Old 02-06-2017, 11:26 AM   #15
VTEC
Drives: Scion FR-S
Don't do it. Like @humfrz said, this engine is designed/tuned for 93 octane. It'll run on California 91 but it pulls timing hard to manage the knock.
It's a terrible idea. Don't do it.
^This. 91 octane is bad enough. Don't do 87. This is not a heavy ass minivan with a big 3.5L V6 that guzzles gas. It's a small lightweight car with a small 4 cylinder engine. It's really not that expensive to use 93 octane. And if you use 87 octane on a regular basis you may end up with costly repairs that will greatly exceed whatever little money you saved at the pump.
Also I'm pretty sure your Honda Odyssey does not take premium fuel so using 87 octane for that is correct.
Also this is your car so wouldn't you be filling up the tank anyway? How would he know what gas you are using?
Instagram: @racecar_4life
VTEC is offline   Reply With Quote
Old 02-06-2017, 12:02 PM   #16
kakacarrotcake
kakacarrotcake's Avatar
Drives: Man
Send a message via ICQ to kakacarrotcake Send a message via AIM to kakacarrotcake Send a message via Yahoo to kakacarrotcake
Really just want to drive home the "Do not use anything lower than 91" message here.
If you use low octane gas...
kakacarrotcake is offline   Reply With Quote
Old 02-06-2017, 02:04 PM   #17
JD001
JD001's Avatar
Drives: Subaru BRZ
16 posts in and still no Tcoat..
Old 02-06-2017, 02:09 PM   #18
OK OK
Geeeez
I figured everybody had it under control.
Manual says 93 recommended, minimum 91 REQUIRED.
Volt, tell the old fogey that it must have a minimum of 91 or it could die.
JD001 (02-06-2017), Ultramaroon (02-06-2017)
Old 02-06-2017, 02:36 PM   #19
funwheeldrive
Originally Posted by VoltsFRS2013 View Post
thank you so much, first car...
Another one bites the dust.
Old 02-06-2017, 02:55 PM   #20
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Race gas or GTFO.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 02-06-2017, 03:02 PM   #21
VoltsFRS2013
VoltsFRS2013's Avatar
Drives: 2022' GR86 Premium 6MT
Thank you all for the replies. I'll make sure the message is put across clear that no lower octane fuel goes in the car.
Sometimes my dad comes around and checks our vehicles out, and out of habit If i wasn't around he might take the car out and throw normal gas in it which was my concern.
VoltsFRS2013 is offline   Reply With Quote
Old 02-06-2017, 03:05 PM   #22
If he does it a couple of times it won't hurt a thing. It isn't going to blow up because it had a half tank of 87 run through it. Just don't run regular in it all the time and all will be good.
Old 02-06-2017, 03:06 PM   #23
wrh3
billswebspace.com
wrh3's Avatar
Drives: 2017 Alfa 4C, 2019 Fiat 124 Abarth
Thank you soo much!
A question about the premium gas thing --
my dad is a bit on the cheaper side and is going to insist on putting normal fuel in it (we already do this for our 2007 Honda Odyssey Touring that is meant to heave premium in it)
Will it hurt it to go back and forth? it's hard to reason with him
I have this same argument with my father, it is not some gas company conspiracy
This motor is a high compression motor and needs the extra octane to avoid pre-detonation. The computer will pull as much timing as possible when using less than required octane gas, as a result gas mileage goes down and you may have additional wear on the engine if the computer cannot pull enough timing to compensate.
It's almost more cost efficient to use the correct gas maximizing MPG and engine life.....appeal to your father's economic side and he won't argue the highest octane you have available in your state as stipulated right in the owner's manual (another appeal to your father, "Look, the guys that built the car state this").
Good luck in your debate
Bill
BillsWebSpace.com
wrh3 is offline   Reply With Quote
Old 02-06-2017, 03:15 PM   #24
One of the most common misconceptions about premium gas in a nut shell! People presume since it cost more then the station is making more from it. That is not even close to the reality. It costs more because it is more expensive to make. There are many stations that don't even want to carry it because there is a smaller profit margin in it than regular. Gas stations make their money by selling volume not by huge markups and many just do not sell enough premium to get that volume. On the other hand if they don't have it then they lose customers that may have more than one vehicle and use both so they are sort of stuck with it.
Dadhawk (02-06-2017), Ultramaroon (02-06-2017)
Old 02-06-2017, 03:19 PM   #25
Just say "Dad, my car, my rules". He should respect that....
Mine has had 87 in it twice. Very first full tank (done by dealer, without me realizing) and during the Colonial Pipeline induced fuel shortage. So far she hasn't turned wheels up in the morning.
As @Tcoat said, just don't do it regularly and if it does happen just dilute it (strengthen it?) by filling the tank at half full the next couple of trips.
Old 02-06-2017, 05:17 PM   #26
ChimpMania
Drives: 2014 WRB BRZ 6MT
don't buy a sports car if you can't afford the gas..or the maintenance
ChimpMania is offline   Reply With Quote
The Following User Says Thank You to ChimpMania For This Useful Post:
finch1750 (02-06-2017)
Old 02-06-2017, 07:04 PM   #27
Oh, hell, there is nothing special about this car with respect to maintenance. It gets expensive when you start tracking and modding it.
Leave it alone and it's a great little "relatively" inexpensive go kart.
Tcoat (02-06-2017)
Old 02-06-2017, 08:21 PM   #28
VoltsFRS2013
It's not even an affording thing, my dad just prefers to save money. And as to maintenance I have bumper to bumper provided by Toyota due to us financing through Toyota about 10 years ago. The bumper to bumper last a handful of years, I forgot the exact package.
ANYWAYSSSS
We talked and he was more than happy to fuel it with premium. Most fuels around here are like 93 Octane I believe.
The Following User Says Thank You to VoltsFRS2013 For This Useful Post:
Finally got her + BRZ available! ironchef BRZ First-Gen (2012+) — General Topics 12 09-17-2012 08:55 AM
FINALLY GOT IT! Ayaz2589 NY / NJ / CT / PA 8 07-28-2012 02:52 AM
She's finally here :) wawro569 Scion FR-S / Toyota 86 GT86 General Forum 21 07-25-2012 10:07 PM
FINALLY ! geb2391 BRZ First-Gen (2012+) — General Topics 22 07-24-2012 11:50 AM
Finally came in, yeh!! huma BRZ First-Gen (2012+) — General Topics 26 07-21-2012 02:23 PM
