Old 02-06-2017, 08:31 PM   #1
number_Un0
Drives: 2013 FRS 10 series #0001
Transmission dust cover?
I was taking a look under my hood the other day and i noticed that something seemed to be missing from that slot in the picture.
Im not sure if its suppose to be like that or if their should be a rubber or metal piece that covers that hole. If so, what is that part called? Because i tried searching for it but couldnt find anything.
number_Un0 is offline   Reply With Quote
Old 02-07-2017, 12:22 AM   #2
I don't know if it's just the Olathe Toyota website but I had shit for luck finding it as an frs.
Here's the brz part.
number_Un0 (02-07-2017)
Old 02-07-2017, 02:47 AM   #3
number_Un0
Thanks for the help ultramaroon!
What is the purpose of that hole tho?
Old 02-07-2017, 02:53 AM   #4
Flashfire88
Flashfire88's Avatar
Drives: Limited Silver
Yes there's supposed to be a rubber plug on there, prevents clutch dust from forming around the opening and serves as a visual inspection whenever you need to look around inside the housing for whatever reason. It's not a critical thing to have but with time that area will look like brake dust has never been washed off.
-Avo @ 10.5psi-
Flashfire88 is offline   Reply With Quote
Old 02-07-2017, 06:28 AM   #5
NLSP
NLSP's Avatar
Drives: 2014 Ultramarine FR-S
That's why this was produced:
https://www.velox-motorsports.com/pr...2-d3784bb555ba
The Following User Says Thank You to NLSP For This Useful Post:
Old 02-07-2017, 12:18 PM   #6
number_Un0
Originally Posted by NLSP View Post
Come to think of it, the rubber piece probably flew out on my last track day (as mentioned possible by Velox) since I noticed it was missing after my last session.
Old 02-07-2017, 12:37 PM   #7
Ragin Gti
Drives: '15 Subaru BRZ
The opening is for removing the torque converter bolts on an automatic/CVT. All Subaru engines have that hole.
Ragin Gti is offline   Reply With Quote
Old 02-07-2017, 12:54 PM   #8
Or melted. :/
I wasn't going to assume you're tracking it but yeah, maybe Eric's special cover is what you really want.
Old 02-07-2017, 01:30 PM   #9
number_Un0
Or melted. :/
Would it cause any issues if it fell inside?
Old 02-07-2017, 01:34 PM   #10
Nah, except for the gooey mess it made. Just a hunk of rubber.
Old 02-07-2017, 03:33 PM   #11
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
Mine falls off after an autocross or track day. I might grab that replacement part though better safe than sorry.
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
Old 02-07-2017, 03:41 PM   #12
number_Un0
Ill probably end up getting the Velox piece
Old 02-07-2017, 03:54 PM   #13
tobin
tobin's Avatar
Drives: '13 BRZ
Does it matter that the Velox cover isn't a perfect seal like the factory rubber piece? Will dust and dirt make their way into the clutch area over time?
tobin is offline   Reply With Quote
Old 02-07-2017, 04:01 PM   #14
It's wide open anyhow. I don't know which is the input versus output but there are ports at the top left and bottom left corners of the bell housing. It's designed to circulate fresh air to cool the clutch.
tobin (02-08-2017)
WTB: Shifter Linkage Dust Boot & Shifter Dust Boot Erick.Hnandez Want-To-Buy Requests 6 01-27-2021 05:58 PM
Car needs a new transmission but Subaru wont cover it under warranty.. rhythmM Southern California 31 04-19-2016 02:20 PM
Parking brake dust cover Chaetagnath Cosmetic Modification (Interior/Exterior/Lighting) 18 08-29-2014 11:05 PM
changing idler pulley from vortech, dust cover? Sniper2606 Forced Induction 0 02-01-2014 04:02 PM
Brake dust or rail dust? Dealership bs? Muskokan Issues | Warranty | Recalls / TSB 12 12-21-2013 09:30 AM
