Old 06-28-2012, 04:38 PM   #15
RRnold
2 wheel member
RRnold's Avatar
Drives: JZA80, 997.1, Taco
Does anybody have any feedback on oil changing pumps?
Old 06-28-2012, 05:04 PM   #16
mr2lor
Drives: 2013 Scion FR-S Asphalt MT
For the FR-S, do we use the same one as the BR-Z or do we use the F-103. On their website, it states that all Scion used F-103 as well as Toyota.
mr2lor is offline   Reply With Quote
Old 06-28-2012, 05:24 PM   #17
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Use the F-108. The engine is a Subaru engine.
The Following User Says Thank You to Draco-REX For This Useful Post:
mr2lor (06-28-2012)
Old 06-28-2012, 05:27 PM   #18
Draco-REX
Corner Junkie
Draco-REX's Avatar
You'd have to get one with a hose that is small enough for the dipstick tube. Might take a while to drain the sump. Otherwise, I've seen people bring their filled pump in to recycle. Seems like they might work well.
My only issue with them is that the ones I've seen cost between $125 and $250. Maybe I'm not finding the cheap ones.
Old 06-28-2012, 06:23 PM   #19
RRnold
2 wheel member
RRnold's Avatar
Yeah, all of the lower priced ones that I've seen from Harbor Freight, Wal Mart etc didn't have good reviews.
Old 06-28-2012, 06:50 PM   #20
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
Does the magnet really have an effect? It almost seems like a "snakeoil" product.
Hawaiian is offline   Reply With Quote
Old 06-28-2012, 07:58 PM   #21
Hanakuso
How much force is needed to switch the oil valve? I would be worried it might release all the oil when i'm driving.
Hanakuso is offline   Reply With Quote
Old 06-28-2012, 08:33 PM   #22
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
Definitely. The nipple on the F-108N is easily an inch long, so the regular valve will have an inch of clearance. Anything that would hit the valve would do serious damage to the rest of your car and possibly high-side it. A damaged oil pan would be the least of your worries.
Beautiful! Aside from the vivid visual of me destroying my car in a fiery inferno. Thanks Draco, looks like I'll be picking one up.
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
Old 06-28-2012, 09:58 PM   #23
Surakusa
Mechanical Guru
Surakusa's Avatar
Drives: 2013 Scion FR-S (Argento) M/T
Call me crazy, but what can a magnet pick up? aren't engines made out of aluminum, as well as most of the innards that aren't bolts? those aren't magnetic. :P
Surakusa is offline   Reply With Quote
Old 06-28-2012, 11:20 PM   #24
Draco-REX
Corner Junkie
Draco-REX's Avatar
A reasonable amount. Also, when closed the lever sits in a recess that keeps it closed and a spring inside keeps the lever in the recess. If you're still concerned about it opening due to vibration you can get a spring clamp to keep the lever in place.
However, I think that's overkill. My WRX that I race in SCCA RallyCross has a Fumoto without the extra clamp and it has never opened on it's own.
In a fully broken in engine, not a whole lot. But it still can pick up some. The way I see it, any way to keep contaminates out of the oil is a good thing.
Probably an exaggerated pic, but:
If you've ever seen "Ferro Fluid" you've seen metal bits in an oil suspension. Except because the metal content is much lower in engine, the bits stay against the filter wall.
The block is aluminum, but the parts that wear, crankshaft, pistons, rings, sleeves, bearings, camshafts, lifters, etc are not.
Ultimately the filter magnet is one of those things that may have a long-term effect. Like getting 99.9% filtration filters instead of 95%. Does it truly matter? No one really knows because no one's going to pay for a long-term study to be sure. But it should matter, and it brings peace of mind.
I'll try to remember to rent an exhaust pipe cutter next time I change my oil and I'll cut the filter open and take pictures to see if it gathered anything.
The Following 4 Users Say Thank You to Draco-REX For This Useful Post:
gonzo (10-29-2012), Hanakuso (06-29-2012), Hawaiian (06-28-2012), LivingLegend (07-10-2012)
Old 06-28-2012, 11:27 PM   #25
Draco-REX
Corner Junkie
Draco-REX's Avatar
I had a thought and fired off a quick question to Blackstone Labs to see if they've seen lower metal counts when a filter magnet is used. If I get a reply I'll post it.
Old 06-29-2012, 11:02 AM   #26
Draco-REX
Corner Junkie
Draco-REX's Avatar
Ok, got a reply from Blackstone Labs:
Draco,
Thanks for the email. A lot of our customers use magnets on drain plugs and
filter. Our belief has always been that they certainly don't hurt anything,
but we normally don't see dramatically lower wear with magnets in place
versus no magnets. Still, getting metal out of the oil can't hurt anything.
Just don't expect lower wear in the oil analysis. Let me know if you have
any other questions and have a great day.
Alex Miller
Blackstone Labs
So, it doesn't hurt anything and certainly might be helping. But there's no solid evidence to prove one way or the other. I think it was a good purchase, personally. But others can decide on their own of course.
Old 06-29-2012, 11:18 AM   #27
lordtakuban
lordtakuban's Avatar
Drives: 2013 FRS - Whiteout
Does anyone know the correct Power Enterprise MAG II oil filter to use? Those come with magnets inside them already and are a really good filter. I use them on my MR-S and would like to continue to use them in my FR-S. I'm just having a difficult time finding out the proper one to buy. So far, based on some other cross-references, it looks like the OFII-04A is the correct one. But I am not certain.
Edit:
It could be either of these:
OFII-04A 65x80 (width x height in mm)
OFII-02A 65x70 (width x height in mm)
Both are: M20×1.5
The O2A allegedly replaces Subaru part number: 15208-A0130. That's not exactly the same as 15208-AA130. But I'm just trying to figure out the proper sizing. I suppose I'll just measure once I have the car and order the one that is the closest height then. The both should fit though.
2013 FRS - Whiteout - Slightly modified
2001 MR2 Spyder - Super White - Heavily modified
lordtakuban is offline   Reply With Quote
Old 06-29-2012, 12:41 PM   #28
Koji_Online
N7 Spectre
Koji_Online's Avatar
Drives: 2017 Toyota 86 (Ablaze - 6MT)
Hey whatsup, when I look at the Fumoto valve, I'm trying to figure out where the oil comes out; is it on the side of the open valve (90 degree angle to pan) or does it flow out the straight opposite ende of the opening that goes into the pan?
GT 6/ Sport PSN: Koji_Online
Koji_Online is offline   Reply With Quote
Odometer Functions - "S" & "G" What are they? kablammo BRZ First-Gen (2012+) — General Topics 59 12-01-2013 12:28 AM
NEW Volk Racing TE37SL "Black Edition" Different finish, same low price! Speed Element Wheels and Tires 19 07-19-2012 02:27 PM
Toyota Holds "FT-86 Fastest Painted Website" Event to Help Launch FR-S / FT-86 Snoopyalien24 Scion FR-S / Toyota 86 GT86 General Forum 35 11-26-2011 07:56 AM
May 2010 Car&Driver issue FT-86 article - "25 Cars Worth Waiting For" JDMinc Scion FR-S / Toyota 86 GT86 General Forum 76 04-17-2010 03:58 AM
