Old 02-04-2017, 06:47 AM   #1
FReSh-af
Drives: 2013 Scion FR-S, 2014 Scion tC
2AR-FE
Can anybody point me in the right direction with my idea for a 2AR-FE DD?
FReSh-af is offline   Reply With Quote
Old 02-07-2017, 01:09 AM   #2
KR-S
Sporadic Member
KR-S's Avatar
Drives: 2016 Halo FR-S M/T
Aside from more torque, what do you find more appealing about the 2AR?
Old 02-07-2017, 01:47 AM   #3
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Because OP wants a Camry in a 86 body.
KR-S (02-09-2017)
Old 02-07-2017, 07:55 AM   #4
2JZ-GTE
What license?!
2JZ-GTE's Avatar
Drives: 2015 Scion FR-S
So no Camry can never pull on a FT86 ever again.
[ame="https://www.youtube.com/watch?v=T3_wvXDCQRM"]https://www.youtube.com/watch?v=T3_wvXDCQRM[/ame]
2JZ-GTE is offline   Reply With Quote
Old 02-07-2017, 02:13 PM   #5
FReSh-af
Cause the 2ar-fe is basically a 2jz with two less cylinders.
Ever seen Fredric Aasbo's 2AR from Papadakis Racing?
Old 02-07-2017, 02:28 PM   #6
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
There are two engines worth swapping: 2JZ and LS?. Everything else is inferior and/or too expensive.
Old 02-07-2017, 02:32 PM   #7
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Can't blame a guy for wanting to be different.
Personally, I would do a rocket engine.
Current DD: M235i
8RZ is offline   Reply With Quote
The Following User Says Thank You to 8RZ For This Useful Post:
KR-S (02-09-2017)
Old 02-07-2017, 02:33 PM   #8
FReSh-af
Those are some of the best engines but I'd like to have 800hp come from an 51lbs 4 cylinder (empty of course), and still have room under the hood for more.
Old 02-07-2017, 02:41 PM   #9
MRS-Colin
Drives: 2001 Impreza 2.5 RS
You might have the 3S-GTE and the 2AR-FE confused
Colin Beck
MRS-Colin is offline   Reply With Quote
The Following User Says Thank You to MRS-Colin For This Useful Post:
KR-S (02-09-2017)
Old 02-07-2017, 02:43 PM   #10
mav1178
mav1178's Avatar
Good luck spending 2 years of your life developing this.
http://www.motoiq.com/MagazineArticl...ta-Engine.aspx
KR-S (02-09-2017)
Old 02-07-2017, 02:45 PM   #11
FReSh-af
That's the link my inspiration came from. Lol
Old 02-07-2017, 02:46 PM   #12
FReSh-af
Too be honest didn't know that engine existed, but it seems intereating and research worthy.
Old 02-07-2017, 02:49 PM   #13
8RZ
The Gunshine State
8RZ's Avatar
3S-GTE is known as the 4-cylinder 2JZ.
Current DD: M235i
Old 02-07-2017, 02:54 PM   #14
FReSh-af
The 2AR is the first I4 I've actually liked, never took any other 4 cylinders into consideration, so I didnt do too much research into other 4 cylinders. Always liked the body of the MR2's, just haven't taken a look under the hood of one.
2arfe, 4 cylinder, daily driver, frs, swap
