Old 02-08-2017, 03:53 AM   #1
edwardleeaf
Drives: Fr-s
17% LTFT. Checked for leaks and none.
Hi guys,
I'm currently running open flash headers + stg2 tune + trd exahust. I have an automatic frs. I am getting high ltft. I am sure I am using 91 octane fuel and using the stage2 tune map. I'm not sure how to fix the problem.
Me and my friend checked for exhaust leaks and there were none.
We took out the headers and also used new gaskets and that did not fix our problem.
Next, we checked if there was a vacuum leak. My friend suggested spraying brake fluid at certain locations while my car is turned on and my engine did not rev up.
Here is my second and third gear pull below.
http://datazap.me/u/edwardleeaf/seco...1?log=0&data=1
Here is a casual data log if that matters
http://datazap.me/u/edwardleeaf/long...log=0&data=1-5
I plan on calling elite performance soon for help. My friend suggest I post here first.
edwardleeaf is offline   Reply With Quote
The Following User Says Thank You to edwardleeaf For This Useful Post:
fibble (02-13-2017)
Old 02-08-2017, 05:23 AM   #2
Nah
Drives: 2013 Scion Frs 6mt
Bro,
Sounds like you just need to get your MAF scaled.
Stop messing with all that other dumb stuff and save yourself the headache.
Get a tune.
Nah is offline   Reply With Quote
The Following User Says Thank You to Nah For This Useful Post:
Teseo (02-08-2017)
Old 02-08-2017, 06:49 AM   #3
steve99
Drives: FT86
Stock intake ?
if you got no intake or exhaust leaks, check catch cans
check 02 sensors screwed in all the way ring should not be loose, use thread chaser to clean up header bungs if necessary and no o2 spacers
its got classic signs of leak though high fuel trims at lower rpm and ok at mid upper rpm where leak has less effect
then rescale maf
Teseo (02-08-2017)
Old 02-08-2017, 06:52 AM   #4
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
He is tuned. This is not a MAF scaling issue.
It's worse at idle speeds, when pulling it goes lower. Your AFR looks good. Looks like a vacuum leak.
What kind of intake do you have and have you recently done anything to it? Do you have a oil catch can?
guybo is offline   Reply With Quote
Old 02-08-2017, 06:59 AM   #5
guybo
Huge E85 fan!
guybo's Avatar
Whoa that was weird, Steve99- we both answered at the same time, same answer.
Except the O2 sensor thing
The Following User Says Thank You to guybo For This Useful Post:
Chimera (02-08-2017)
Old 02-08-2017, 08:09 AM   #6
aagun
Drives: 86
cold start logs plz
aagun is offline   Reply With Quote
Old 02-08-2017, 11:03 AM   #7
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
If you had a vacuum leak big enough to cause +20% fuel trims, your car would be idling high in neutral / park.
You 100% sure there are no leaks on the intake after the MAF? MAF screwed in securely? All couplers on the intake tight? Are you running stock or an aftermarket intake? The OFT maps are tuned for OEM intakes, so if you are running an aftermarket intake, that is your issue. In that case, get a custom tune done as recommended above.
Otherwise we need more info on your full setup to help.
'13 WRB BRZ ~470whp // Instagram // YouTube
BRZoomTX is offline   Reply With Quote
The Following User Says Thank You to BRZoomTX For This Useful Post:
Teseo (02-08-2017)
Old 02-08-2017, 11:07 AM   #8
cjd
cjd's Avatar
Drives: 2017 BRZ
How'd you check for exhaust leaks? I had similar symptoms and it took a vacuum on the tailpipe and a tube to my ear to find any leaks. More than an inch away with the tube and I couldn't hear it. A small leak near the O2 sensor (before or after) will get swamped out while running hard but will show up in a hurry as soon as you lift, and at idle.
Old 02-08-2017, 12:04 PM   #9
aagun
Drives: 86
my point is looking for carbon build cozz by leaks
Old 02-08-2017, 02:58 PM   #10
edwardleeaf
Drives: Fr-s
Thanks for the answer guys.
I do have a stock intake. I have a K&N drop in air filter (is there anyway I can install this wrong? I reference "http://www.ft86club.com/forums/showthread.php?t=34343 " and it was "good good good". )
I do not have an oil catch can. I'm running stock everything else.
I'm pretty sure my MAF is screwed in tightly. I can double check on this area. How would I know it is not tight?
This is how I checked for exhaust leaks:
Tape both tail pipes and blew a vaccum through. I use soapy water and sprayed everywhere.
Way before, i noticed there was a small leak in the donut gasket(there was bubbles) for the headers so I replaced that, and double checked that spot twice,at two different moments, and there was no leak there. When we fixed that leak, that did not change my ltft at all.
Old 02-08-2017, 03:02 PM   #11
edwardleeaf
Drives: Fr-s
Stock intake ?
then rescale maf
Are catch cans aftermarket? I do not think I have one. I'll try using a thread chaser to clean up the o2 sensor hole.
Anyone with a BRZ get brake-checked tonight? HachiRo Northern California 52 02-02-2015 05:37 PM
Orange you glad you checked this thread?!? BlaineWasHere FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 23 04-09-2013 06:02 PM
get your brakes checked... tibsy92 AUSTRALIA 22 09-21-2012 10:10 PM
Checked out an FR-S and BRZ yesterday, parked my MR2 next to 'em Turbowned New England 6 06-04-2012 11:08 AM
Anyone checked this site out? ryude Southeast 3 01-16-2012 01:40 PM
