Old 01-04-2017, 12:32 PM   #897
wolfausti
Drives: 2013 FR-S Firestorm
I am currently on the stage 2 UEL E85 tune. Is it safe to reprogram TPMS light at the tire shop when I switch between my sets of tires? Or will this mess up my tune somehow? I'm told the only way to reset the light is to bring it to the shop and have them pair the tpms system. I have TPMS on both sets of wheels and tires I own. I searched extensively on google and the forums and couldn't find anything... thanks in advance for the help.
wolfausti is offline   Reply With Quote
Old 01-04-2017, 12:40 PM   #898
alxtheoreo
alxtheoreo's Avatar
If the reprogramming of the TPMS is via the wheel senors & scan tool (which plugs into the wheel valve stem), it should not affect the tune.
Sent from my SM-G930V using Tapatalk
Invidia catless FP & Q300. Enkei TS-10s. Conti ExtremeContact Sport tires. Hawk HPS pads. Centric Rotors.
alxtheoreo is offline   Reply With Quote
Old 01-04-2017, 12:41 PM   #899
Aussie
Drives: 2013 Scion FR-S 6MT
I have successfully programmed my TPMS codes myself with an OFT tune using the Carista App on my Phone using an OBD2 adapter. http://www.caristaapp.com
Aussie is offline   Reply With Quote
Old 01-04-2017, 04:35 PM   #900
wolfausti
The shop will do it for free for me since I purchased my tires through them. Thanks for the heads up on the app though!
Old 01-28-2017, 04:06 PM   #901
Cole
Not a troll
Cole's Avatar
Had a new CEL pop up today that I have not run into before, wondering how big of an issue it is.
Code is P0138. The car has been sitting for about a week now, and when I started it up, the code popped up. The car has a catless UEL header, tuned on an OTS 91 Stg 2 map.
I haven't seen a whole lot of info about it, so I'm wondering if it's an ok code to disable?
Cole is offline   Reply With Quote
Old 01-28-2017, 04:58 PM   #902
Kodename47
Kodename47's Avatar
Drives: UK GT86
@Cole
https://www.yourmechanic.com/article...by-jay-safford
If you're still running the 2nd sensor it may have gone faulty. I would just confirm what's said in the link. It could impact running even if the CEL is disabled.
.: Stealth 86 :.
Kodename 47 DJ:
Old 01-28-2017, 05:01 PM   #903
Cole
Not a troll
Cole's Avatar
Originally Posted by Kodename47 View Post
@Cole
Thanks.
I'll do a log today, and check on it.
Old 01-28-2017, 06:27 PM   #904
steve99
Drives: FT86
Originally Posted by Cole View Post
Thanks.
Yes +1 on what kode said
that code is not normal
https://www.engine-codes.com/p0138_subaru.html
oft logs rear 02 sensor as Widebamd 02, its not calobrated correctly but it should show some movement on that channel, however some roms the ram address is incorrect i think B01C is ok but later roms like D00C may not log correctly.
front 02 is logged as afr.
i think the oft can also log o2 sensor volts directly not sure if it can do front and rear o2 volts
its possible that code may be caused by exhaust leak or loose sensor as well as damaged sensor.
if you have techstream it would be usefull
Cole (01-28-2017)
Old 02-14-2017, 02:47 AM   #905
hapa_kcm
hapa_kcm's Avatar
Drives: WRB BRZ Limited
So apparently I got my OFT stolen and currently running an E85 tune. Is there anyway to get another brand new OFT to pair up to my car and get it tuned to 91?
hapa_kcm is offline   Reply With Quote
Old 02-14-2017, 05:27 AM   #906
steve99
Drives: FT86
If you get aonther new or unmarried oft it will marry up to your car ok. But your stock\original tune will be your E85 tune, but you will be able to flash any tune you like to car even real stock tune.
The downside will be that if you ever unmarry oft you car will go back to the E85 tune, the oft originally married to.
Alternative in this case maybe to buy tactrix cable instead and flash whatever tune you want. or if you know somone with tactrix cable who can flash you to stock before you marry up new oft
Old 02-14-2017, 04:31 PM   #907
MurderousPandas
MurderousPandas's Avatar
Drives: 2013 Scion FRS
You should be able to reflash the stock tune back on. I think there was a fix for people with flashes that went bad
"Chasing speed with patience"
MurderousPandas is offline   Reply With Quote
Old 02-14-2017, 08:52 PM   #908
Calvin27
Drives: GTS
Randon question, but anyone got an easy fix to turn the display upside down?
Is there a setting somewhere?
Calvin27 is offline   Reply With Quote
Old 02-14-2017, 10:26 PM   #909
steve99
Drives: FT86
tate Screen 180 degrees
Go to the main menu select feature option then rotate screen option, your done ..
info in the oft tips thread lnk below
Calvin27 (02-15-2017)
Old 02-15-2017, 07:30 AM   #910
elBarto
elBarto's Avatar
Drives: Toyota GT86
You can also try asking to update your ecu at your local dealer. Then you have a stockrom.
Verstuurd vanaf mijn Xperia L met Tapatalk
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners
elBarto is offline   Reply With Quote
WTB: Open Flash Tablet TOZER Canada Classifieds 3 07-05-2015 08:13 PM
Open Flash Header & Open Flash Tablet Calavera Engine, Exhaust, Bolt-Ons 9 05-11-2015 09:27 PM
FS: open flash headers / open flash tablet - SOLD alanhung85 Canada Classifieds 12 02-10-2015 03:08 PM
FS: Open Flash Tablet (OFT) mex2309 Engine, Exhaust, Bolt-Ons 1 10-29-2014 03:49 PM
Open flash tablet. cooldandani Scion FR-S / Toyota 86 GT86 General Forum 1 02-22-2014 08:14 PM
