-   -   2017 BRZ MT Drop-In Filter (https://www.ft86club.com/forums/showthread.php?t=115431)
Drambeenie 02-10-2017 06:13 PM
Anyone know of available drop-in filters for the 2017 BRZ manual?
The 2017 automatic has the same filter design as previous years, but 2017 MT filter is different, and I can't find a drop-in filter yet.
Thanks!
mav1178 02-10-2017 07:15 PM
Thanks!
Blitz has it available.
59624
BRZ FTW 02-11-2017 07:36 PM
59624
Any idea where to buy? I was wondering the same also.
mav1178 02-12-2017 07:49 PM
Should be in by end of month from what I understand.
Qc86 02-12-2017 09:18 PM
So the frs drop in filter won't fit the new brz/86 MT? I was just about to order one
Lantana frs 02-12-2017 09:37 PM
No. Different airbox for 17 manuals.
Qc86 02-12-2017 10:27 PM
Alright I guess I'm gonna wait for k&n to release one
steve99 02-13-2017 03:06 AM
The 2017 manual car air filter is already a higher flow version than the older stock filters in earlier cars, thier is likely little to be gained changing it
finch1750 02-13-2017 04:51 AM
Really? Interesting. Between that and the larger diameter header you would think more then 5hp would be gained unless they kinda detuned it.
steve99 02-13-2017 05:37 AM
it think it was 5 kw
but yeah better header better air filter better intake tube better intake maifold , new fueling strategy it doesnt run pig rich at higher rpm, you would think gain more
but aparanatly its more linear , but they likey had to compply with more stringent emmissions standards so that may have knobbled it a bit who knows
churchx 02-13-2017 05:37 AM
OEM always plays more safe.
As for stricter emission standards, i doubt it. Otherwise why those changes/improvements are not there for AT & for all MY2017 in EUDM?
steve99 02-13-2017 05:44 AM
yeah all guesswork, but i suspect if you bring out a new model it might have to comply with latest standard but maybe for existing model you get some dispensation.
heard roumor that the changes done on engine didnt work well with auto for some reason.
the ecu fueling and timing logic in 2017 manauls is all new, but the auto runs the same old ecu code, its not just tune table changes in mannual ecu it whole new fueling strategy with full time closed loop and two sets of timing and fueling tables
mav1178 02-13-2017 04:38 PM
The only major change on the intake side is a different air filter element. I will know by the end of month on whether this is a difference sized filter or not..
Air box location (inlet/outlet) as well as the intake tube (box to throttle body piping) is the same.
Aftermarket intake kits that utilize the stock tube are still the same part number.
-alex
BRZ FTW 02-13-2017 04:49 PM
-alex
They tweaked the intake on the 17 MT quite a bit. Filter size does appear to have changed.
