Old 01-15-2017, 09:37 PM   #169
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
Prepping for clutch swap, again. My old one was damaged and was causing vibrations. Sucks that the new Exedy stage 1 doesn't work with the older lightweight flywheel they previously included. Oh well, OEM flywheel it is.
New two piece investment casted overpipe installed. It looks so pretty, it really makes my existing exhaust look crummy.
New gtx2867r vs old gt3076r.
Turbo mounted.
Heat shield to protect the sway bar bushing from melting during those 100 degree track days.
Final look at the turbo installed with undertrays on.
Exhaust installation tips for those installing the PTuning turbo kit themselves, this is just from my personal experience. I'm not a professional mechanic.
[ame]http://youtu.be/DVPvea2uoDg[/ame]
First WOT pulls at 6psi on base timing map while data logging.
[ame]http://youtu.be/GtF-NSxMwTI[/ame]
rb6freak is offline   Reply With Quote
The Following 7 Users Say Thank You to rb6freak For This Useful Post:
Bowen (01-16-2017), Bramick (01-16-2017), D_Thissen (01-20-2017), Hicklinc (01-30-2018), M1K3 (01-16-2017), Mrc@ptuning (01-16-2017), skylinekin (01-20-2017)
Old 01-16-2017, 03:48 PM   #170
Mrc@ptuning
Mrc@ptuning's Avatar
Drives: S1000RR
Glad to see her back on the road. How do you like the spoolup of the smaller gtx28
Mrc@ptuning is offline   Reply With Quote
Old 01-16-2017, 05:29 PM   #171
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
Not as dramatic as I expected just doing pulls with the boost solenoid active. However on-off-on throttle I can definitely feel the difference, boost ramps up fast. I should really feel a difference on the track. I'm still at least a few weekends out from booking track time. My oil leak returned, albeit a lot smaller leak this time . I'll revisit that after the tune is dialed in.
The induction sound will take some time to get used to, I wonder if its the cobra intake, or just the sound of the turbo.
The Following 2 Users Say Thank You to rb6freak For This Useful Post:
Hicklinc (01-30-2018), Mrc@ptuning (01-17-2017)
Old 01-16-2017, 08:02 PM   #172
Evil Rocky
Drives: FRS
Love your build. I been following your YouTube channel too.
Keep us all updated
Evil Rocky is offline   Reply With Quote
The Following User Says Thank You to Evil Rocky For This Useful Post:
rb6freak (01-16-2017)
Old 01-20-2017, 09:02 PM   #173
skylinekin
skylinekin's Avatar
Drives: 22 GR86, 13 FRS, 15 BRZ, 13 FRS
@rb6freak Hows the clearance now between turbo inlet to the overpipe?
skylinekin is offline   Reply With Quote
Old 01-20-2017, 09:06 PM   #174
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
Doesn't touch, not even the steering rack either. The GT28 is so much smaller than the GT30 too so there is actually a lot of room down there. Even the first charge pipe was easier to install this time as it had so much clearance over the transmission.
Loving this turbo, with the solenoid active; I'm at full WG spring pressure from vacuum in what feels like less than a second.
Still dialing in the tune.
Hicklinc (01-30-2018), skylinekin (01-20-2017)
Old 01-20-2017, 09:43 PM   #175
skylinekin
skylinekin's Avatar
Awesome, I am about to pull the trigger on the new overpipes so that is great to hear.
Also, it looks like you have your front anti-roll bar pre-loaded (end links are overextended). Ideally the anti-roll bar "blade" should be as close to parallel with the ground as possible (when the car is on the ground).
Do you have it adjusted that way for some clearance reason?
The Following 2 Users Say Thank You to skylinekin For This Useful Post:
Hicklinc (01-30-2018), rb6freak (01-20-2017)
Old 01-20-2017, 09:51 PM   #176
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
I don't remember why I set them as seen in the picture, I set them about 3 years ago and never looked back lol. I'll look into readjusting them next time I lift the car. What is the "blade" portion?
Old 01-20-2017, 10:12 PM   #177
skylinekin
skylinekin's Avatar
The end section of the bar with the hole for attaching the end link. You will most likely need to completely shorten the end link top and bottom to make it flat.
Hicklinc (01-30-2018), rb6freak (01-21-2017)
Old 01-21-2017, 01:09 AM   #178
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
Thanks bud, I'll give it a try this weekend.
Old 02-07-2017, 11:48 PM   #179
BRZ_Willy
BRZ_Willy's Avatar
Drives: 2016 WRB Subaru BRZ
Could you elaborate more on your oil leak?
Also, is there a reason you haven't installed a catch can?
BRZ_Willy is offline   Reply With Quote
Old 02-07-2017, 11:56 PM   #180
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
I had an oil leak on the mechanical oil pump, resolved it, and I thought it came back. But I was mistaken. It was just residual oil from reinstalling it the last time.
Setrab series 9 15 row. Seems to be perfect. Other guys have done 25 row but it's too much, however you can track all day long in 100 degree weather lol.
My tuner said I don't need it, and I've checked out others at the track with catch cans. Small amount in the PCV, none in the CCV. For me it's really not worth the extra hoses and etc... Just to save a little blow by burn. The tune handles the detonation if any.
The Following User Says Thank You to rb6freak For This Useful Post:
Old 02-08-2017, 12:03 AM   #181
BRZ_Willy
BRZ_Willy's Avatar
Thanks! I've been seriously considering the Ptuning Turbo kit and it looks like it is really well put together. I still have a year or so before the funds will be made available for boost. Too many home repairs Look forward to more videos on YouTube!
The Following User Says Thank You to BRZ_Willy For This Useful Post:
rb6freak (02-08-2017)
Old 02-23-2017, 01:24 PM   #182
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
101 octane tune has started
I went a little too high on the duty cycle as I was dialing in the boost settings, however the EcuTek logs looked just fine, no knock, whew!
[ame="http://youtu.be/Duc1KaTw71g"]https://youtu.be/Duc1KaTw71g[/ame]
Hicklinc (01-30-2018), skylinekin (02-23-2017)
AVO turbo kit for BRZ - initial build thread AVOturboworld Forced Induction 3109 12-01-2019 04:55 PM
My trip to FBM - FBM Premium Turbo Kit build brzaapi Forced Induction 170 11-12-2013 07:04 PM
400hp build and other turbo questions. Ludacrits Forced Induction 22 10-26-2013 10:01 AM
Just wanted to show off my turbo build sw20kosh Forced Induction 5 04-01-2013 04:16 PM
Turbo engine build, and parts No Limit Motorsport Forced Induction 30 12-11-2012 08:32 PM
