Old 02-10-2017, 05:13 PM   #1
Drambeenie
Drambeenie's Avatar
Drives: Black 17 BRZ LT MT PP
2017 BRZ MT Drop-In Filter
Anyone know of available drop-in filters for the 2017 BRZ manual?
The 2017 automatic has the same filter design as previous years, but 2017 MT filter is different, and I can't find a drop-in filter yet.
Thanks!
Drambeenie is offline   Reply With Quote
Old 02-10-2017, 06:15 PM   #2
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Thanks!
Blitz has it available.
59624
Old 02-11-2017, 06:36 PM   #3
BRZ FTW
Drives: 2017 Subaru BRZ
59624
Any idea where to buy? I was wondering the same also.
BRZ FTW is offline   Reply With Quote
The Following User Says Thank You to BRZ FTW For This Useful Post:
Drambeenie (02-11-2017)
Old 02-12-2017, 06:49 PM   #4
mav1178
mav1178's Avatar
Should be in by end of month from what I understand.
Old 02-12-2017, 08:18 PM   #5
Qc86
Drives: 2017 Toyota 86 M6
So the frs drop in filter won't fit the new brz/86 MT? I was just about to order one
Qc86 is offline   Reply With Quote
Old 02-12-2017, 08:37 PM   #6
Lantana frs
Drives: 13 frs red
No. Different airbox for 17 manuals.
Lantana frs is offline   Reply With Quote
Old 02-12-2017, 09:27 PM   #7
Qc86
Alright I guess I'm gonna wait for k&n to release one
Old 02-13-2017, 02:06 AM   #8
steve99
Drives: FT86
The 2017 manual car air filter is already a higher flow version than the older stock filters in earlier cars, thier is likely little to be gained changing it
Old 02-13-2017, 03:51 AM   #9
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Really? Interesting. Between that and the larger diameter header you would think more then 5hp would be gained unless they kinda detuned it.
Old 02-13-2017, 04:37 AM   #10
steve99
Drives: FT86
it think it was 5 kw
but yeah better header better air filter better intake tube better intake maifold , new fueling strategy it doesnt run pig rich at higher rpm, you would think gain more
but aparanatly its more linear , but they likey had to compply with more stringent emmissions standards so that may have knobbled it a bit who knows
Old 02-13-2017, 04:37 AM   #11
churchx
churchx's Avatar
Drives: 2014 GT86
OEM always plays more safe.
As for stricter emission standards, i doubt it. Otherwise why those changes/improvements are not there for AT & for all MY2017 in EUDM?
Old 02-13-2017, 04:44 AM   #12
steve99
Drives: FT86
yeah all guesswork, but i suspect if you bring out a new model it might have to comply with latest standard but maybe for existing model you get some dispensation.
heard roumor that the changes done on engine didnt work well with auto for some reason.
the ecu fueling and timing logic in 2017 manauls is all new, but the auto runs the same old ecu code, its not just tune table changes in mannual ecu it whole new fueling strategy with full time closed loop and two sets of timing and fueling tables
jcw99 (02-13-2017)
Old 02-13-2017, 03:38 PM   #13
mav1178
mav1178's Avatar
The only major change on the intake side is a different air filter element. I will know by the end of month on whether this is a difference sized filter or not..
Air box location (inlet/outlet) as well as the intake tube (box to throttle body piping) is the same.
Aftermarket intake kits that utilize the stock tube are still the same part number.
-alex
Old 02-13-2017, 03:49 PM   #14
BRZ FTW
-alex
They tweaked the intake on the 17 MT quite a bit. Filter size does appear to have changed.
drop in filter, filter
WTB K&N Drop in Filter amilleri Want-To-Buy Requests 1 06-04-2016 05:35 PM
FS: aFe pro dry drop in filter (never used) FRSoxfan Engine, Exhaust, Bolt-Ons 4 05-13-2014 04:45 PM
K&N Drop in Air filter SkAsphalt Canada Classifieds 1 04-29-2014 03:29 PM
Drop In filter test! Stock, Apexi, No filter RallySport Direct Engine, Exhaust, Transmission 14 06-25-2012 02:40 PM
