #95
Icecreamtruk
Drives: Track preped NA FRS
Will it always be the case? Purely speculating here, but would it be possible the oil is not lubricating enough and its getting some more heat into from generated friction and increasing viscosity increases lubrication and the heat gained from the extra pressure is offset by the less heat generated in friction?
Im just speculating here, just trying to keep the discussion going in a sane/interesting direction.
Icecreamtruk is offline   Reply With Quote
Old 05-04-2017, 01:37 PM   #96
CSG Mike
CSG Mike's Avatar
"not lubricating enough" = touching metal surfaces (no film) = dead engine.
Old 05-04-2017, 01:54 PM   #97
OND
OND's Avatar
Drives: 2023 BRZ
That makes sense in the "boundary lubrication" regime, which is where you dont want to be due to the vicious cycle of thinning-->more heat-->more thinning... I think once you get to that point, you'll end up with a spun bearing in no time and I dont think that condition applies to this case.
Check out Stribeck curve (Fig 14) here:
http://edge.rit.edu/edge/P14453/publ...l_Bearings.pdf
Old 05-04-2017, 02:46 PM   #98
ApexEight
Drives: 2014 Subaru BRZ Limited 6MT SSM
What oil temps and pressures do you see with the 10W-60 during cold starts and also during race conditions?
ApexEight is offline   Reply With Quote
Quickie: 0w20 vs 5w20 / 5w30 empower-auto Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 43 12-17-2016 01:54 PM
Oil 5w30 cooldandani Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 26 05-27-2015 09:50 AM
UOA 5w30 Rocket.BRZ Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 49 07-07-2014 11:29 PM
Where to buy Eneos 5w30? mswhong AUSTRALIA 0 03-26-2013 06:25 AM
DOT Crash Test (non) Data for FR-S/BRZ Dadhawk Scion FR-S / Toyota 86 GT86 General Forum 15 03-24-2012 04:21 AM
